Question about Proview PL926WBi 19" LCD Monitor
My lcd goes off after few seconds,i replaced all the caps on the inverter board but that did not solve the problem.
  • 11,361 Answers
You can have bad lamp problem, you need spare lamp to verify if it is the inverter circuits or the lamp problem. How are the 5vdc for the logic and the 12~18vdc for the inverter circuits?
http://s807.photobucket.com/albums/yy352/budm/Bad%20backlight%20lamp/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on May 25, 2011
When I turn my Polaroid tv on I get the dish signal and see a picture a few seconds, then goes off. I still have sound.
This problems is the long LCD inverter board is dead.This long LCD inverter board help the LCD screen panel to have a backlight to prduced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy a long LCD inverter board for the replacement.
Feb 02, 2011 | Polaroid TLA-01511C 15 in. LCD Television
My westinghouse 32 inch flat panel tv turns on i get the picture then in about 20 seconds picture goes out but still have volume. i turn it off then on again and the same thing happens ....help
This tv have a dead long board call the LCD inverter board.This long LCD inverter board job are to help the LCD screen panel to have a backlight to produced a picture.Replaced this long LCD inverter board,will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish long LCD inverter board for the replacement.
Dec 02, 2010 | Westinghouse SK-32H540S 32 in. LCD TV
Picture goes out after 2 seconds
Tv have picture only few sec.than dies have sound left only?Yes,than the tv long board call the LCD inverter board is dead.This long LCD inverter board help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy this long LCD inverter board for the replacement.
Oct 21, 2010 | SVA-USA EV-1703 17 in. LCD Television
My westinghouse flat screen tv - i turn power on picture comes on for a few seconds and goes black - sound still works - any suggestions?
The tv have 1 or 2 long boards call the LCD inverter boards are dead.These 1 or 2 long LCD inverter boards help the LCD screen to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 1 or 2 long refurbishes LCD inverter boards for the replacement.
Oct 07, 2010 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Monitor goes black after a few seconds
Tv turn on now,picture flashes only few sec. just dies and have sound left only?Yes,than a long board call the LCD inverter board is dead.This LCD inverter board help the LCD screen to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish a long LCD inverter board for the replacement.
Aug 04, 2010 | Polaroid TLA-01511C 15 in. LCD Television
Screan comes on for 1 second then goes black. switch light showes recieving signal.
This Acer 2416w has problems with weak capacitors on the inverter board causing shorting of the driver FETs. Replacing caps and shorted FETs may solve the malfunction.
Monitor Mike
Oct 04, 2009 | Acer AL2416W 24 in. LCD Television
I have Toshiba 15" lcd tv with vestel 17ips01-2 psu/inverter board.the tv will show a picture for a couple of seconds and then the inverter cuts out.
There are a few things that can cause this fault, but the most common is the High Voltage Capacitors that feed the backlights going bad. The invertor and power supply are on the same board (Vestel 17IPS01-2)
The caps are on the power supply board and are C355 & C356 (12pf 3kv) and C354 (4.7pf 3kv). If you replace these caps it will solve the problem in 99% of cases.
If replacing these three caps do not solve the problem then it may be easier to replace the power supply board... as fixing means replacing a tiny surface mount chip with loads of legs.
WARNING: The Power Supply/Invertor board can contain LETHAL VOLTAGES even when turned off and unplugged. if you are not sure, Pay someone to do it for you!
Aug 13, 2009 | RCA Mikomi 5290925 15 in. LCD TV
SCREEN GOES BLACK AFTER A FEW SECONDS AFTER TURNING MONITOR ON.
More often then not, this is attributed to a failing Backlight Inverter. A Backlight Inverter, is a power board mounted below the screen that actually send power to the Lamp inside the LCD itself. Check to see, when it goes out if there isn't still some images faint in the screen. If this is the case take it to a local repair shop and have them order one and replace it. repair cost for this shuold be around 65-100 dollars.
If this helps, please rate my solution. Have a great day.
May 16, 2009 | Acer AL1715 17" LCD Monitor
Replacing Inverter Board
I did some poking around and only found a few places that sold inverter boards for this monitor. Ebay has one that sells for about $80: http://cgi.ebay.com/Backlight-Inverter-for-Gateway-FPD1930-LCD-Monitor_W0QQitemZ160070918225QQcategoryZ174QQrdZ1QQssPageNameZWINQ3aPOST0Q3aRECOQ3aBINQQcmdZViewItem I wasn't able to find any specific instructions posted, however, taking a typical LCD panel apart and replacing the board shouldn't be too difficult. The only hard part is not getting shocked, which is why this is not a job for the typical user. Anyway to disassemble the typical LCD you remove the pedestal from the back of the LCD then remove the screws around the back of the LCD, remove the back and look for the inverter board. Typically it is covered with a metal shield; again the hard part is knowing how to correctly handle the parts. Considering you can buy a new 17" LCD for $120 to $150 (and has a 1 year warranty) you might want to consider investing in a new monitor instead. If you have any other questions let us know, otherwise please don?t forget to rate this posting.
Feb 03, 2007 | Gateway FPD1760 17" LCD Monitor
Proview PL926WBi 19" LCD Monitor Logo
103 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Diego Zenizo
Diego Zenizo
Level 1 Expert
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
