Question about A.O. Smith SQ1102 Pool Pump Motor
I havew a Jacuzzi 3/4 pump that runs for my above ground swimming pool.....it will only operate on high speed or whirlpool.........is there a way to slow it down? Sorry...newbie pool owner, here!
  • 43,501 Answers
Most of those pumps are a single speed motor. Because of that it is difficult to slow it down.
The best thing you can do is to install a valve in the outlet hose and slow the water down that way....it will not hurt the pump and if you had a meter on the wiring to the pump you would see that it will actually use LESS electricity with the valve part way shut.
That way you can easily adjust how much water is going through the pump...
heatman101
Posted on May 24, 2011
Tip
How To Connect Hook Up Use Above Ground Swimming Pool Vacuum and Hose With Sand...
<utube src="YEW-QUyP2Iw"></utube>This video will show you how to connect your above ground pool vacuum and hose to the sand filter on your swimming pool.
on Aug 03, 2013 | Pool & Spa
HOW TO WINTERIZE AQUAMATE ABOVE GROUND SWIMMING POOL PUMP
Open the plugs on the bottom front of the pump pot and on the pump housing itself. These two plugs will do the pump and just the pump. You should have simmilar plugs on the filter, heater, chlorinator and any other equiptment on the system.
Oct 13, 2010 | Hayward Sp1580x15 Power Flo Lx 1.5hp...
I Have a Jacuzzi Magnetak pump. I do not know the horse power. 115 volt, 12.4 amps, 3450 rpm. It is attached to a DE filter sstem. The pump is at least 6 years old. It runs well and pumps well for 1-3...
The earth filter is in need of a good cleaning. You may even need to acid wash it. Welcome to the high-maintenance draw-backs of a DE filter! Once cleared your system should go back to operating normally.
Jul 30, 2010 | Jacuzzi Cyget In Ground Pool Pumps
2 hp Swimming Pool - Jet / Well Pump Motor / Century B124: Water pump from swimming pool to filter lost it's ...
NOT THE MOTOR ,THE SEAL... JET PUMPS ARE NOT FOR POOLS.. LOW FLOW HIGH PRESSURE.. YOU NEED HIGH FLOW LOW PRESSURE ... IF NOT YOU MAY HAVE A SUCTION LEAK OR A BAD SHAFT SEAL... VOTE JAY
May 17, 2010 | AO Smith 2 hp Swimming Pool - Jet / Well...
Pump will not work in high speed
Only three posible problems. High is out on pump. Spa side control is out. Control box relay that runs high pump is out.Does upper controls(spa side) read out a code? Kirk
Feb 12, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
A.O. Smith SQ1102 Pool Pump Motor Logo
22 people viewed this question
Top A.O. Smith Plumbing Experts
Donni Steen
Tom Chichester
Are you an A.O. Smith Plumbing Expert? Answer questions, earn points and help others
