The bottom paper tray won't slide out. Is there a way to force it out?
    Sergeant:
  • 167 Answers
Check first if there is some paper remain and clog inside before you pull it out.
Posted on May 24, 2011
HP OfficeJet Pro 8600 tray can't be inserted all the way. Stops with 3 inches of tray sticking out.
  1. Grasp the handle on the front of the input tray, and then pull the tray towards you to open it.
    Figure 1: Pull out the input tray
  2. Slide the paper width guides out as far as possible.
  3. Remove all paper from the paper tray.
  4. Inspect and remove any foam or tape packaging materials in the paper tray.
  5. Insert a stack of unused, plain white paper (with the print-side down) in the center of the tray.
    Figure 2: Load paper into the tray
    CAUTION: Do not load any paper above the solid red lines on the sides of the tray. Do not use torn, wrinkled, perforated, wet, or folded paper. Make sure to remove all paper clips and staples before loading the paper. Figure 3: Stack label height
  6. Slide the paper guides in so that they rest against the edges of the paper, and then insert the tray into the product and push it forward until it clicks into place.
    Figure 4: Slide the paper guides in and reinsert the tray into the product
  7. Pull out the tray extender on the output tray.
    Figure 5: Pull out the tray extender on the output tray
Step two: Load paper in optional Tray 2
Tray 2 is an optional accessory. Follow these steps to load paper in Tray 2.
NOTE: Tray 2 supports only plain letter or A4 paper.
  1. Grasp the underside of the tray, and then pull out the tray from the bottom of the printer.
    Figure 6: Pull out the tray from the bottom of the printer
  3. Load a stack of unused, plain white paper (print-side down) in the center of the tray. Make sure that the stack of paper aligns with the engraved lines in the tray.
    NOTE: Load Tray 2 with only U.S. Letter or A4 plain white paper.
  4. Slide the paper guides in so that they rest against the edges of the paper.
  5. Carefully reinsert the tray into the printer, and then push the tray forward to close it.
    Figure 7: Reinsert the tray into the printer
  6. Pull out the tray extender on the output tray.
    Figure 8: Pull out the tray extender
Load specialty paper Follow these steps to load specialty paper such as card stock, envelopes, photo paper, or labels.
Before you proceed, verify that your printer supports the specialty paper on which you are attempting to print by viewing the product specifications . If the size, type, or weight of the paper is not available, the printer does not support printing it. Also note the tray loading capacity for the type of paper on which you are attempting to print.
Sep 27, 2013 | HP Officejet Pro 8600
Delonghi magnifica bottom tray won't go in
Hi there, I have the same type of coffee maker. I have had problems with " the black thing push". Back to the tray. Take the tray out and hoover the bottom and as far in as you can and under the " push". I need to hoover mine I can see now. 8_27_2013_9_23_31_pm.png
Jul 10, 2013 | Coffee Makers & Espresso Machines
Samsung Optical Drive SE-208 tray rattling won't eject
if you look on the drawer you will see a little hole.push a pin in the hole and the drawer will open.
Nov 15, 2012 | Samsung Optical Drive SE-208AB/TSBS...
Paper won't come out paper light blinks
I have a similar printer. Sometimes the bottom paper tray gets stuck or caught. Make sure the printer is on a flat surface.
1. Turn off the printer.
2. Pull the paper tray all the way out.
3. Take out all the paper and then place the tray back in.
4. Turn the machine on and let it try to print without paper.
5. When the light comes on add paper hit the button and you should be good to go.
Jul 26, 2011 | Brother HL 2140 Laser Printer
I put pictures in the cd but now it won't eject. It dot stuck inside. I could not eject even if I clicl computer then click eject, it won't eject
Power off the notebook, remove power cable and battery. Then try inserting a paper clip into the small hold in the CD drive to force eject the tray. Make sure you have powered off device and removed battery before you attempt.
Jul 10, 2011 | Fujitsu LifeBookS6120 Notebook
Even though my printer settings are set to print and use the paper in tray 1 - the printer wants to pull from the bypass tray (which always pulls crooked). The printer used to work just fine then the alert...
Two things to check for a problem like this:
1) Driver Settings:
If your computer's drivers are telling the machine to pull from the bypass tray it'll ignore the machine settings. You're kind of on your own here figuring it out, if you can't though then try deleting the printer from the computer and re-installing it (will default settings)
2) Manual Feed sensor:
When you put paper into the bypass try you're activating a flag which tells a sensor there's paper there, if this flag is stuck forcing the sensor to constantly think you have paper there it would always to pull from there. Find the flag, move it back and forth, hit it with some air from a can of air.
May 31, 2011 | Ricoh AficioSP C222DN Laser Printer
When I try to print a page, printer does not pick up paper and then gives error message that printer is out of paper when there is plenty of paper in the tray. Sometimes if the printer hasn't been...
Hello.
From the HP site:
There could a problem in the pickup assembly area of the product. There are twoblack Mylar light shields approximately 3.5 inches long. They are located onboth sides of the pickup roller under the pickup roller rod. One or both ofthese black Mylar shields can be tucked under, or partially bent when removinga paper jam from the paper input tray slot.
Reposition the black Mylar light shields back into the proper position.
  1. Unplug the power cord from the product.
  2. Remove the paper and paper input tray.
  3. Slide hands, palms side up, into the paper input tray cavity until the fingertips reach the end of the cavity.
4. Bend fingers up to push theblack Mylar light shields back into place. The proper position of the blackMylar light shield will be flat.
5. Reconnect the power cord.
6. Print a self-test/configuration page to verify product is functioningcorrectly.
If still a problem, make sure that the tray, paper is locked in thecorrect position. Sometimes the spring in the tray can become worn out andloose. You can take that out and spread it out a little. Also, make sure thatthe tray bottom is free to move. Take out the paper and see if it goes up anddown correctly. If you don't hear the pickup roller moving or the motor runningyou may have a bad feed roller gear. There also, could be a problem with thepickup roller.
Hope this helps.
May 23, 2011 | HP PSC 2355 All-In-One InkJet Printer
Slide tray won t seat on projector
Try a couple of things:
1. Turn on the projector & cycle it in "Reverse" 3 or 4 times (without the tray). Do the levers that move the tray move correctly? If so, do you have another tray you can try? If another tray works correctly, follow Step #2.
2. The 140-Tray has to be in the "zero" position for the tray to seat on the projector. Check to make sure the Locking Ring (the ring is in the center of the tray & keeps the slides from coming out) is TIGHT on the top of the tray. Once checked, turn the tray upside-down. Refer to Page 8 in your owners' manual (if you don't have one, I've made an image of the page, below). You have to make sure the plate on the bottom of the tray is lined up at the notch at shown.jauburn_12.jpg
If this helps, please leave positive feedback for me @ FixYa.com. If you need more help, please re-post!!
Apr 13, 2011 | Kodak Carousel 5600 Slide Projector
Canon IP4600 won't feed from rear tray.
It turns out that if you read the documentation VERY carefully it says that "if the application program specifies 8.5x11 plain paper and that is what is loaded in the front cassette you cannot print from the rear tray". It turns out that this is true even if you go to the printer driver and specify "rear tray" manually. The driver disregards the setting. You can force printing plain paper from the rear tray by going to the Canon "My Printer" icon and forcing ALL printing from the rear tray. If you do this, remember to change it back. You can also print plain paper from the rear tray if you specify the "allocation" option and the paper from the front cassette runs out. You can always print from the rear tray if the application that created the print job specifies something other than 8.5x11 without resorting to the forced override, e.g. printing a .jpg or .gif or something from an application like Paintshop or Printshop, etc.
Jun 12, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
k24674
jasbo
jasbo
