Question about Lexmark Office Equipment & Supplies
Copies are coming out with black ink spots all over them, changed ink cartridge, how do you clean it?
    Sergeant:
  • 167 Answers
Clean the drum of a toner, or the tuner is low
Posted on May 24, 2011
Copies of documents are not clear
Spots on copying: Chk is there any marks on flat bed glass?,clean flat bed glass with wet cotton cloth, allow it for dry.
Spots on printing: There is no particular reason for this issue. clean paper path with wet cotton cloth & allow for dry..
Mar 18, 2013 | HP Deskjet 2050 All-in-One Printer
When copying the page comes out SOAKED in black ink
The cartridge or Toner is splitting out more ink.... Remove the cartridge Clean it and place it again.
Oct 30, 2012 | HP Office Equipment & Supplies
Won't print or copy (looks like it's out of ink or cartridge is jammed)
if you have the program of printer install to your comp ? then run the maintenance program , that will CLEAN , ALIGN , AND PRINT A TEST PAPER , AJ
May 08, 2009 | HP OfficeJet R80xi All-In-One InkJet...
Generic black ink cartridge causing black ink to not print
Never mix dye and pigment inks/machines Head could be screwed Try copying many black text only pages up to 200 but run head clean after 50 or so Inkypete
Apr 20, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Red will only print on test page.
So what you need to do is clean the cartridge from the printer toolbox..do all the three steps cleaning..(clean cartridge,prime cleaning,intermediate cleaning)..
once the cleaning is done..try to make a copy..if its still the same..change both the ink cartridge and then try to make a copy..if it resolves the issue then cartridge is defective..if it does not resolve the issue then printer is defective..
Mar 09, 2009 | HP DeskJet F380 All-In-One Printer
How can I get the fax and copy to print clearly?
Still sounds like a bad ink cartridge, try cleaning the bottom of the cartridge with a Kleenex and soapy water. Dry it off real good.
Look where the cartridge sits and clean the same way.
Ink jets are dead technology.
Nov 11, 2008 | HP 640 Inkjet Fax Machine
Copies come out with splotches
replace the drum. take out toners and clean inside real good. check your exit rollers to see if they have any ink on them. be sure you use genuine hp products.
Jun 26, 2008 | HP LaserJet 2840 All-In-One Printer
Hp Photosmart 3110
I have changed the BLACK cartridge ( as suggested ) but still cannpt print or move breyond the PROBLEM Note that comes up to CHANGE the Yellow and Black Cartridge - I cannot SCAN or COPY leave alone PRINT - please suggest a solution - Thanks ,
Adrian
May 14, 2008 | HP PSC 2210 All-In-One InkJet Printer
I have changed the black ink cartridge and my lexmark 125 keeps telling me to change the black ink cartridgeand I can not get the thing to copy for me. All it does is keep telling to change the black...
After you get the carriage centered to remove the ink, power off the printer. If you replaced the cartridge with a new cartridge check cartridge for tape residual that might be covering the copper contacts. ( you may not be able to see this).
If you use a refill kit. Most printer Mfg's insert a chip in all there ink cartridges. This chip tracks when you remove an empty cartridge through the printer software. So it knows you replaced the same cartridge forcing you to buy another.
You can also clean the copper ink cartridge contacts with some alcohol & cotton swabs. (Careful not to drip excessive alcohol onto the bottom of the cartridge). Clean the carriage contacts as well. Re-place the cartridge & try again.
Luck!
Mike
Apr 11, 2008 | Office Equipment & Supplies
Faded left hand copies
Pleas check that you inserted the K toner correctly, check, that transfer belt and/or drum cartridge is installed correctli. also check that 2transfer roller, its one big black roller.
Jan 23, 2008 | Konica Minolta magicolor 2400 Laser...
56 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
