SOURCE: I have a siemens WM14S794GB washing machine and F23 is flashing
F:23 means that your machine is leaking and should be repaired. This is often a bad seal and if you are competent or know a friend who is they can inspect the source of the leak for you. Needless to say you should make sure that you unplug your machine before attempting any repairs.
Hope this helps you.
SOURCE: getting FE error on our
I suspect that stands for 'Filter Error' so I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Testimonial: "I can only say a big Thank You for your kind help and prompt assiistance..it s a flter problem and cleared it off..back to working..Thanks a ton John."
SOURCE: the error F23
This error occurs when heater fails in the unit .
Try this
Hope this helps .
SOURCE: code f23 for whirlpool washing machine
It means that there is a fault in the heating circuit and the heater is not working
The listed site deals with this problem so take a look and if you are fully capable of testing, follow the troubleshooting instructions but always double check that the unit is unplugged or disconnected from the electrical supply.
http://www.assuredparts.com/WhirlpoolDuetWasherFaultCodes.html
And remember kindergarten rule #1 "If in doubt, don't" with everything that is potentially dangerous. Electricity kills so a service repair bill may be a better solution.
Hope this helps.
jenni.
SOURCE: Getting faulf code F06 on Whirlpool 6th Sense AWM 8143
Hi There
I have found what you looking for and i hope this help's yo. let me know.
F/06
Drive
Motor Tachometer Error
The
control is unable to properly detect motor speed and the
machine will shut down. If a failure occurs during high-speed
spin, the door will be unlocked after 3 minutes.
Thank you for writing to fix ya.
Best regards Richard
