Question about HP Computers & Internet
I have used my HP Pen Drive on a computer in a Cyber Cafe n at that time it was working absolutely fine n but after that when I tried to use it on my own computer it was not detected by my computer or I have cheked it on other PC's too but result was the same. So now tell me how I can fix my Pen Drive. It's HP 4 GB Pen Drive ...
  • HP Master
  • 27,725 Answers
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts also
scroll to disk drives if you can see your drive + to expand right click you should see options update driver disable uninstall scan for hardware changes
select properties you should see options in the general tab to troubleshoot policies volumes driver and details under the driver tab you will have the options to check the driver details update driver rollback driver or uninstall
hope this helps
Posted on May 24, 2011
HP v218g PEN DRIVE 16 GB SHOWING 0 BYTES MEMORY
Click start control panel administrative tools computer management disk management right click on your drive select properties
then you restore it to its default status
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
Hope it helps.
Dec 02, 2012 | Electronics - Others
My hp pen drive shows the icon but i could not open it,i am using windows xp,pls help me
If your system did install the HP software/drivers for this pen the first time you connected, try reinstalling the drivers, reboot your system and try again.
Good Luck
C2Solutions
Jan 20, 2011 | HP 16 GB USB FLASH DRIVE PRO FULL SPEED...
.the main server does not
pano ko po ma upload ulit yung cafe manila ko kasi na dlete po sa server
Jan 04, 2011 | Cafe Manila Cyber Cafe Management Standard
My pen drive is not detecting in any pc, previously it was working fine. And also how to get serial no. for HP pen drive
if its not detecting in any pc.the only way to get the serial number is on bill or on box.as pen drive is not working now it will not be possible to check serial number on pen drive
Dec 30, 2010 | HP 16 GB USB FLASH DRIVE PRO FULL SPEED...
I have a HP 4gb pen drive.Initially it was working fine but now even a small data transfer takes too much time,e.g. to transfer a data of 600mb it takes 45min or even more. What is the cause of this...
1. make sure USB port is 2.0
2. Try another USB port
3. Format your'e pen drive and try again
4. Finally, try another computer
if all fails, consider buying a new one.
good luck
Nov 08, 2010 | Office Equipment & Supplies
My pen drive was write protected by DPROTECT.DAT
Not sure what you want to do. If you want to use it and there is nothing important in the thumb drive, you can go Format by right clicking on the thumb drive and pressing format. This way you can start fresh with it.
Dec 08, 2009 | Computers & Internet
I have a HP Evo Intel Pentium 4 destop oc, xp pro (dc5000). it crashed and when we went to reload the OS and drivers, we lost most of the drivers and applications. I can boot it up but it will not go...
Since you have an HP, you can order a replacement set of "System Restore" disks from HP, for less than $20 -- much less than buying a "retail" copy of Windows. That set of CDs will have the correct drivers and the same "factory-installed" applications.
Oct 28, 2009 | HP Compaq EVO D51S Intel Desktop PC -...
Pen drive unable to Read
Have you tried to use the pen drive in another computer. If the pen drive does not work in another pc then this pen drive could be fried. There is whats called "Safety Removal Hardware" This should be used before removing any hardware from the pc. Also have you ensured that all the updates have been carried out on that computer?
Jul 27, 2009 | HP Computers & Internet
Computers & Internet Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
