Question about Craftsman YT 3000 42" Kohler 22 hp Gas Powered Riding Lawn Tractor
I own a Craftsman YT 3000 mower and I am having problems with wht I think is the drive belt. The mower is 2 years old and I replaced the drive belt last year after it was slipping. The forward and reverse hydrostatic drive is either fully engaged or not at all and is very jerky when trying to engage in forward or reverse.
  • awhelan May 24, 2011
    Where is the adjustment for the F-N-R? If it is positioned in nuetral, it either wants to go forward or backwards. After it warms up (15 Min.) it starts to slip
I have the gear drive YT300o 42" 6 speed 21 HP Briges and I have lost reverse .. The whole trans is just nolonger shifting right and its only 4 years old and adult ( 63) driven. I have played and played thinking it just needed linkage adjustment but so far to no avail.. ANY IDEASW ANY ONE ?
Posted on Oct 20, 2014
  • 5,370 Answers
Check the fluid level , check the the engine pulley for wear, Check idler arm spring tension,
Disassemble the transmission and inspect the pump center section and swash plates for wear....Look for tiny scratches on the bearing surfaces, if it is worn then replace parts as needed. These hydro transmissions comes with grease in the gear box that stops working after a few years. You need to drill a hole in the top of the transmission and push about 1/3 quart of gear oil in. Then seal the hole. You can use metal tape. If the shift lever F-N-R is out of adjustment the tractor will go in and out of gear as you drive. Once it is adjusted you should stay in gear and it will run smoothly. It will leak the gear oil out various unsealed spots until it find the level below these spots. Also re check the belt alignment.If its over stretched or got loose then it can cause such problems. ----------- This should help.Thanks.Helpmech.
Posted on May 24, 2011
  • raj somaiya May 24, 2011
    This slipping problem is related to belt not tensioned properly or belt is got bit over stretched or loose.Re check the drive belt alignment. Also check the mower deck belt placement.Also see if blades are getting loose or not fitted properly.On your mower there is motion lever instead of FNR adjustment.The motion lever has to be checked, if its got loose or cracked inside.----------
    There is every thing mentioned in the manual.On page number 21 its mentioned about belt replacement and belt setting, on page number 11 and 12 the motion lever its shown.---
    To get the manual, if in case you dont have.Please click the link below:--
    This should help.thanks.Helpmech.
Why doesn't craftsman mower tractor yt 3000 charge?
If the battery is below around 11.8 volts it never will charge. The charging systems on these mowers are made to "maintain" the charge. Check the battery, if below 11.8 volts charge the battery with a battery charger. Then see if the mower will maintain the level. If not, you may have a bad battery. Your local automotive store can check it for you.
Jul 08, 2014 | Craftsman YT 3000 42" Briggs & Stratton 21...
Yt 3000 42" will not move forward or backward
Your drive belt might be off or broken (upper one) not the belt that controls the blades. There's a rod at the rear of the mower that also controls the trans-axle, if it's pulled out, the transmission is disengaged. To purge air out of the system, you pull the rod out, keep it in the out position with a pin and move the motion lever to go forward and return it to neutral several times, then do the same thing to the reverse direction. Then release the rod and return it to the very most inner position. GOOD LUCK, hope it's not a bad transaxle.
Feb 24, 2014 | Craftsman YT 3000 42" Kohler 22 hp Gas...
I have a Craftsman YT 3000 cutter. The top belt ( drive train ) belt slipped off how can i get it back on
If you could supply the number under the seat like the following I can answer your question with a diagram.4_10_2012_8_58_29_pm.jpg
Apr 10, 2012 | Craftsman YT 3000 42" Kohler 22 hp Gas...
Craftsman YT 3000 suddenly, without warning or unusual noise stopped going forward or backward
Sounds as if your drive belt has broken or slipped off pulleys.
Aug 06, 2017 | Garden
Changing belt
look at the diagrams at dixiesales.com
it will show you exactly how to route the belts.
May 14, 2011 | Craftsman YT 3000 42" Kohler 22 hp Gas...
Sears YT 3000 42" 21
oftentimes the things will not start after sitting idle all winter as last year's gasoline has turned into a lacquer which has blocked the flow of fuel through the small passages in the carburetor. there is at least one product, called Stabil, which you dump into the gas tank which precludes this. So maybe a carb rebuild and clean out is in order; and if it then works OK you should make a point to put some of that stuff in your tank at the end of the season. Works well for RVs also.
Apr 11, 2011 | Craftsman YT 3000 42" Kohler 22 hp Gas...
Blades running while the lever is disengaged
sounds like belt is to tight or the electric clutch isn't disengaging
Jun 25, 2010 | Craftsman YT 3000 42" Kohler 22 hp Gas...
Craftsman YT 3000 42" Kohler 22 hp Gas Powered Riding Lawn Tractor Logo
2,528 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
