Question about Weather King Heating & Cooling
NEED TO REPLACE FAN MOTOR ON MODEL 10AJB24A01 MOTOR PART # IS K55HXLAJ-9880 WHERE DO I GO TO ORDER
2 Suggested Answers
timblodgett
  • 691 Answers
SOURCE: I need to know what size run capacitor for compressor I need on a Weather King model 10AJB24A01?
You can see a pic at the web address provided. The number is located on the old capacitor and frequently a replacement will not have an exact fit that requires you to modify the space it rests in. The updated part number is
43-25135-16 it is a 3/30 Mfd capacitor. 30 3 Mfd 370V Oval Capacitor 43 25135 16
Posted on Sep 16, 2015
Sep 16, 2015 | Weather King Heating & Cooling
How do I change the fan in my riccar vacummn?
It depends on which model you have. Most models have a fan that will never need replaced. Tandem air and Supralight models have a fan that could be damaged on older models but is unlikely on newer models as fan are now made from a flexible material. Remove the motor assembly and disassemble to get to the fan. Remove the nut from. The shaft and remove the fan. Install new fan and put back together in reverse order as it was taken apart.
Feb 28, 2015 | Riccar Vacuums
How to fix printer blurr
most likely you're wiper for the capping station is covered in ink. I recommend having the printer cleaned by someone who does maintenance on Epson printers.
Mar 21, 2014 | Epson 9880 stylus pro Printer
Instal capacitor on Rudd 10Ajb24a01
Hi, this is a 2 ton unit from the numbers you have provided. I'm not sure what you are asking about the capacitor?? If you are installing the run capacitor, is it for the compressor/outdoor fan motor? I can't tell you how without looking at the schematics on the unit. Its pretty simple though. If you know its bad, you may have to purchase one online. You have to be a contractor in the hvac field to get one at a wholesale store. If its a dual run capacitor, it will have a c, fan, and herm stamped on top. This is for the compressor and outdoor fan motor. It will say something like this, ( 30mfdx5mfdx370 volts and so on. The 2 brown wires on the condenser fan motor will go one taped off and the other on the fan terminal if you are using a dual cap. If you are using a single 5 mfd or larger on a new motor, both brown wires will go to each side of cap. I will need more details if this is not what you need. Thanks
Shastalaker7
H,V,A.C. contractor
Ps, Send me more information on what you need?
Mar 19, 2012 | Heating & Cooling
The fan is not working, what should I do?
there two fans 1 inside the freezer and other down by the compressor . both are not hard to replace but do order it by model and ser # because there are ac and dc motors an cw and ccw motor. and they all look the same . some are 9 to 12 volts and 110 v . so do order the correct motor . for your model . if more help is needed need model & ser # of your unit .. mm feed back pls ..
Dec 11, 2010 | KitchenAid (KSRD22FKST) Side by Side...
Can not find motor for LS100SE . ref p/n 62345000 given by Nutone
Packard Electric Motor Company model # 65345 is a direct replacement motor for the nutone LS100SE. It can be ordered from Conrey Electric Inc in Portland OR.
Aug 13, 2010 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
Brother MFC 9880 error 71
error 71 indicates problem with the laser unit motor.. 80% is the motor problem and 20% could be the LVPS board... make sure all the cover and interlock switch are close properly.. as any interlock switch which are not close properly will effect the voltage to the motor..
May 28, 2010 | Brother MFC 9880 All-In-One Laser Printer
I NEED A CONDENSER FAN MOTOR WITH BLADE AND
cna't find your model with this # reck model # ser # there is no problem getting the parts for whrlpool . the motor and fan are normal service parts but the mounting bracket would have to be ordered . as the do not ware out . ****..
Dec 23, 2009 | Refrigerators
Fan not working
Yes the bearings in the fan motor are bad you get at an a/c supply house for $ 150 to $200
Oct 06, 2008 | Friedrich SL24J30 Air Conditioner
Heating & Cooling Logo
644 people viewed this question
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
acrman404a
Level 1 Expert
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
