Question about Canon Speedlite 580EX II (1946B002)
I have a new 580EXII mounted to my Canon 7D. I do not seem to getting the "double flash" (not sure what the technical term is) that I expect and pictures are coming out dark. I'm think I'm just getting the pre-flash and the second flash isn't firing (or vice versa). I've tried remounting it several times. Any suggestions? Holly Cannon
    Scholar:
  • 147 Answers
Holly, I believe you are referring to the pre flash for the ETTL function. both flashes happen so so fast that it looks like one flash. If your pictures seem dark make sure your flash is set to ETTL (press the MODE button unlit ETTL is displayed) this way the flash output is automatic. If it is still too dark you can change the flash output by adjusting the FEL (flash exposure composition) by pressing the button in the center of the dial until +/- is displayed the turn the wheel to select a + exposure (you can adjust this in 1/3 stop increments) then press the center button again. This can be found on pg 14 of the manual
Hope this helps.
Posted on Jun 18, 2011
580ex won't communicate with Canon 7D (Because I dropped it)
Not sure about the repair costs but why not invest in a Phottix Odin wireless system? I use them in my work and they perform flawlessly. Small and lightweight plus they are wireless which means that the camera can communicate through windows and walls etc.
Hope this helps
Mar 17, 2013 | Canon SPEEDLITE 580EX TTL Flash
Canon 580exii speedlight, I want to only use the slaves, but they won't fire when I turn off the master
You didn't say what camera model you are using.
If you have 7D/60D/T4i you can have a total of 3 wireless ir flashes.
580EX II must be set at Master, say Group A & Channel 1
Two 270EX II must be set at Slave, say Group A & Channel 1
or
One 270EX II set at Group A & Channel 1
Second 270EX II set Group A & Channel 2
Then go into camera menu & turn off Master flash & turn settings for those two flashes.
Send me a email, then I can help you much better.
atdlee@netzero.com
Nov 17, 2012 | Canon Speedlite 580EX II TTL Flash
My canon sd630 can view pictures when you set it to
The technical term for this is 'broken'. Repair will cost more than replacement.
May 07, 2017 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon 7D battery problems
I take it this is a non-Canon battery? If it does this with a Canon battery, then the board that senses the charge level is bad.
However, the 7D has a history of loose screws which will short out various circuit boards of the camera. [screws that hold the DC to DC power board]
Mar 30, 2012 | Canon EOS 7D Digital Camera
I need a manual for my canon 580ex flashgun
580EX:
http://downloads.canon.com/cpr/software/camera/580EX.pdf
580EX II:
http://downloads.canon.com/cpr/software/camera/Speedlite-580EXII.pdf
Jun 30, 2011 | Canon SPEEDLITE 580EX TTL Flash
Just got a Canon 7D. Attached my 430EX to the hot shoe and it won't fire. Tried new batteries and checked the contacts, and it still won't work. Put th 430EX back onto my Rebel XTI, where it has always...
Make sure you using flash grade batteries and not rechargables. try energiser ultra or litiums or duracelll plus but nothing else. if the charge light is not coming up then most likely batteries. I would take it to your local camera shot and test your 7d with one of thier 430 just to make sure the hotshoe didnt short out the flashgun
Feb 21, 2011 | Canon Speedlite 430EX TTL Flash
"Error 05 The built in
This could happen when the surrounding temperature is too cold. The camera uses a spring to pop up the flash. If the oil around the spring freezes, the flash will not pop up at all.
The other thought is about the spring itself. if the spring losses, it will cause the flash not pop up again.
If those are not the issues, you may want to bring it to technical support.
Dec 07, 2010 | Cameras
I have a Tamron lense 18-250mmm for Canon. It does not focus with zoom use, iwith different Canon bodies , particularly with a focus on a light or low contrast point. Canon lenses do not seem to have this...
In low light situations, connect a speedlite flash to your body (e.g. 430EXII or 580EXII). These flashes emit a AF assist beam to assist focussing in low light situations.
Nov 28, 2009 | Tamron 28-300mm f/3.5-6.3 DI XR for Canon
Af assist on canon flash 580exii not working
check Custom Functions of Camera and Flash it can be turned off in both locations
Jun 13, 2009 | Canon Speedlite 580EX II TTL Flash
Canon Speedlite 580EX II (1946B002) Logo
107 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
