Question about Gateway NV53A24u Laptop
Many broken key hinges, so got a new keyboarrd. Cant figure out how to pull this keyboard out and replace, laptop is different and way more difficult from what ive ever seen. Seems i may have to pull the faceplate off to replace.
    Guru:
  • 811 Answers
There are a series of screws the main one most folks miss is the ones under the battery there usually is three of then and one or two keyboard screws underneath you will have to take one of the covers off where the CPU and battery is located there will be one there, The battery for the main charger not the CPU battery it will have just 3 or two screws remove that, I hope that this assisted you, thanks for using FixYa! John
Posted on May 24, 2011
My keyboard wont type
Restore a Laptop Keyboard b> When a keyboard stops working, has odd key letters, stuck keys and non-functioning keys for no reason at all, the laptop may have an easy fix solution. However, if liquid spilled on the laptop or the laptop was dropped and as, a consequence, the keyboard doesn't work, or the keyboard device has simply failed, fixing the problem may require a more involved laptop keyboard replacement.
Click start control panel keyboard hardware make sure you have the right keyboard selected or you might have uninstall the keyboard then restart your computer then reinstall it and its drivers Click start control panel administrative tools computer management device manager scroll to keyboard you might see a yellow question /exclamation mark ? ! or a red X right click update driver if your computer came with a motherboard disk the drivers could be on it. If its still not working Tap the "Alt" and "Shift" keys simultaneously if you are pressing one keyboard key and getting a different symbol or letter. This will reset the keyboard defaults on some laptops. Press the "Ctrl" key and tap the "Shift" key simultaneously if the procedure in Step 1 did not work. Press the "Fn" and one of the "F" keys to disable the "Num Lock." Different laptops use different "F" keys to disable the "Num Lock." Toggle each "F" key and press the "Fn" key at the same time to find the right key combination. Check your laptop manual to find the right key combination. Press the "Fn" key and the blue "NumLock" key simultaneously if the keyboard is typing numbers instead of letters or wrong letter keys and the above steps did not solve the problem. b> Keyboard Maintenance b> Blow compressed air in the cracks and crevices of the laptop keyboard. Sometimes dust and debris can cause keys to lock, making such keys non-functional. Disconnect the laptop from the power outlet and remove the battery. Make the tip of a cotton swab as thin as possible by rolling it between your finger tips. Dip the thinned cotton swab in rubbing alcohol and clean the crevices of the keyboard with the cotton swab. Continue cleaning between each key of the keyboard with the alcohol-dipped cotton swab. Use a new cotton swab whenever necessary. Slightly tip up one side of the laptop so dust will move from under the keys to the crevices so you can clean. Blow compressed air into the keyboard again as you did in Step 1 of Section 2. Reconnect the computer to the power and check to see if the issue is resolved. Insert the flat edge of a flat-blade precision screwdriver under a keyboard key and gently pry it up and off. Remember where the keys go, so you can easily replace them. Remove three keys at a time and clean with a cotton swab dipped in alcohol. Replace the keys and remove the next three. Do this until the entire keyboard has been cleaned. Disconnect the laptop from the power outlet and remove the battery again. Turn the computer so the rear is facing you. Remove the screws that hold the plastic hinges in place. Insert a small flat-blade precision screwdriver in the plastic hinge seam and pry the hinges up. Turn the computer back face forward and open the screen as far back as it will go. Continue lifting the plastic hinge and power plate until it comes off. Remove the screws you see holding the keyboard with a precision Phillips screwdriver. Blow compressed air under the keyboard. Lift the cable connector levers slightly and remove the data cable. Clean the cable pins with an alcohol-dipped cotton swab. Replace everything, power on the computer and try the keyboard again to see if the issue is resolved. b> Keyboard Replacement b> Connect an external keyboard to the USB port on the laptop and verify its working condition. Disconnect the external keyboard and verify that the keys on the laptop are still inoperable. Disconnect the laptop from the power outlet and remove the battery. Remove the laptop keyboard as you did in Step 3 of Section 2 by removing the plastic hinge and power button plate, the keyboard screws and disconnecting the data cable from the motherboard connector. Replace the keyboard with a new laptop keyboard for your laptop make and model.
b>
Jan 11, 2013 | Samsung N145 Plus 10.1 inch Netbook -...
The letter 'r' and 't' has come off our laptop how do I put them back on?
The keys on the modern day laptop as placed on hinges, and that's how they keep coming up when we press them down.
The problem is, if the keys come out of the keyboard, then we need to check whether that hinge is broken or not. If it's broken, then you need to contact your local Computer Engineer who can fix this for you, as helping you in this medium won't resolve the issue.
If it's not broken, then I would suggest you to carefully see how the mechanism of the keyboard is on your laptop, and place the hinge back on the keyboard.
One more small tip, if neither of them works, then use some permanent glue and try to stick the keys on the keyboard. Though I would recommend this only as a last resort.
Let me know how it goes.
-Pragith
Mar 11, 2011 | Acer Computers & Internet
Need to replace broken key on keybord. plastic appartus on key underside broke
Remove sticky tape securing the keyboard cable to back of the keyboard.Part of the keyboard cable is glued to the keyboard. Carefully separate the cable from the keyboard.Start peeling off the aluminum protective film Remove the protective film. After the protective film is removed it's really hard to attach it back to the keyboard because it's deformed.Most laptop keyboards have some kind of plastic separators.
These separators secured on the back of the keyboard.
Plastic pins are melted on the back of the keyboard and retain separators in place.Push all plastic pins though wholes on the keyboard.Start removing the separator.The plastic separator has been removed.
Now you'll have to remove all key caps.
Before you start removing key caps, make a picture or xerocopy of the keyboard so you know the order in which keys are attached to the keyboard.In order to remove the key cap carefully lift it up with your fingers.Remove the key cap so the hinge underneath stays connected to the keyboard.
Some big keys have a different design.
In addition to the hinge, some big keys (Back space or Space bar for example) might have an additional support bracket.Remove the key cap with the support bracket. As you see, the key hinge stays connected to the keyboard.Some laptop keyboards might have blank covers on the left and right sides from the up arrow key.Lift up and remove the blank cover.All keyboard key caps and plastic separators have been removed.Now you can start removing key hinges - key lifting mechanisms.Carefully separate the key hinge from the keyboard.
Each key hinge has two parts - external and internal pieces.
When you remove the hinge, try to keep these parts connected to each other the same way they are connected on the keyboard.If the external and internal pieces got separated, you can assemble them together.If you following this guide to repair the keyboard, I would recommend to keep all hinges in the right order.
The keyboard has two sheets laying one on the top of another.
Remove the sheet with silicone (or rubber) nipples.Remove the second sheet with traces.Both sheets have been separated from the keyboard base.The sheet with traces has two layers and all traces are running between these layers.In order to access and repair traces you'll have to separate to layers from each other.The keyboard has been disassemble.
As you see it's not easy to disassemble a laptop keyboard and even harder to put it back together.
Is it worth repairing? Probably not. These days you can find a new laptop keyboard very cheap.
Oct 17, 2010 | HP Pavilion ZD7140US Notebook
Where can i find replacement hinge clips for my keyboard keys that were pulled off by my 2year old. It's an older systemax laptop but it worked well. I was able to replace several but some of the clips...
The good thing with an older model laptop is you will be able to get spares cheaply from ebay, and other less well known auction sites, i do not know what model your systemax is but just fould a few laptops for breaking
http://cgi.ebay.co.uk/SYSTEMAX-8170-LAPTOP-keyboard-WORKS-NEED-QUICK-/130404269972?cmd=ViewItem&pt=UK_Computing_ComputerComponents_KeyboardsMice&hash=item1e5cb33f94
Its a good probability that the hinge clips will fit even if its not the same model, all about cost reduction for any manufacturer.
Mar 15, 2010 | Logitech diNovo Edge 9676850403 Keyboard
How to replace a key that popped off
Ichand1958 is right, if its broken the no matter what you do it will not go on, but if he thinks installing a key is difficult, how you think the average user will be able to take apart the entire laptop to install a keyboard?? I think you should first try just fixing the key, often the new key will just snap right on. Have a look at http://www.individualkeys.com/ACER_KEYS/ and if that does not help, THEN take the laptop to a shop and have them install the ENTIRE keyboard.
Jan 25, 2010 | Acer NSK8458AN Keyboard
Replacing the keyboard
your only supposed to pull the hinge out carefully a small amount so the flex cable comes loose, then insert the new keyboards connector there and push them back into place. Its pretty much the same thing in all brands of laptops.
if you have broken the connector, you will probably be looking at buying a new motherboard unless you find someone to replace the broken connector.
Oct 11, 2009 | HP Compaq Presario R4000 Notebook
The i key won't work
Faulty keys on keyboards are very difficult to fix, usually you need to replace the keyboard.
You can try removing the key and if you can get to the rubber membrane switch you may be able to use a cotton bud with electronic cleaning fluid cleaner on the contacts. Replacing the key could be difficult with the small plastic hinge components.
If you are lucky place the key over the plastic hinge and pressing down till it clicks into place.
If it works you are in luck, if you are unlucky it may not work at all, then you need to buy a replacement keyboard or use a USB keyboard with your laptop.
Jun 28, 2009 | Sony VAIO PCG-K25 Notebook
How do i replace the keyboard on a dell inspiron 1525
How to Install a Replacement Keyboard on Dell Inspiron 1525 Laptop Computer You may need:
  • New keyboard
  • Screwdriver
---Be careful to not break off any of the plastic tabs on the keys as they are difficult to replace.---
  1. Turn the computer off and slide the tip of the screwdriver in the notch on the right side of the hinge cover (the plastic section above the keyboard). Slide the hinge cover up and remove it from the computer, exposing a series of bolts. Unscrew the bolts and remove them.
  2. Pull up on the edge of the keyboard and slide it forward toward the display. Slide the keyboard all the way out of the computer case slowly.
  3. Unhook the flex cable from the computer board to disconnect it from the computer.
  4. Slide the new keyboard into place, connecting the flex cable first.
  5. Screw down the edge of the keyboard with the 4 bolts from before and replace the key cover.
  6. Power up the computer and see how your new keyboard works!
May 01, 2009 | Dell Inspiron 1525 Notebook
How do I replace a broken and stuck key.
Most keyboards can be popped out by pulling them straight out and replacing them by pushing them straight in. If you have several sticky keys, you are better off just buying a new keyboard and replace the entire thing. follow the instructions on the owner's manuel how to remove the keyboard on your machine as they are different. it usually requirer removing just a few screws either from under the machine or by removing the small face plate just below the screen..Again, all laptops are a little different.
Let me know if this helps
Apr 10, 2009 | HP Compaq nc6220 Notebook
Open Questions:
Gateway NV53A24u Laptop Logo
115 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
