Question about Autodesk QuickCAD Millennium Edition 6 Full Version for PC
Need to upgrade QuickCAD 6 to Windows 7 compatable software that can open and edit QuickCAD 6 files
  • 18 Answers
SOURCE: Roxio Creator 7 & Vista compatability
download it again from www.download.com
Posted on Jan 17, 2009
  • 5184 Answers
SOURCE: I have Printmaster 7.0 but it is not compatible
The upgrade path is to Printmaster Platinum 18.1 or Printmaster Platinum 2.0. I'm not sure which is better for you but both are $39.99 from http://www.printmaster.com/ .
The installers for Windows have changed over the years. Your alternatives would be to use a dual boot or virtual computer with XP installed. Win7 Pro and Ultimate allow you to run XP mode free after downloading two programs from Microsoft. All the other options require a licensed (paid) version of XP.
The compatibility mode is available but I'm not sure it will work in this case. You would need to right click on the installer and choose Properties. Then go to the Compatibility tab and chose an older version of Windows (Win98 may be a better choice than XP). Then right click on the installer again and chose Run as Administrator. Then you will need to do the same thing with the actual program.
I hope this helps.
Posted on Aug 25, 2010
SOURCE: I could not install PrintMaster Publishing Suite
Not compatible or not working well with windows 7?
(making a program work with windows 7)
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:)) julyallan01_52.jpg
Posted on Dec 06, 2010
SOURCE: Autodesk Quickcad millennium edition 7:
you can run quickcad 8 from another drive and access your drawing, not quite sure how this has happened. I connect my old drive with windows XP and access the programme on it I can then run and edit this old programme from my new computer running windows 7 64 bit
Posted on Jun 19, 2011
SOURCE: I've transferred many QuickCad 7
can install quickcad on my new computer windows7
Posted on Aug 19, 2011
I have Quickcad release 6 millenium edition, can i run this on windows 8.1 ?
You need to get an upgrade from the producer of the program.
Nov 03, 2014 | Computers & Internet
How to run AS-2300 software on Windows 7 Premium edition 64 Bit. Includes also foot padle.
The AS2300 foot pedal RS23 or RS25 are not compatible with 64 bit operating systems. You will need an RS27 pedal, available at http://www.dictationmall.com/147-035.html
Also the software is not supported on windows 7. You can get a free upgrade to the latest version, dss player standard, here. http://olympusamerica.com/cpg_section/software_results.asp?id=1219&os=w
If you have version 6, you need to upgrade to version 7 first. Once at version 7, you can then upgrade to player Standard.
Jun 21, 2011 | Olympus AS-2300 PC Transcription Kit
Autodesk Quickcad millennium edition 7: using windows 7 Will not load from disk: Is there a fix for this, Serial # 110-15952975
Dec 28, 2010 | Autodesk QuickCAD Millennium Edition 7 for...
Nero 6 burning rom inconpatible with windows 7
Nero 6 is not compatible with Windows 7
Nero 9 is compatible.
You can check Win 7 software/hardware compatibility @ Windows 7 compatibility center.
Hope it helps
Oct 07, 2010 | Ahead Software Nero 6 Ultra Edition...
Does Avid Liquid 7 support Vista Home Premium
Avid Liquid 7 is an video editing and authoring software created by Pinnacle Systems.Though they have mentioned support for only Windows XP, it is possible to use Avid Liquid 7 on Windows Vista and Windows 7. Tip is very simple. You just need to run it under compatibility mode. To do this
  • Right Chick on Avid Liquid 7 Shortcut
  • Open file location
  • Right Click on exe file
  • Properties
  • Click compatibility tab
  • Tick mark 'Run this program in compatibility mode' and choose Windows XP (Service Pack 2)
  • Apply and run the software.
Sep 28, 2010 | Avid Liquid Pro 7 for PC
Autodesk quick cad millenniun editio release 7 will not install on my laptop with windows 7. a install window appears but nothing happens when i click install. works fine on xp. is there a patch?
Try this, copy the entire contents of the CD to a folder on your hard disk. locate the setup icon. right click on it and set the compatibility mode options to" windows xp". then doulbe click the same icon to launch it. Its helped me in the past. Cheers
Aug 29, 2010 | Autodesk QuickCAD Millennium Edition 7 for...
Drivers
I will recommend that you download and run the free Windows 7 Upgrade Advisor. It helps find issues with your computer’s hardware, devices that might affect installing Windows 7. Go to the Windows 7 Compatibility Center find direct links to drivers, updates, and downloads.
Apr 04, 2010 | Toshiba Satellite A300-ST6511 Notebook
I have an Olympus Digital Voice Recorder WS-311 M and a new Macbook Pro. I cannot seem to download to my Mac
http://www.olympusamerica.com/cpg_section/cpg_archived_accessories.asp?id=1308&ct=all
"DSS Player Version 7 (Vista Compatible) Item: #147467-410
DSS Player version 7.x provides computer support for Olympus DS-Series, WS-Series and VN-3200 and VN-5200 PC digital voice recorders using Windows 2000 Professional, XP Professional, XP Home, Vista, and Windows 7.
Functions include USB file download, file playback, editing files, conversion of DSS files to WAVE format, and archiving files. The installed application provides for the purchase of an optional Plus upgrade that enables splitting and joining files, and compatibility with voice-to-text transcription software.
The CD also contains DSS Player for Mac that provides computer support for Olympus DS-Series, WS-Series, and VN-3200 PC and VN-5200PC digital voice recorders on Macintosh platforms using Mac OS 10.3 and later, excludes: DS-3000, DS-2000, DS-660, DS-330, DS-320, DS-150, DS-10 and DM-1. Functions include USB file download, file playback, editing files, conversion of WMA and DSS format files to AIFF format, archiving files, and splitting and joining files. This MAC software version is not compatible with older foot switch RS-25, only the RS-27.
Item #147467
Opened software cannot be returned.
Price: $29.99
Sep 24, 2009 | Olympus WS-311M Digital Voice Recorder
Autodesk QuickCAD Millennium Edition 6 Full Version for PC Logo
180 people viewed this question
Top Autodesk Computers & Internet Experts
JM Computer Service
JM Computer Service
Jerry
Jerry
Are you an Autodesk Computer and Internet Expert? Answer questions, earn points and help others
