Question about Pioneer DEH-1900MP CD Player
Help hi i have had deh 1900 mp car radio for a while now and i pressed some button and now i cant get it to work help
    Scholar:
  • 55 Answers
Try resetting the unit. Look in your owner's manual to find where the "RESET" button is located. If you don't have the manual, you can go to pioneerelectronics.com and download one. Hope this helps...
Posted on Aug 30, 2008
SOURCE:
How do i adjust the clock on a deh 1900 mp audio
ive had a search for you and found the manual to download for your pioneer,
hope it helps you set the clock
http://www.retrevo.com/support/Pioneer-DEH-1900mp-Car-Receivers-manual/id/23227bh432/t/2/
Apr 03, 2010 | Pioneer DEH-1900MP CD Player
Changed car battery and now Pioneer DEH-P7700MP doesn't work
check behind radio for inline fuses . useually on red and yellow wire's . most likly blew one . or fried radio all together . most likely just fuse , thats why they are there
May 24, 2009 | Pioneer DEH-P7700MP CD Player
Clock
To set the clock on the Panasonic DEH-1600 car stereo, follow these instructions:
  1. Turn the radio off by pressing and holding the SRC button (under the label OFF).
  2. Press and hold the Audio button in the upper right corner of the radio. After holding the button for about 3 seconds, the clock will begin to blink (the hours).
  3. Use the up and down arrows to increase or decrease the time hours or minutes. Use the left and right buttons to toggle between setting the hours and/or minutes.
  4. When done, push and hold the Audio button again fir about 3 seconds until the clock stops blinking (hours or minutes).
Sep 02, 2008 | Pioneer DEH-1600 CD Player
Setting the clock
Hold source button till radio turns off and clock turns on. Hold Function till clock blinks. Press arrow keys to select direction of time. Then press Source again. All done
Sep 02, 2008 | Pioneer DEH-P430 CD Player
Cant display time
Upper right-hand corner, there's a button next to the "eject" button. Pressing this button while the unit is on will cycle between displaying the clock and the track number & play time (CD) or clock & radio station.
When the unit is off, you can press the same button to completely shut off the display, which is sometimes nice if you don't want the blue ring around the volume knob glaring in your face.
Jun 22, 2008 | Pioneer DEH-P3900MP CD Player
My pioneer deh-1900 mp will not turn on
did you use a wire harness adapter or did you connect the wires from the radio directly to the wires in the car? do you have a computer safe test light or a digital vom meter? do not use a conventional test light in this car or an analogue meter to check for power
Feb 09, 2008 | Pioneer DEH-1900MP CD Player
Cant change the time
I don't have the manual, but I can tell you how to set the clock. This was a doozy to find out exactly how to do this! This technique probably will work with most other Pioneer receivers too.
Either start your car or turn the ignition key to the ACC position (so that the radio is receiving power). With the radio/CD turned off, press and hold the function button (the one in the upper right hand corner) for about 5 seconds, the hours on the clock should start to blink. Use the volume +/- buttons to change the hour, use the track up/down buttons to switch from hour to minutes. Press the power button to get the new time to set.
Jan 17, 2008 | Pioneer DEH-17 CD Receiver
I NEED TO KNOW HOW SET THE CLOCK ON A DEH-1500 PIONEER
Found a posting on another site from 2005, and it worked!
Turn on the radio. Press and hold the "Source" button until the radio goes off. Press and hold the "Audio" button until the numbers flash. Use cursor/arrow buttons to adjust the time. Press and hold the "Audio" button to exit.
Oct 27, 2007 | Pioneer DEH-1500 CD Player
Pioneer DEH-1900MP CD Player Logo
256 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
