Question about Toshiba (K000823110) Motherboard
Toshiba tecra no display but power led light on after watching dvd flim
  • Toshiba Master
  • 27,725 Answers
Test all leads that attach to your hard drive including electrical extensions IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error If your computer came with a motherboard disc the drivers could be on it or you might have a dirty graphics card remove the graphics card and clean the socket
click start control panel display desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size larger size or custom settings
always click APPLY after making any changes
also
hope this helps
Posted on May 24, 2011
I would lick ti instal xp on my set toshiba tecra a2-s316 but i dont know how to boot my system by bootable cd
When booting you laptop notice the Toshiba scree. As that screen displays with the option F2 or F10. With your XP cd in the DVD/CD drive choose F10 and set your boot device to DVD/CD.
And follow the onscreen prompts.
Hope that helps.
Feb 23, 2011 | Toshiba Tecra A2-S316 (0032017250819) PC...
Will not boot up
I have seen a lot of Toshiba Laptops with bad "DC Connectors" on the motherboard. It sounds like you know what your doing so here a link on how to disassemble your laptop.http://www.irisvista.com/tech/laptops/ToshibaM2/tecra_M2_disassembly_1.htm
and here is another on how to repair the dc connector. http://www.laptoprepair101.com/laptop/2006/05/27/failed-laptop-power-jack-workaround/
May 27, 2009 | Toshiba Tecra M2-S530 Notebook
My toshiba tecra 8000 will not power on
What you need to do to test this is the following:
1 - Check if its the battery : Remove the battery, plug in the laptop and try to power on the machine, if it powers on then your battery is dead and the system board is fine
2 - With the batter in and the laptop plugged in you should get a charging LED light up somewhere on the laptop, if you do not then the board is most likley gone.
If removing the battery and plugging the laptop in still fails to start the board of spin the fans and you hear no beeps, then the board is gone.
Hope this helps
May 26, 2009 | Toshiba Tecra 8000 Notebook
Laptop won't start
Majority of the time it's the motherboard. You can try booting the computer with the battery out and also try reseatting the memory. Other than that, there isn't much you can do. If neither one of those solutions works, then you can safely assume it's the motherboard and it will need to be replaced in order to get the laptop running again.
Mar 09, 2009 | Toshiba Tecra A8-S8514 Notebook
Laptop won't power on
change the color converter card.
Mar 09, 2009 | Toshiba Tecra A7-S712 Notebook
I need to upgrade my DVD drive in my Toshiba Tecra A8 EZ 8313
you have to remove several parts that cover the dvd drive enclosure
the keyboard is one and the power and light display at the top of the keyboard is another section that you have to remove they pop out and are not hard to remove but be careful as they have little clips that hold them in once they are out you will be able to see what screws you need to remove.
Dec 14, 2008 | Toshiba Tecra A8-EZ8313 Notebook
CD-RW/DVD-ROM can not read and CD or DVD
yes..it's most likely kaput. I have a tecra, and I'm on my second CD/DVD replacement. They are easy to find and replace(one screw underneath, and just slide em out)..
Feb 17, 2008 | Toshiba Tecra 9100 Notebook
Toshiba (K000823110) Motherboard Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
