Question about Vacuums
I need to know if it has a reset button. we had a power outage and it has stopped working since than. cant find a button to reset it.
  • 1,056 Answers
Vacuum cleaners do not have reset buttons instead it would have a thermal protection breaker integrated within the motor if the motor overloads it will shut off but will start again as it cools down.Check to make sure the outlet has power in it first. Vacuum cleaners are usually reliable since they are not subjected to prolonged use unless it is used in commercial environment, but a common problem with it is a bad internal connection usually around the motor area due to vibration.
Posted on May 24, 2011
Is there a fuse or a reset button on a Ryobi 10 inch surface planer. My planer stopped working after getting too hot. Now, it won't even trn on....
check the motor for a thermal over load button
to stop it over heating take more lighter cuts as the motor is a small motor compared to what the cut can be
May 09, 2016 | Ryobi Planer. 15 Amp 13 in. Planer AP1301
Power nozzle does not work. Light comes on on power nozzle but it does not vacuum
Many early version PN-2E power nozzles have reset buttons that are becoming faulty. The factory stopped adding the rest button to this model power nozzle so you can update your unit by removing and this my solve your issue. You have the trigger to stop the motor if you have an issue so the rest button has become unnecessary.
Mar 28, 2015 | Rainbow E series Canister Wet/Dry Vacuum
After a brief power outage my Marantec 4700 garage door opener has problems opening/closing. When opening it stops at the fully open position and the lights blink, when closing it automatically reverses...
This is not a sensor issue, I have a similar problem, sensors work fine, garage door is still fully functional, all operations, including safety sensors work properly, just the overhead lights flash. I suspect there was damage to the power board due to a power surge, going to order a replacement to see if it works, will let you know how it goes.
May 14, 2011 | Vacuums
No power, does units have a reset?
Hi Troy. I need to know the make and model of the vacuum and what you were doing when the machine stopped. Most have a reset button. Also most hyave a heat sensor in motor. If the vac. feels hot or was labouring ( motor winds up } it may have shut down to avoid burning out motor. Check for any clogs in machine , hose and power head if it has one. Hope this helps. Chris
Feb 09, 2011 | Vacuums
I was vacuuming under my dresser using the large power head and I bumped the power head against the dresser and it stopped working.
If it doesn't work after depressing the reset button, a wire in the power nozzle may have been knocked loose. If that's the case, it will need to be taken to an authorized Aerus Electrolux store for repair.
Jan 27, 2011 | Electrolux Guardian Bagged Canister Vacuum
The brush is not working when I turn the power on and the belt appears to be on and intact. How do I fix it?
This is actually a bad design by Bissell. Remove the Lift-Off portion of your vacuum cleaner. Down at the bottom, where the Lift-Off portion was sitting, you should see a small electrical plug part. What usually happens is this plug arc's, which causes it to burn the plug, and stop the power nozzle from spinning. If you see any black, or burning around this plug, take your vacuum back into Bissell, they will fix this, or give you a new vacuum for free. They don't even sell us their warranty stations this plug piece, you can only exchange it for a new vacuum.
If this is not burned, check the reset button for the brush, it's either located near the plug, or on the side of the brush portion of the vacuum.
I hope this was helpful to you.
Chris Jones
goVacuum.com
Jan 08, 2011 | Bissell LiftOff Revolution Pet Vac 37602...
Stop working. brush was cloged. It there a reset button?
i had a similar thing happen and just got off the phone with dyson. there is a resettable switch on the handle. they told me to start the vacuum in the upright position, put it in the non upright position, then push and hold in the beater bar switch which is located next to the on/off button for 10 seconds and the beater bar should start to function once again
Jul 15, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
THe power head on my canister stopped working
depending on what make ... the power head has one or two thermal switches insiide ... the first one detects when the motor gets too hot .. thats almost always caused by "not enough air flow to keep it cool" ... that switch will reset when the motor cools off ... if that thermal switch fails to work and the motor continues to get hot then a perminant thermal fuse trips ... that cant be reset and has to be replaced ... and thats not always easy to do . they are typically crimped or soldered in place within the motor windings .... usually the motor will be replaced on such units ...vacuum motors operate at enormous power levels .. they get very hot very quickly when air flow is cut off .. another posibility is the wires going inside the plug get broken from so mjuch flexing ... you can try pushing the wire into the plug to see if that brings it to life ,,, the wires sometimes break where they go into the motor also . some machines have a little reset button near the motor .. if you have that then push in for a couple of seconds .. it should click when reset .. ..
Apr 15, 2010 | Vacuums
Electrolux powernozzle not working
mine was the power head neck itself the handle got twisted to far and broke the wire a new neck cost 37 bucks online and i installed it myself wires get attached color to color and screw the head back together. it worked just like new!
Mar 18, 2009 | Electrolux Centralux Vacuum
Vacuums Logo
237 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
