SOURCE: GE profile refrigerator model # TBX25PR
See if ice is jammed up in the tunnel the ice is pushed through.
Will the motor turn the auger with all the ice removed.
SOURCE: Whirlpool Side by Side Ice Maker Not Making Ice
If you have the type of ice maker that has an ice bin on the freezer door, then there are instructions available at www.AnyoneCanFixIt.com to fix the ice maker problem. They also sell the part that is sometimes required to repair this common problem on the ice maker. The problem is notorious on these refrigerators that were made around 2004 and later. The ice maker will usually go out within 1-2 years. They have redesigned a part to eliminate the problem.
SOURCE: Ice maker not dumping out ice
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=GD5RHAXNQ00&siteCd=WHRCOM
Ice maker exploded view is on page 19, and parts are listed on page 2 of the parts manual. I agree, the care and use guide to be useless.
http://www.appliance411.com/
Have you tried thi site? Hope this helps and good luck.
SOURCE: Ice Maker on Whirlpool Side by Sidek stopped making ice
Go to sears.com, select "Parts Direct", enter model number and wait for unit to be displayed, find ice maker part number and price.
SOURCE: whirlpool side by side GS5SHAXN. Ice maker slowly died.
Hi agcruiser;
Have your change your water filter lately?
If not try that, as it may be starting to block up a little.
Another problem could be the water inlet valve(Ice Side) situated at bottom of fridge, that could be starting to wear (Can interchange with water side inlet valve). Yes there are 2- 1 for ice and 1 for water
The Whirlpools Ice Michine set up is very easy, and runs by a mechanical system, they can be tested (Use a qualified tech).
Cheers hope this helps
Click Here=> 4389177 Water Inlet Valve will need replaced. You mentioned the water is filling the tray OK then my focus would be on the ice maker.
Click Here=> W10190965 Ice Maker Assembly
Most times it is less expensive to just replace the ice maker module. Here is a helpful video that helps explain everything about the Whirlpool Ice Maker below. If you find this solution helpful please rate my solution, Thanks Sea Breeze
Original poster here... a reply to this post will be fine, no need for email. Sorry... newbie to this thing.
