Question about Toro Electric Trimmer
TORO 51464 Electric trimmer battery: can it be changed?
There is a 7th screw under the Toro logo along the edge. You need to puch through the logo sticker to access it. Remove that and you will be able to pry open the case without too much difficulty. Battery has slide terminal connectors and is costing me $32 (which includes shipping).
Posted on Jun 09, 2012
  • greg blaho Oct 26, 2012
    Do you remember where you purchased the battery for your trimmer? I need one for my trimmer. thanks in advance for your reply
    Genius:
  • 1,739 Answers
Yes you can replace the original battery. It is recommended you have it done by and Authorized Service Dealer.
When the battery no longer holds a charge, you can purchase a new battery and have it installed at your
Authorized Service Dealer. If you want to discard the trimmer, remove and recycle the battery before
discarding the trimmer.
1. Remove the 2 bolts and nuts securing the trimmer handle section to the black center section.
2. Remove the 6 screws securing the two halves of the handle section together and pull the halves apart.
3. Remove the battery and disconnect it from the wire leads.
4. Discard the trimmer.
5. Recycle the lead-acid battery according to local codes.
Find you nearest dealer here:
https://homeownersolutions.toro.com/portal/server.pt?space=CommunityPage&cached=true&parentname=CommunityPage&parentid=2&in_hi_userid=30166&control=SetCommunity&CommunityID=226&PageID=30037
The part number for your battery is: 106-1905
Posted on Jun 04, 2011
  • thereisonlyz Jun 06, 2011
    I have removed these screws and the handle isn't coming apart, specifically near the battery connection. Is there a trick to it?
2 Suggested Answers
rycgl
  • 1545 Answers
SOURCE: Repair Manual for TORO 51464 Electric trimmer
Repair manuals aren't available for free download. Owner/operator's manual are though. Most service centers won't even repair electric trimmers, saying that the work is not cost effective.
Here is a link to the closest thing to a repair manual.
http://216.213.143.2/ProAuthor/ManProc.cfm?&sk=29830CA7%2DF9A0%2D11DF%2D9262%2D00D0B789305D&&ProcID=9812&ManualID=300&ProductID=-1&Edit=No&Skill=1&Lang=-1
Posted on Dec 02, 2010
Dec 01, 2010 | Toro Electric Trimmer
I dont know what string to use in my toro 8" battery trimmer
The thinner string works well in these machines and puts a lot less strain on them. I would suggest using a string of .065 range. The thicker (and more expensive) string used in the gas machines is too heavy for these lower powered electric units.
Sep 25, 2010 | Toro& Electric String Trimmer
Cordless trimmer 7inch cut model 51556 serial
Go here....you can download the manual....It's free!
https://homeownersolutions.toro.com/portal/server.pt/community/product_center/225#productDetailsPage
Jun 16, 2010 | Toro& Electric String Trimmer
Battery not charging. it has not been charged for
sorry but battery will now be totally useless
Jun 06, 2010 | Toro& Electric String Trimmer
Case won't opem
There is a screw underneath the Toro label.   I learned the hard way.
Jun 09, 2009 | Toro& Electric String Trimmer
I have a Toro 12 inch Toro Electric trimmer and I can't get the spool off to change. Any solution?
I am having the same problem - the spool should just come off by turning it counter-clockwise but is completely stuck. This model does not have any tabs that need to be pushed in to get the spool off. Very frustrating!
Jun 03, 2009 | Toro Electric Trimmer
I have an 11" Toro trimmer and was having trouble deciphering the symbols on the base. The key is having a method to gain some opposing force to unscrew the cap that holds the spool. I have an oil filter wrench called the round wrench. It is a steel bar with an attached length of rubber belt that can tighten around cylindrical objects. I used that to oppose the unlock direction on the trimmer and "voila", no tabs to push no trick with the button, you just need o_1089.jpg_1088.jpg_1087.jpgpposing force.
May 26, 2009 | Toro Electric Trimmer
Cannot disassemble weed trimmer to change battery
This is the interactive menu and it will show u specifically what to do!
http://216.213.143.2/ProAuthor/ManProc.cfm?&sk=9C8C4593-4977-11DE-9261-00D0B789305D&&ProcID=9812&ManualID=300&ProductID=-1&Edit=No&Skill=1&Lang=-1
May 17, 2009 | Toro& Electric String Trimmer
Toro Electric Trimmer Logo
2,197 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
