Hello.. the dvd tray is locked how do i unlock it so i can remove disc
    Sergeant:
  • 167 Answers
Power off the unit pull the plug then put it back again then power on the unit.
Posted on May 24, 2011
Hello, I have jusy bought a HTS3011 home theatre system, but I had try to play a lot of dvd s, and I had an error related to the disc regionin the most part of the discs I tried. Can someone help me? As I...
Hello Patricia -
Please follow the instructions below for unlocking your Philips HTS3011
1. Switch on the DVD player
2. OPEN the disc tray
3. Key 9 9 9 9 0 using the Philips remote control supplied with the DVD player
4. Press PLAY. The disc tray will close.
5. Switch the player OFF then switch ON again.
6. To test, play a disc from a region which was previously locked.
If it does not work the first time, switch the player off and back on, then try again.
This is a verified unlock method, but I was unable to confirm whether it works for players sold locked to Region 1 (North America). If you have a Region 1 player and the method above does not work, you will not be able to unlock your player.
Please note: Unlocking a DVD player may invalidate the warranty. Unlock sequences may not work with some firmware updates and some DVD players have been damaged through failed attempts to unlock them. Unlocking your DVD player is done at your own risk.
Regards,
BElectric
May 01, 2011 | Televison & Video
Dvd door will not open
with the unit turned off press and hold "8", and then press "x" on the unit until "unlocked" appears on the screen.
This is from page 83 of the manual regarding tray lock feature.
Nov 18, 2007 | Televison & Video
It is locked and we do not know how to get it unlocked. It states we need a code and we do not have it.
Do you mean it is disc locked or tray locked? If it is tray locked, it may require workshop attention, which could be expensive (depending on the nature of the problem). If it is DISC LOCK, try this:
Up to 20 discs can be locked.
[ Lock ] - To block the playback of the current disc. Subsequent access to a locked disc requires a six-digit password.
The default password is 136900.
[ Unlock ] - All discs can be played.
(You enter the six digit code as above then press OK on remote) (resourced from elsewhere)
Apr 18, 2011 | Philips DVP3982 DVD Player
Disc tray is "locked" on
I had the same problem and unplugging it doesn't help. I found that if I unplug it AND remove the HDMI plug the system resets itself so that when you plug the system back in, you can open the disc tray.
Jan 13, 2011 | LG BD550 Blu-Ray Player
My JVC TH-G30 gives me a locked message when I try to open the load tray what should I do?
hello Setting the disc ejection lock
You can lock the disc tray to prevent the disc form
being ejected.
When the main unit is turned off, hold down the STOP
key at the front panel for 5 seconds
If you attempt to open the disc tray by pressing
OPEN/CLOSE key, the disc tray does not open and
“LOCKED” appears in the display window.
To cancel the disc ejection lock, hold down the STOP
key at the front panel for 5 seconds again when the
main unit is turned off.
“UNLOCKED” is displayed in the display window.
Note:
Before the main unit is turned off, DVD/CD function
should be selected.
Mar 29, 2010 | JVC TH-G30 Theater System
The tray disc says LOCK, someone know how to unlock
Hold stop on player and power button on remote at same time for 5 sec.
May 30, 2009 | Panasonic DVD-S35S DVD Player
Trey locked
There is a lock on this on the remote or end the menu system I do not remeber witch. You can unlock this software if not you need to unlock it hardware witch gets a little tedious.
May 24, 2009 | Sony DVP-NS700P DVD Player
My kids locked my rca dvd player model rc5220p
The Disc Tray is Locked
If the message “Tray Locked” appears on the screen, the retail lock feature has
been accidentally engaged. To unlock the disc tray you must press and hold a
combination of keys simultaneously:
On the front panel of the DVD Player, press and hold the STOP, ON•OFF and
OPEN•CLOSE buttons for at least 3 seconds.
I forget the password Your player is equipped with a “back-door” unlock sequence. Press and hold
the STOP button on the front of the DVD Player and the STOP button on the
remote control at the same time. (Hold both buttons down at the same time
for at least 3 seconds).
Dec 28, 2008 | Televison & Video
Locked??
I had this problem, it was a jammed disc. I disconnected the dvd player and removed the cover. Then I checked out the trays and sure enough a disc was jammed. It took a bit of very gentle work to free the disc as the jammed tray needed to be unlocked so the tray self slid and released the offending disc. Once that was done I placed the cover back on and reconnected the wiring...and all was well.
Jun 02, 2008 | JVC TH-M606 System
DVD Tray is locked
Push and hold down the Open/Close button until "UN-LOC" appears on the FL display (or "Disc Tray Unlocked" appears on the TV screen).
Jan 18, 2008 | Sanyo DWM-390 DVD Player
20 people viewed this question
 Grubhead
Grubhead
