Question about HP Photosmart 3310 All-In-One InkJet Printer
HP 3310. My hinges are broken - HP Photosmart 3310 All-In-One InkJet Printer
  • Anonymous Aug 15, 2008
    When I raised the compartment to change ink cartridges I broke the hinges. How can I fix this ?
    HP 3310 AIO Photosmart Printer
  • Anonymous May 15, 2009
    My hinges also broke ink cartidge door stuck open. HP rep online chat never was able to understand problem.
    SOLUTION: open up printer using torx T10 bit. It is pretty tricky take off right side panel. Disconnect all cords, remove paper jam clean out panel in rear. Remove two silver colored screws behind this panel. Remove two black screws on rear of printer next to the hinges. This will allow the middle panel to swing down and be gently lifted back and away from the printer. You need to release the tab on the side panel underneath the open ink cartridge door. Use a putty knife or some other stiff thin metal object lift it gently and it will free the side panel. Disconnect the multi wire connector at rear of printer, then disconnect the three multconnector ribbons noting where they connect. You will replace them in the opposite order. The entire scanner can now be removed (also a little tricky). With the ink cartidge door open (I assume you can't close it yet), push the outermst piece or end of the hinges uptowards the scanner deck (This is hard - the part is stiff) while this tab is pushed in slide the scanner up off of the hinge. TIP: Stand the whole printer on its left side (the printer is now perpindicular to your work area) this will take the weight off of the hinges.
    Now with the jammed hinges uncovered, you will find a screw under the front side of the lid hinge. The hinge is slotted so you can reach through it with your Torx bit. Remove the hinge (it now just lifts out) Pull the hinge pin out and take out the black piece of plastic. Do this for both hinges. Just get rid of the worn out plastic piece (it hardly looks worn, and you might as well take the springs out too. Put the hinge together without the spring and the plastic part.
    Now reassemble the whole thing. Your printer should work fine, but you will need to prop the thing open to change cartridges in the future.
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
Posted by fmoo on May 15, 2009 My hinges also broke ink cartidge door stuck open. HP rep online chat never was able to understand problem.
Posted on May 15, 2009
  • Peter Nause
    Peter Nause Sep 13, 2016
    Thanks so much for this GREAT advice - I have a HP 3310 All-In-One that I purchased way back in 2005 in which the hinges got stuck open when servicing the print cartridges. I use the unit mostly as a scanner & it performs fine - I hated that I should have to trash it because of the 'simple' physical malfunction of the 2 hinges. I followed the process described above, got inside the thing, removed the heavy duty springs from inside the hinge casings, reassembled the parts, managed to get the 3 "multconnect" ribbons back into their slots, panels on and everything fired up just fine - back in business! A small victory but very satisfying nonetheless - very grateful!
    Peter / Madison Wisconsin
Simple fix ! IF your cables have come out because the hinges broke, then cut out using a scriber or a box cutter an L shape section of plastic about 50 x 30mm next to the rear left hand hinge to expose the connectors inside. This will allow you to reconnect then later using some pointy nose plyers. OR you could take the whole thing to bits for this... Next, use a 4mm drill and looking at the rear of the unit. Drill * 2 holes [*' '*] near the top of the grey plastic section that covers the spring housings and about 10mm down from the top and 22mm wide spacing. Okay, that's about 135mm up from the bottom of the printer. Do the same for the other side. Get some 1.8 mm wire or similar and bend it into an L shape, 8mm x about 50mm long, make 4 pieces. Poke the 8m bend in one of the holes and slide it between and around the black spring housing and curl it around so that the hook goes into the hole where the hinge pin use to be. The whole principle is to pull the hinge down and back a bit using the wire hooks. Do all 4 the same. Using plyers again, bend the wires that stick out of the back of the printer at 90 degrees to each other [__] and cut them short so that the ends overlap each other. I use a dop of superglue to fix this into position but other than that, connect the cables up and a dop of glue for the piece you cut out earlier... back in again. That's be careful to open the lid to change ink, mabe prop it up using a biro or similar.. 11-7-2013 Rgs Michael L
Posted on Jul 11, 2013
Before going to the extremes of taking the printer apart. Spray a small amount of WD40 or silicone along the horizontal joint on the hinge that is just above the star bolt that is situated directly in front of the hinge. allow this to penetrate then work the lid slowly up and down, at first it will creak a little but eventually it will reduce the friction between the spring loaded wedge in the bottom part of the hinge and the camb the forms the bottom part of the top hinge.
Posted on Jan 12, 2010
3 Suggested Answers
SOURCE:
Inkworks
  • 98 Answers
SOURCE: HP PHOTOSMART 3310
We have parts machines..
Inkworks
866-381-0541
Posted on Feb 10, 2009
FixinFax
  • 3085 Answers
SOURCE: Please what is the part number for the left hinge
C9143-60101 ADF
C9124-60117 Flatbed lid
Not available as a part. You will have to buy the entire assembly.
Posted on Apr 12, 2010
I changed a printer cartridge and the lid is stuck open. HP 3310 Photosmart. I did reseat the cartridge I changed to no avail. I am most curious how this can be fixed without forcing the lid down. Thank...
hello, well, you can take off the right cover, with printer unplugged, and disconnect cables that connect to the scanner top cover area. the hinges have press lock that will require you to press up, and slide towards the front and lifting up at same time. the scanner will come off, using #10 torq bit, take hinges out of machine, if you some white grease or light weight lithium oil, use it in and around the actual hinge area, basicly what your working against is plastic on plastic, with a powerful spring, so do this carefully and try not to pinch your fingers, it hurts alot. try slowly to open and close hinge slowly, if it does not move freely, don't force or it will break, that spring used is under alot of pressure, so do it slowly, lube and try to move, lube and try to move. when it works smoothly put back together
Oct 12, 2010 | HP Photosmart 3310 Printer
Please what is the part number for the left hinge on the HP All in One 3310 Printer/copier
C9143-60101 ADF
Apr 12, 2010 | HP Office Equipment & Supplies
I cant close the lid of my
Same thing happened to my printer last night (never happened before) and I too am looking for some release latch....so frustrating and I don't want to force it closed...
Nov 10, 2009 | HP Photosmart 3310 Printer
The lid to my hp 3310 is stuck open.
Check back by the hinges there should be a catch that locks the lid up just release the catch. If yours does not have this check to make sure you don't have to lift up again to release the lid. These are the only problems with that type of printer that I've seen, I hope this helps if not let me know and I'll do some research and try to find an answer for you. Good luck.
Sep 25, 2009 | HP Photosmart 3310 Printer
HP PHOTOSMART 3310
Inkworks
866-381-0541
Jan 27, 2009 | HP Photosmart 3310 Printer
HP 3310 Photosmart AIO
Try this bellow link if it is of any help for you:
http://partsurfer.hp.com/cgi-bin/spi/main
Good Luck
Aug 19, 2008 | HP Photosmart 3310 Printer
Access Door won't close. Used some force and both hinges broke !
not really..that's a service level repair that takes around 1.5 hours with the right tools
Aug 01, 2008 | HP Photosmart 3310 Printer
Access door will not closwe.
I have the same problem and found it's a broken right back hinge. The plastic that holds the pin in place is broken and the spring underneath is preventing the access door from closing properly. Unfortunately, I had to take it apart to see it. If hp (or any other computer company) stocked these cheap parts, they couldn't make money selling disposable computer products...sad but true. I'll be looking for a cheap 3310 for replacement parts for mine...
Jul 24, 2008 | HP Photosmart 3310 Printer
Door is open and wont close
Hi HP-Friends! I had the same problem and read through the post.
I decided to take the whole thing apart and removed the hinge (w/ some difficulty) I inspected the hing and took it apart. Realizing that the spring got too much pressure. I cut it down about a 1/4 of an inch and so far so good. I then broke one hinge when I put this thing together but it work fine at the end. You just have to be carefull opening the door. The hinge has no mechanical value other than it makes it easier to open the door. I am o.k with that as I only open that from time to time to change the printer. -- I tested it all afterwards and its just fine.
Frank
Austin, Texas
Jun 26, 2008 | HP Photosmart 3310 Printer
Unable to close Lid
Sounds like the hing on back is broken. Look on the back of the cover, there will be 2 hinges holding the scanner on. Probably a piece of plactic broke and is hanging up one of the hinges.
Possibly a small spring.
Feb 28, 2008 | HP Photosmart 3310 Printer
HP Photosmart 3310 All-In-One InkJet Printer Logo
871 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
