Dvd reads disc inserted then signals "no disc" and does not self start. When attempting to start play using remote signal "Err" appears but still willnot play
  • 8,457 Answers
This question is for a plain basic DVD player only wright?Yes.DVD player laser eye data reader it is dead.This is a basic DVD player only?Yes,not worth a cost of the repair.Because basic DVD player only,now are pretty cheap.Can get a new one for like $40 brand new.
Posted on May 24, 2011
When i try to play a dvd it says cannot read disk. please choose another
The rca jacks are either marked in for signal to enter or out for signal out.
If will not read a disc either the optical pickup in the DVD unit is dirty or bad and it is that simple.
Apr 17, 2012 | Panasonic PV-DM2093 Triple Play 20 in....
The disc is stuck in the player and the tv screen says it cannot get a signal.
Barbara, your dvd player needs to be either on channel 3 or 4. If you have a local channel 3 or 4 switch it to the one that is not local. Or it could be a video 1,2 or 3. Just keep using the remote in that format and you will find the signal.
Nov 21, 2011 | Cyberhome CH-DVD 300 DVD Player
The disc player suddenly stops playing and says no disc even if there is disc on the shelf
Your disc player has a "lens or eye" that reads the electronic signal from your disc and transform that signal into a video image and audio sound. The reason why it stops playing and says there's no disc inside is because it fails to read the signal. The lens or eye may have acquired dirt that's blocking the signal. Try to open your disc player and locate the lens located on the center of the rotating disc holder. It is very easy to locate because it is directly under the disc. It is round, very small and made of glass. Get a cotton ear bud or just a small piece of cotton, moisten it with alcohol, or nail polish remover then wipe the lens. By doing it, you are removing the dirt that may have accumulated while you were using your disc player. It is highly advisable that you switch on all your electronic gadgets at least twice a week even if you're not using them. By doing this, you are preventing your electronic devices from acquiring moisture due to heat/coldness in the environment.
Another possibility, the format of the disc that you inserted (mp3, mp4, blueray, dvd) is not compatible with your player and therefore your player was not able to decode/read the signal.
Jul 23, 2011 | JVC Audio Players & Recorders
The display says, "insert disc",
Thank you for posting to Fixya.com and it is my pleasure to guide you.
1. The disc may be turned over. Insert the disc with the playback side facing down.
2. The disc may be dirty. Wipe it with the correct type rag.
Since you stated the display is showing then I take it the player is on and the chord is plugged in.
3. Is the disc completely centered in the tray? I have done that before.
4. Have you run the self-diagnosis function? If the Error code 'AACS ERR' shows then it is an "AACS read failure". Remove the protected disc. Then turn the unit off and wait a minute or two and back on.
Good luck and please post back that you are successful and give thumbs up if my solution has worked for you. If I can be more helpful just reply.
Jun 18, 2011 | Sony BDP-S300 Blu-Ray Disc Player
Technika tv/dvd combi dvd will not play when disc inserted it reads then indicats "no disc" and when attempting to play via start control on remote signal "err" appears
your player did not read multi disk or maybe the lens is not clean try to clean it with dvd disk cleaner first or check the disk for some scratches causing problem
May 24, 2011 | Televison & Video
Lexus 2001 is 200 6 disc stereo error 1 code shows when trying to play cds
Error 1 - "disc is dirty, damaged, or is inserted upside down"
I quote other solution comments:
I've been getting the Err 1 and Err 3 for a while now, my headunit needs replacing but I haven't had chance yet...
I've found that the cold weather makes it worse as the CDs get that cold they are covered in condensation so the CD has trouble reading them..
In my experience when you get an Err 3 it's basically knacked and needs replacing and Err 1's can sometimes be read problems - what's the disk like?
Mine has started giving Err 1's on brand new CD's (not CDRs) so she's probably having trouble focussing....
If the car is less than 5 years old the headunit should be covered under warranty (ie free).
Hope helps.
Apr 02, 2011 | 2001 Lexus RX 300
DVP-NS30 shows "CANNOT PLAY" message when DVD inserted
Follow this procedure to troubleshoot if the DVD player cannot read or play the inserted disc.
  1. Ensure the inserted disc is compatible with the DVD player.IMPORTANT: Refer to the operating instructions supplied with the product for a list of compatible disc. Manuals are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
  2. Use a soft cloth to clean the disc.
  3. Examine the disc for any cracks or scratches that might be interfering with playback.
  4. Attempt to play another disc.NOTES:
    • If another disc plays in the DVD player, then the previous disc is faulty.
    • Some recordable discs may not play correctly because of the quality of the recording, the physical condition of the disc, or the characteristics of the recording device or authoring software used.
  5. Remove the disc from the DVD player.
  6. Turn off the DVD player.
  7. Unplug the power cord of the DVD player from the AC outlet.
  8. Let the DVD player remain without power for 1 minute.
  9. Plug the power cord back into the AC outlet.
  10. Turn on the DVD player.
  11. Insert the disc into the DVD player.
  12. Attempt to play the disc.
If still persists, its time for your device to get serviced.
Aug 01, 2009 | Sony DVP-NS57P
Three Problems, Please.
Dear brother Iam also a Technician like u I have also the same dvd player with me with missing IC104 in signal board under the lense mechanism,How ever the problem which u explaind in ur question I think it is problem from the lense,becouse I got so many DVD players (not mentioned player)for the explained symptoms and most of that when I change lense become good.
Dear brother I have a request to that to mail me the IC 104 number in follwing address.noushadkaruvally at yahoo.com
Jan 16, 2008 | RCA RC5215P DVD Player
DVD appears to not be reading or recognizing discs
Unfortunately your DVD drive mechanism looks to have bit the big one.
You can try taking it apart, removing the top of the drive and cleaning the lense. Work it up and down. Use a q-tip with a little squirt of windex on it.
Reassemble and try it again. If you get the same results, it's time for a new DVD player.
Dec 27, 2007 | Toshiba SD-V392 DVD Player/VCR
Built-in DVD player
Are you trying to play DVD's you've made or copied yourself or new one's you buy from an actual distributor? Because sometimes self-ripped Cd's & DVD's won't play on a LOT of DVD players. Otherwise it's bad DVD player and you should go get it swapped out if it's not too late.
Dec 03, 2007 | Insignia LCDTV26 26 in. Television
Televison & Video Logo
62 people viewed this question
Top Televison & Video Experts
Electro Med Services...
