Question about Stanley Black & Decker Stanley Bc1509 15 Amp Battery Charger Sta-bc1509
I have a new stanley 15 amp automatic battery charger. i have hooked it to a small 12 amp ATV battery and plugged in. It is emitting a constant beeping sound. Is this normal? The box did not contain any instructions; so, I assume that you just hook it up and go....correct?
2 Suggested Answers
SOURCE: I can't find a user
Go here for the Stanley BC1509 15 AMP Battery Charger Manual:
http://www.baccusglobal.com/stanley/bc1509.php
Posted on Jul 27, 2011
How do you charge battery
A motorcycle battery should be charged with a small charger, 6 amps at most. Take the time to be sure your battery connections are clean, tight and in good shape. When charging any battery hydrogen gas is emitted, do it in a ventilated area with no open flame. Hook the negative clamp (black) of the charger to the negative (-) post of the battery, positive clamp (red) to the positive of the battery (+); plug charger in. Chargers may have a gauge that shows battery charged when needle is almost to 0. I prefer to spend a couple extra bucks and have a charger with automatic shut off to avoid over charging
Sep 28, 2014 | Motorcycles
What does flo mean
FLO indicates charger has entered FLOAT charge mode, which it does after sensing that the battery is drawing less than 1 amp or so at the highest charging voltage which is around 14.75V. The float charge voltage is between 13.2v and 13.8v. You can leave the battery connected in float mode for days or weeks for a really full charge.
Dec 18, 2013 | Stanley Black & Decker Stanley Bc1509 15...
Owners manual for stanley battery charger
whats wrong with it? if you want a manual search google.
Mar 05, 2013 | Stanley Black & Decker Stanley Bc1509 15...
Can I charge a Polaris battery at 2 amps to keep it charged?
use a small solar panel ,cheap and it will keep the battery up
Nov 09, 2011 | Stanley Black & Decker Stanley Bc1509 15...
I can't find a user manual for stanley 15 amp automatic battery charger BC1509 no matter where I look. Can you help??????
Jul 15, 2011 | Stanley Black & Decker Stanley Bc1509 15...
Just want to know what the code FLO stands for kid lost the manual
The digital display shows "FLO" to indicate that the unit is in float charge mode. The battery "fully charged" icon will display on the LCD screen and the arrows pointing to the "+" and "-" will flash. In this mode, the unit monitors the battery voltage and charges as necessary to assure the battery maintains full capacity. The unit remains in float charge mode as long as the charger is connected to the battery and plugged into a functioning AC outlet. I hope this has answered your question.
Apr 01, 2011 | Stanley Black & Decker Stanley Bc1509 15...
I purchase a stanley 450 amp battery jumper.and i woul like to know how can i plug a radio in my ice shack with this product and if so where can i purchase this.to whom this may concern thank you.
the most simple way to run the radio from a charcher is to hook radio and charger to a battery
the charger will charge battery and battery will supply constant volts to run radio
Jan 04, 2011 | Stanley Garden
We have no instructions for our charger can you please tell me how to use it?
your car battery has two connections called posts. one is negative and one is positive +. the red clamp from your charger goes to the positive terminal on the battery. the black clamp is supposed to go to ground, like an unpainted bolt but not brake lines or any kind of tube. It can be hooked to the negative or black battery connection as well. just make sure there is plenty of airflow around the battery and you should be fine. I usually do it that way and have never had a problem.. finally set your charger for 10 amps on a 12 volt battery and plug it in.
Aug 20, 2010 | Schumacher 10 Amp Fully Automatic/Manual...
12v 1.5amp fully auto, alwyas worked, hook up to battery 12v 8.5amph, alwys red light flashed, went solid while charging, then off, or flashed, and off cause was already fully charged. now red light just...
I really don't have any idea as to what you're talking about here other than a battery and maybe a charger. Seems as if you're saying that you have a 12 volt 1.5 amp automatic battery charger connected to a 12 volt, 8.5amph battery but the red light on your charger is blinking. The blinking red light indicates that the charger is not seeing a proper connection such as crossed polarity connection or simply a poor connection. You say that the battery voltage has dropped from 12.5 volts to 9.1 volts with the charger connected. If this is the case, the battery is badly discharged and the charger is not charging the battery for some reason. The charger may be bad but check the connections to make certain they are correct and good. If they are, I'd replace the charger.
Good luck
Steve
Aug 10, 2010 | Harley Davidson FXR Super Glide...
Stanley Black & Decker Stanley Bc1509 15 Amp Battery Charger Sta-bc1509 Logo
82 people viewed this question
Top Stanley Black & Decker Car Audio & Video Experts
Colin Stickland
Colin Stickland
FixUpper
Level 1 Expert
Gerhardus Stroebel
Are you a Stanley Black & Decker Car Audio and Video Expert? Answer questions, earn points and help others
