Question about Western Digital My Passport Essential SE WDBABM7500ABK 750 GB External WDBABM7500ABK-NESN USB 2.0 Hard Drive
The computer doesnot reconigze the disk in the usb port
  • 34 Answers
Unplug your drive and then head over to:
http://support.wdc.com/product/download.asp?groupid=209&level1=&prodid=&modelno=&lang=en
and download the drivers and software for your hard drive.
Then plug in your drive and your PC should then read your drive.
Posted on May 24, 2011
When I attach a next hard disk drive it doesnot work
You need to be running Windows XP, Vista, or 7.
You will need at least 1GB of RAM and a USB port.
Your computer looks to be very slow. I think this is the reason why it does not work.
You need an OS/ Operating System. Windows etc...
Take care!
damnor01
Apr 18, 2011 | IBM Netvista Intel Pentium 4 2GHz / 256MB...
My Seagate Expansion External Drive just stop working. Whene ever I connect the power cable it making bip sound repeately several times and stop. and the drive doesnot show in My Computer. The drive is...
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Feb 21, 2011 | Seagate (ST310005EXA101RK) 1 TB USB 20...
When i pluged up my hard disk then a massage appear it hi speed hard disk in insert is non hi speed port . and window doesnot reconized it
hi friend,
it's due to the your system low speed port. your hard disk speed is not compare to your system port. port speed depend upon motherboard capacity. so, do one think if your motherboard have an option to add more usb port then, go for it. it surly fix your problem.
Regards:
Rakesh
Feb 13, 2011 | Computers & Internet
After instal a pendrive in cpu it doesnot disply in my computer & doesnot flash is working
Did you go to my computer,,thats how you open or find a flash drive,,hit my computer and it should be there removible disk,,,if not try pluging it in and restarting computer,,also try wesite of the usb to see if any updates or u may need new driver,,but I never had any flash drive do that so,,could be faulty or went bad,,tap it on a hard surface a few times ,,could free the disk,,it works eith seized hdds ,,so,,goodluck
Nov 20, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
I don`t connect with usb of PC. The USB port not reconigze it
use only the rear USB port of desktop, because by using any extension or hub there is a voltage drop so that why it is not recognisezed, only use the rear USB port and use the orignal cable or branded product USB cable, loose cable also dont work with it.
Feb 14, 2010 | SimpleTech SimpleDrive 160 GB External USB...
Connect external hard disk IBM travel star 80GB USB port 2
Unless it's windows 98 you don't need a driver. If your computer can't see it, it's probably broken. Try plugging it in to another computer and see if it can see it
Oct 01, 2009 | IBM TravelStar 40GN 40 GB Hard Drive
Usb port will not work
check your USB (Universal Serial Bus Controllers) in the Device Manager...
right click My Computer
select Manage
select Device Manager
from here you can check you USB controllers and other stuff
Mar 29, 2009 | Acer Computers & Internet
USB port is not working under windows xp sp 2
hi,
you can try the following steps.
Install the driver for the camera and the ipod as XP is preloaded with drivers for cameras for only selected models only.
Hope it helps.
Regards.
bzoy
Dec 30, 2007 | Soltek SL-915G Pro-FGR Motherboard
Western Digital My Passport Essential SE WDBABM7500ABK 750 GB External WDBABM7500ABK-NESN USB 2.0 Hard Drive Logo
403 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
