I am working on a Sharp MX-C311 that continues to wrinkle the paper. I have replaced the fuser with the newer version, but the paper is still wrinkling. I checked technical bulletins, but none seem to be out. Any suggestions how to get the paper to stop wrinkling?
    Sergeant:
  • 167 Answers
Their is a small sheet of paper remain inside causing problem or the paper tray is not properly inserted
Posted on May 24, 2011
My sharp MX-C311 shows maintenance required Code TA
Hi, TA code refers to maintenance all counter has reached its specified limit. This usually means all the consumable parts have reached the end of their service life. If you have a maintenance contract with a Sharp dealer then they should replace all the units that require replacing & reset the maintenance counters for you, if you don't then, if the copy quality is still ok, you should be able to continue to use the machine as normal.
Hope this helps.
Dave.
Oct 15, 2017 | Sharp Office Equipment & Supplies
What shall i do to return my sharp mx-2700n copier to operation?
have you check the sensor actuates on the registration section
Oct 19, 2015 | Sharp MX-2700N Color Copier
How to fix mx-c311 error code e7-06?
The Causes
Compressed image data abnormality. HDD connection trouble when HDD is installed.try to check and see wether connectors are connected properly
. Remedy
If the job at an occurrence of an error is a FAX job, check the FAX PWB. Check connection of the MFPC PWB and the HDD. Replace the MFPC PWB.
Jul 16, 2014 | Sharp MX-C311 Primary Transfer Belt Unit
Why does my copier "rear jam" and wrinkle the paper after the fuser?
replace the fuser and check for a blockage after the fuser
Jul 11, 2014 | Sharp AL 1631 Copier
H2-01
"Press # - Interrupt - C - Interrupt -14 - Start key Thermistor open
The thermistor is open. The fusing unit is not installed.
Dec 02, 2013 | Sharp Dx-C311 Copier
Misfeed and printing prob
You need to put those levers on the fuser down so there is enough pressure to fuse the toner properly to the paper. Only put those levers up if your doing envelopes or heavy paper.
Dec 14, 2011 | Sharp MX-2300N Color Copier
My printer (Sharp MX-C311) shows an error code: L4-16. Please advise on troubleshooting procedures.
Make sure the to pressure release levers on each side of the fuser are down. Turn the machine off for a minute then back on and should be fine.
Sep 14, 2011 | Sharp MX-M350 All-In-One Printer
Printer is destroying my papers
The problem sounds like it is the FUSER. It is notorious for wrinkling paper and causing black marks. Try replacing that, and you should be fine. It's NOT your paper... just try replacing the Fuser.
Sep 15, 2009 | Office Equipment & Supplies
140 people viewed this question
jasbo
jasbo
