Question about Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl
Think my young son put somthing down the toilet filled up with watre wont flush but hums intermitently
    Scholar:
  • Saniflo Expert
  • 115 Answers
Definitely there is an obstruction on the blade or impeller inside the pump casing. Pry open the lid using a flat head screwdriver and remove the motor with pressure chamber out of the pump csing as one piece. Once the motor is out inspect the blade (on top of motor) and the impeller which is at the bottom of the motor. Also the starting capacitor may have seized up. If the capacitor goes bad it tend to hum and not pump any waste out.
Posted on Jul 13, 2011
How can I adjust the waterflow to a lower setting to make it 1.2 gallon flush from a 1989 3.5 gallon flush??
Keep in mind that if you limit the amount of water too much, the 3.5 gallon toilet will not flush properly.
This looks like an old Kohler Rialto toilet. The proper way to adjust the water level is to tighten down on the adjustment screw located on the very top of the fill valve. The fill valve is the the piece that the float ball screws into on the left side of the tank.
Tighten the screw down and flush the toilet. Wait for it to refill, and check the level. If you need less water, tighten again, let fill and check level.
There are also two old school methods to save water in your toilet. One is to put one or two bricks into your toilet tank. This reduces the amount of water that fills the tank. The second method is if the fill valve has a float ball on a metal rod, you can bend this rod down into the water. This makes the fill valve shut sooner. Don't bend too far or too fast because the chlorine in the water weakens the brass rod that the float ball attaches to.
Nov 29, 2016 | Home
MY TOILET WILL FLUSH BUT WONT FILL I CLEANED FLUSH VALVE AND VALVE HAS PRESSURE BUT WONT FILL TANK PLEASE HELP
Make sure the flapper is seating properly. If you can't tell, put some food coloring in the tank part... you will see color in the bowl.
Nov 02, 2014 | Danco Plastic Relief Valve Repair
I had the same issue wit my champion toilet the issue was finally resolved by using a plastic drain snake and cleaning out the flush tube at bottom of drain (1" hole at bottom of drain facing toward front of toilet) mine was restricted down to 1/2" "bad casting I think"
May 14, 2014 | American Standard Cadet 3 FloWise...
Toilet wont flush
Main 3 (or 4) inch drain under the toilet is clogged. Requires removing the toilet and running a "snake" down the pipe. Alternately, you can (carefully) try manually filling the toilet bowl all the way to the top----to apply pressure to the clog....it may push it through.
Mar 04, 2014 | Home
Toilet wont flush
Here is a nice link for your saniflow maintenance.
http://www.plumbteamltd.co.uk/sanifloguide.html
This will may help.
Oct 22, 2012 | Saniflo Sanicompact 48 - One Piece Toilet...
I just bought a new kohler cimmaron biscuit 2 peice tiolet. it is installed correctly. every so often i hear the water running for a few seconds then it shuts off like its losing water and refilling. i...
check fill tube from the fill valve to the flush valve, if the end of the hose is close to the watr level it will back syphon.... recommend also putting in better inner components.. fluild master 400 a fill valve and a nice red korky flapper
Sep 02, 2010 | Kohler Cimarron 2-PC Elongated Toilet with...
TOILET WONT FLUSH AWAY PROPERLY
I believe what your plumber was referring to are the flushing orifices. Yes they have changed through the years. Unless you have a pressure assisted toilet, the orifices are what makes it flush, by breaking the trap seal and creating a vacuum. Now that being said you can check to see if this is the problem by filling up a bucket with aprox. 2 gallons of water and dumping it straight into the bowl. It should flush right down with out hesitation. If it does then your orifices are not working properly. If this is a new stool, it is possible it is just a bad mold and should be replaced. I hope this helps. Your new toilet should flush for you.
May 08, 2010 | Home
Igenium Flushing valve will not shut off.
THE WHITE PIECE IS LOCKED IN YOU MUST PUSH DOWN AND TURN A HALF OF TURN .THEN LIFT IT OUT,DON'T DAMAGE YOUR O RING
Apr 05, 2010 | Kohler K-3422 - Wellworth Elongated...
Grinding motor will not stop
my son put a wet wipe down the toilet, now it makes a loud grinding noise when flushed
Oct 07, 2009 | Saniflo SaniPlus-Round SaniPlus Macerator...
Need instructions and Switch for twyford close coupled cistern
i presume with lid of u can flush toilet by pusshing switch with finger if so buttons must be spot on when replacing lid can be adjusted inside systern any probs get back
May 07, 2009 | Toto CST414M-51 Aquia Dual Flush Close...
Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl Logo
239 people viewed this question
Top Saniflo Home Experts
Paul Carew
Donni Steen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
