Question about Singer 3116 Simple
My take up lever is stuck on my singer machine. It won't go up and down. What can I do?
SOURCE: i have a singer stylist model 413 that the bobbin
I have the same problem! Did you ever figure it out?
Posted on Jul 31, 2011
SOURCE: 1) The lever at the
it sounds like the take up lever has either come loose or is broken, & since the needle won't go up & down it needs to be checked
Posted on Aug 02, 2011
Joe Onley
  • 363 Answers
SOURCE: I have a simple singer
The take up lever is right up front, the unit that goes up and down when you turn the wheel on the right, it usually has an eye or a quick threading loop. After that, it goes down, and under that circular 'thing' there, then to the needle, I hope this isn't too confusing.
Happy Sewing, Please rate and comment, Thank You,
Joe
Posted on Sep 01, 2011
  • 586 Answers
SOURCE: my izek singer sewing machine won't do
Hello there,
First thaing you should check is the tension pulley if it is poperly adjusted. Adjust it to the factory setting. Then check the needle if it is properly sitted. Then you look into the bobbin case and refix the bobbin.
Adjust your thread tension. It may be too tight or too loose.
If your upper thread and bobbin threads are different types, try using the same thread for both. And use a good quality, brand name thread.
Try switching to a needle plate with a smaller hole (a straight stitch needle plate). (Important: After changing your needle plate, check to make sure your needle aligns perfectly with this smaller hole before starting to sew. A misaligned needle could hit the plate and break, which could be dangerous. And make sure to change your needle plate back for zigzag and other wide stitches.)
Hope this was helpful to you. All the best Elect_Comp
Posted on Sep 07, 2011
  • 4 Answers
SOURCE: My Singer Prelude machine
Hi Jos, I'm no pro but I fix lots of things. It sounds like there is a mechanical blockage that is preventing the motor from turning. If you haven't already, open all the panels or covers that reveal the mechanical workings, and remove any bobbins (and maybe the needle, if the tip is touching another part of the machine) using your hand to gently rock the motor forward and backward (unplug the cord first) look for the parts to move however slightly they may be moving. if they move with your rocking motion and stop hard, there is something that has moved out of place. Closely watch the needle tip first to see how it moves and that it and its clamp are not bumping into anything. following up the shaft, gradually and methodically look at the next parts that you can see moving, and continue checking every consecutive piece in the mech, till you've come to the back end of the motor. if you havent found the culprit by now, at least you have narrowed down the possibilities and you know your toy much better that most people. When you take it to the service man, be sure to tell him how you examined it and every thing you have learned. By giving the repairer this head start, you not only reduce their time to fix it but...they will know that you are fully aware of your machine and understand something of the problem and about troubleshooting your sewing machine. You will probably fix it yourself but if not, you wont be overcharged by anyone.
Good luck, I hope this helps.
If you want, you can E me at
derbyboab AT gmail.com
Posted on Nov 17, 2011
Singer 7258 will not sew automatic buttonholes. The needle goes up and down, but that's all. The buttonhole lever is down, so that's not it. Please help.
if the sewing machine is set on the buttonhole setting then it's
possible that the sewing machine motherboard has a problem.
or a part could be damaged, the machine may need some type
of adjustment.
Dec 01, 2012 | Singer 7258 Sewing Machine
The pressure foot handle is loose and my foot won't go down what's wrong
Grasp the presser foot bar and pull it down. It is likely that the loose bar has jumped off of the cam on the lever. you'll need to figure out how to get in there and tighten it or replace a broken lever.
Good luck.
Oct 11, 2012 | Singer 9900
How do you thread a singer merritt 1872?
Wow, one of the few Singer machines that doesn't have a free download manual. Hmmm..... Ok looked up a photo of your machine. It's pretty easy.
1. raise your presser foot.
2. Put thread on spool pin.
3. draw thread over to and under from behind of the pre-tension disc at top
4. Draw thread down from the right and under the tension dial to seat the thread into the tension discs and flex that spring a little.
5. Through the take up lever.
6. Down through the thread guide.
7. Down through the needle bar thread guide.
8. Through the needle.
Hope that helps.
Aug 20, 2012 | Singer Sewing Machines
I have a 9960 singer machine and am trying to use the buttonhole presser foot for the first time and I can not get it to sew T
the buttonhole foot snaps on to the presser bar, there's a little lever at the back of the presser bar that releases the foot, then put the buttonhole foot down on the needle plate & use the presser foot lifter (number 11) to lower the presser bar down onto the buttonhole foot & you'll hear a click sound when it snaps on & make sure to use the buttonhole lever(number 31) because the machine won't sew a buttonhole unless that lever is pulled down.
Apr 26, 2012 | Singer Sewing Machines
My Singer 5050 sewing machine won't let me
sounds like a part is damaged or jamed, the machine needs to be checked
to see what's wrong with it
Apr 14, 2012 | Singer Sewing Machines
The Presser Bar on my Singer 66 does not move up or down when I use the Presser Bar Lever. It seems to be stuck solid and therefore it will not lower onto the feed dogs to enable me to sew. The Presser Bar...
it's possible that the presser bar could be bent or damaged, the only way to know what is exactly wrong would be to take it to a sewing machine repair shop
Mar 20, 2012 | Singer Sewing Machines
I was free motion quilting, machine stopped. Beeps three times when I push foot pedal and won't sew
Check your buttonhole lever, left back of the machine. Pull it down and push it right up into the machine. Should solve your problem
Sep 06, 2011 | Singer Confidence 7467 Mechanical Sewing...
I have a simple singer and I don't now how to thread the upper thread! I get stuck in the part where the manual asks to put the thread trought the take-up lever because I can't find the the take-up...
Joe
Sep 01, 2011 | Singer 3116 Simple
The take up lever on my morse 400 super dial sewing machine does not move up and down, It is stuck. What can I do to fix this problem?
it won't be the take up lever it is a false impression, take the bobbion case and raceway out and you will probably find thread stuck
Aug 15, 2011 | Sewing Machines
1) The lever at the back that keeps the foot up when threading etc will not stay up on it's own. When you put it up, it just falls bak down a second later. 2) The needle won't go up and down,...
Aug 02, 2011 | Singer 1507
Singer 3116 Simple Logo
985 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
