Question about Dyson DC17 Animal Bagless Upright Cyclonic Vacuum
Getting a very high pitch sound only when the motor is engaged. I can turn the vacuum on and don't hear the sound until I tilt it back and engage the belt.
    President:
  • 2,080 Answers
More than likely your roller brush drive belt is damaged. If you remove the belt and look at it you will probably see a bald spot on the inside circumference where it is missing some teeth. Your belt drive gear is probably spinning and squealing each time it hits this bald spot on the belt.
To access the drive belt unplug the unit, then just rotate the flathead screws on the bottom plate counterclockwise until they disengage and then gently pry off the base plate. Use a screwdriver slide the inner part of the belt off the drive gear and then the whole roller assembly and belt should come right out.
Just contact Dyson and have them send you a replacement belt for free and then just reinstall it yourself.
Here is the link to the Dyson website:
http://www.dyson.com/
http://www.dyson.com/support/help.asp?article=2
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information and items at the website indicated.
Or phone Dyson Support toll free:
1-866-693-9766
I hope that was helpful to you, good luck.
If you choose to rate this solution using the Thumbs Up scale provided, I thank you very much for your time and consideration.
Joe.
Posted on May 24, 2011
Hi, i just bought a Dyson DC 22 yesterday and it makes this really annoying high pitched noise? Is thia normal? Or should i take it back to the supplier?
Sorry to hear you're having difficulties your DC22. So we can identify the cause of the high-pitched noise you're hearing, and recommend the best course of action, I'd suggest calling us directly so one of our experts can diagnose any issues over the phone with you. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We look forward to hearing from you.
Kind regards,
Jack
Dyson Customer Service
Aug 01, 2011 | Dyson DC22 Motorhead Canister Vacuum...
When I tilt my Dyson DC 17 Animal upright so that I can use the hose, the vacuum powers off. As soon as I tilt it back down, it turns back on.
I'm sorry to hear you're having difficulties with your DC17. When you stand the cleaner upright, the brushbar motor is designed to shut off automatically. However, the suction motor should continue to run unless you turn it off manually with the on/off switch. If both motors seem to be shutting off when you stand the cleaner upright, it's probably best if you get in touch with us directly so we can resolve this issue for you as quickly as possible.
You can call us free on 1866MYDYSON - or if you email your details to askdysonUS@dyson.com, someone will be in contact as soon as possible.
Kind regards,
Jack
Dyson Online Customer Support
Jun 30, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
I am losing suction and it sounds as if there is a leak in the vacuum(I hear air rushing around). There is also a high pitched noise. Dyson dc07. Can there be leaks in the gaskets where you clean hoses and...
It wont be a gasket problem - they don't tend to fail.
A high-pitched noise can be a number of different things. That is too vague to diagnose on here with the description you have given. Can you be more specific?
Jan 16, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
NO SUCTION HIGH PITCHED MOTOR
sounds like the bearings or brushes in the motor are bad.
Oct 23, 2009 | Dirt Devil Vision Turbo W/Bonus Upright...
Dyson motor making high pitched noise. Is this
Most likely, there's something in the dirt tube. Ic could be something like a piece of paper or cellophane, vibrating from the air going over it. without hearing it, a high pitch noise could be different things.
Jun 13, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
High pitched sound when vacuum is on
You may be loosing your bushings on the motor,if this is an expensive machine it may be cheaper to have it fixed,if not it will burn up eventually.Also try taking the beater bar out and make sure you don't have something rapped around it causing a noise.
Hope this helped.Let me know by rating me
For more help go to live chat.
lenwest
Jan 19, 2009 | Dyson DC14 All floors Bagless Upright...
Bissell lift off vacuum about 4yrs old. Extremely noisy. OK until before Christmas but getting worse every time it's used. Washable filters washed, HEPA filter replaced. brush bar cleaned of every scrap,...
Sounds like a bad motor bearing. If it is, then you would have to replace it. Could be the brush roll, did you check the ends to make sure they turn easily?
Apr 30, 2008 | Vacuums
High pitch
Sounds like you have a clog. Make sure the filters are clean, replace if it has been more then a year, check the inlet down by the brush roll, your clog maybe there.
Dec 24, 2007 | Hoover Fusion Plus Cyclonic Upright Vacuum...
Dyson DC17 Animal Bagless Upright Cyclonic Vacuum Logo
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
