Question about Intel D845GRG Motherboard
I have a intel d845grg desktop.my problem is that i reinstalled windows xp and now there is no sound devise or driver. i have tryed the downloads on intel downlaod centre but it do not work.
  • 961 Answers
Unfortunately, you have Soundmax AD1981A AC97 sound. The only download I can find for you, which you may ahve already have tried, is here
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=N&ProductID=824&DwnldID=12170&strOSs=44&OSFullName=Windows*%20XP%20Professional&lang=eng
You can give it a try if you haven't already. The Soundmax sound is no longer supported at all. You may want to consider a sound or graphics card if all else fails. Good luck.
Posted on May 24, 2011
I HAVE INSTALLED A NEW COPY OF WINDOWS xp AND LOST MY SOUND DRIVERS
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
don
Feb 20, 2011 | Intel D845GRG Motherboard
D845GRG INTEL CORPORATION MOTHERBOSRD
If you are looking for the device drivers for this Intel motherboard then -
You can download the motherboarddrivers from Intel WEB site. Select your model motherboard/device, and makesure you select the Windows XP or Vista version of the drivers that matchesyour Windows operating system. Please click on this link andselect your model motherboard : - http://downloadcenter.intel.com/default.aspx?iid=gg_support-au+home_downloadctr
Nov 29, 2010 | Intel D845GRG Motherboard
Necesito los drivers de ethernet D845GRG
Drivers for Intel D845 Chipset are available at Intel Official Site
Click here and select "Operating System" and "Type of Download". From the list choose the drivers you need.
Good Luck!
Hope this helps!
CreativeTECH
Nov 05, 2010 | Intel D845GRG Motherboard
Download motherboard driver
You can download the motherboard drivers from Intel WEB site. Select your model motherboard/device, and make sure you select the Windows XP or Vista version of the drivers that matches your Windows operating system.
Please click on this link and select your model motherboard : -
Aug 20, 2010 | Intel D845GRG Motherboard
I NEED A AUDIO DRIVER
Hi darylsg,
You can download the driver or drivers from Gateway for the E-2300 system from the link below;
http://support.gateway.com/s//PC/E2300_Series/1008302/1008302nv.shtml
Scroll down the list for sound driver. If you wish to use Intel's driver instead of Gateways click on the next link;
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=824&OSFullName=Windows*+XP+Professional&lang=eng&strOSs=44&submit=Go%21
The audio driver is listed as number 5.
You should try Gateway's driver first even though the E-2300 uses the Intel board.
Intel customizes boards for each manufacture.
Still have problems, post here.
Mike
Apr 25, 2009 | Intel D845GRG Motherboard
Sound problem
you need to install a compatible multimdia controller/driver for your system.Uninstall the previous driver and Check out this site below for some audio drivers.Make sure it is XP compliant.
http://drivers.softpedia.com/essentials/SOUND-CARD.shtml
Jul 20, 2008 | Intel Frontier Design Dakota 24-Bit PCI...
Sound problem
Try to find updated drivers. Or rollback the old drivers.
Also if you fix this issue and the sound still doesnt work...
try this :
Go to run
type services.msc
look for Windows Audio under the Services Menu.
Right-click it and click 'Start'
hope this fixes it! get back to me :]
Jul 16, 2008 | Intel Frontier Design Dakota 24-Bit PCI...
Sound Card Drivers Intel PENTIUM-4 865GV mother board
i m using motherboard of intell pentium 4 can u help me for intallation of sound drivers or to download it thx zakir
Jul 07, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Mouse not working after BIOS upgrade on Intel D845GRG motherboard
use usb mouse
othervise re format yours whole system low level
and re install win xp or whataver you want
Dec 14, 2007 | Computers & Internet
Intel D845GRG Motherboard Logo
127 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
