Question about Garden
I have a husqvarna riding mower - Model YTH150 and Serial 051099d003012... 1st - the drive belt broke and I had it replaced by the neighbor...but it was the wrong size belt and it kept slipping....and it did not solve the problem of the mower not driving when it got hot..2nd - a friend put the correct size (?) belt on and the mower seemed to work fine until it got hot .. it gets so bad that you have to push it to go forward
  • dawnda2 Jun 05, 2011
    I did replace the belt. I brought all the info to the dealership and they gave me the belt to use. It works a little better but not wonderful. It takes me 4 mows to mow my acre...I mow until it loses its forward momentum and then I park it for an hour or so - then go out and do it again... a friend suggested buy a belt an inch or so shorter and install that....I don't know it works now and depending how you look at it, gives me a rest 3-4 times.....thank you for your assistance
    Master:
  • 448 Answers
If you take the make model and year down to tractor supply they will give you the right belt that
goes to your mower keep in mind a true mower belt is (GREEN) not black also engine size
they have a parts manuel in there that will amaze you
any make model year they can cross reference the part you need
i hope this helps you
bob
Posted on May 29, 2011
  • robert DIBBLE
    robert DIBBLE May 30, 2011
    i am trying to find out how you made out with your belt i didnt abandon you
Husqvarna yth248t belt diagram
You can go to www.Husqvarna.com/us and use the serial number and the product number of the unit. These numbers are located on the tag found under the seat of the mower. With the serial and product numbers you can locate an IPL or owner's manual which will show the belt routing.
Sep 04, 2014 | Husqvarna Garden
Mahindra tractor diagnostics
You are going to have to disconnect belt and try to turn pulleys on drive system to locate the excact location. It sounds like a belt tension or bearing problem to me.
Jul 19, 2013 | Husqvarna Garden
Was cutting grass and mower just quit pulling
sounds like the drive belt broke you need a new belt
Jan 29, 2013 | Husqvarna 26 Hp 54" Deck Zero Turn Riding...
Finding replacement belt from UK for McCulloch hornet ride on mower
Just in case anyone else comes across this in searching for a Main Drive Belt or a Deck Belt :-
Marksman Industrial Ltd
Main Drive Belt 1134.9013-01 (see also 9585-0057-00)
External length 888 mm
"STIGA 1134-9013-01 Equivalent Belt" Kevlar reinforced
Deck Belt 1134.9032-01 (see also 9585-0075-00)
External Length 1219 mm, Pitch Length 1206 mm
4L480K - 1/2" x 48" Kevlar reinforced
Note:
Stiga Garden Combi is pretty much an identical mower
Hope this helps someone.
Aug 01, 2012 | Garden
Husqvarn lgt2654 wont pull
Make sure the drive belt is routed right. Go to partstree.com click on
husqvarna and put in your model number and click on the drive scematic and it will show the routing of the belt.
Jun 23, 2012 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Hi, Just replaced the drive belt on a Husqvarna CTH180XP rear discharge 42" deck ride on mower, due to the belt becoming worn. Replaced exactly as the way it was taken off with belt all pulleys. The...
My name is Dane and I am going to help you solve your problem.
I looked up your mower and I believe you should be using drive belt# 5321701-40. That is a 112" belt. Here is a link to the parts manual and a drawing of the belt routing. As long as that is the belt you have, and replaced it correctly it should be fine. You are correct, when you put the mower in gear, the pulley system will put more tension on it.
http://weborder.husqvarna.com/order_static/doc/HIPL/HIPL2003/HIPL2003_1063048-61.pdf
Well, I hope I've helped. If you found this information useful, please leave me some THUMBS UP if you think I'm deserving! :-) Thank you! Dane
Dec 05, 2010 | Husqvarna Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
