Question about Behringer XENYX 2442FX Mixer
Nor realy a problem, more of a modification! I have a behringer Xenyx 2442 FX USB. I would like to convert Aux 4 to Pre-Fade as opposed to Post-Fade. Has this been done before? Where can I obtain a full schematc?
  • Behringer Master
  • 5,603 Answers
It appears there are internal jumpers that do this on the MX2642A but the schematic does NOT show these for the Xenyx2442FX. These if they existed may be push on type OR they may be ones you have to change using soldering equipment. Carefully open the unit and look on the back of the circuit board. The jumpers would have low numbers... Should be JP1 through JP24.... I have a hunch that they are not provided for your model. Here is your schematic:
http://elektrotanya.com/behringer_ub2442fx-pro_sm.pdf/download.html
Scroll down to the "Get Manual" and click on it to download. The jump[ers would be near the pre/post fade switches for AUX1 and AUX2.
Posted on May 24, 2011
Run an active subwoofer with a Xenyx 2442fx
Probably the easiest way is to run a balanced 1/4" TRS to XLR Male Interconnect Cable from one of the AUX outputs from your 2442 board.
Here's a link to an example cable: http://www.sweetwater.com/store/detail/BPBQXM20/
Good luck! :)
Dec 20, 2012 | Behringer XENYX 2442FX Mixer
Behringer XENYX 2442 FX: Turntable into CD/tape IN. CD/tape OUT connected to USB device IN. Why is there no signal from mixer to the computer?
If I read correctly, you have outputs on the Behringer (CD/Tape Out) connected to inputs on the Behringer (USB Device In). Is that correct? If so, try going from CD/Tape Out directly to the computer. If not, please explain what the "USB Device In" is.
Thanks,
Rich
Apr 30, 2012 | Music
Looking for a manual
Here:
http://www.behringer.com/assets/1622FX_P0557_M_EN.pdf
The 2442 is just an extended version of the 1622FX. The manual covers the whole series.
Aug 07, 2011 | Behringer XENYX 2442FX Mixer
Right channel gone down. xenyx 2442
Here is a schematic than is for a less number of channels (they just repeat) than yours, but is enough to fix it:
http://elektrotanya.com/behringer_xenyx_1622fx.pdf/download.html
Scroll down to the little link "Get Manual" and download it.
Mar 30, 2011 | Behringer XENYX 2442FX Mixer
I can't hear sound from my PC when I'm using the mixer. I plugged it in with the USB to the computer and tried to record using Cubase 4 LE. I seem to get sound in, but i can't hear any sounds from the...
In the "Sounds and Devices" of teh control panel under the Voice and also recording tabs amke sure the 2442 is selected instead of teh computer internal audiop system.
Feb 18, 2011 | Behringer XENYX 2442FX Mixer
I have a behringer xenyx 2442 USB and can not get the sound to my daw. I can see and hear sound from the desk so I believe that side of things is ok. I've gone to setup devices and selected behringer usb...
First thing to check is look in the Windows Control Panel at the the "Sounds and Devices" and verify that the 2442USB IS the device for both input and output instead of the usual PC audio devices. You should see a pulldown list including both for those... If not, your SW driver is NOT loaded properly.
Dec 26, 2010 | Behringer Xenyx X2442USB / Harbinger...
How do i hook up a powered moniter to the behringer xenyx 2442fx mixer?
hook it up to one of the aux output sends (1 or 2), and use the corresponding aux send knob per channel to put each channel necesarry into the monitor signal.
Nov 20, 2010 | Behringer XENYX 2442FX Mixer
I have a behringer xenyx 2442 and the main output fader no longer works. Each individual channel fader now seems to go direct to the main mix and appears to bypass the main fader
The utput fader has probably been broken. If the knob takes a hit, it breaks the resistance element. The part is inexpensive but it takes a lot of work to access and replace the part.
Oct 14, 2009 | Behringer Xenyx 1002fx Mixer 10 Input 2...
I have the 2442 fx behringer ''XENYX'' mixing console, and while trying to operate channels 13/14 and 15/16 (these are both stereo channels with mono capabilities, and do not have XLR inputs) I only get...
Check you assign buttons and bottom (three black square buttons) and play with them. It sounds as if you are not sending to that side. You should use mono cables into left and right. I set pan on left all the way left and right, all the way right. Hope this helps.
Jul 06, 2009 | Music
Behringer XENYX 2442FX Mixer Logo
121 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Are you a Behringer Music Expert? Answer questions, earn points and help others
