Question about Toshiba PA3554U-1CAM Webcam
I have toshiba laptop , camera is nt detected in device manager , its not working. when camera is nt in device manager , oviously camera doesnt work. so help to me to add the camera hard drive in device manager.
IrishDruid
  • 2712 Answers
SOURCE: adding bluetooth to toshiba laptop
Well,I'm not really an expert on Bluetooth, but let me try...
Which version of Windows are you running? If you have Windows XP SP2 or above, the Microsoft Bluetooth stack should be installed on your system. First make sure that the Kensington bluetooth adapter is compatible with the printer and the OS. From what I heard Canon sell a separate Bluetooth adapter for about $80 for this, but I'm not too sure.
Secondly, ensure that the built-in Bluetooth Stack or Software has the required Profile for your printer.
Next, put your printer in "discover" mode (see printer manual for more info ). Use the Bluetooth Connection Utility software that came with the built-in Bluetooth stack to "discover" the printer. Follow the instructions by the Bluetooth stack manufacturer on how to pair and connect Bluetooth devices to your built-in Bluetooth stack.
Please also see THIS article. although it is meant for the Logitech DeNovo keyboard, it can be used for any Bluetooth enabled devices. (Just replace the DeNovo wit your printer in the article.
But mainly, make sure that the Kensington adapter is compatible...
Hope that helps..
IrishDruid
Posted on May 04, 2008
SOURCE: Drivers lost for Toshiba Tecra M7 Tablet PC
download win xp sp3 and install .... ur laptop should work and then download and run the "registered" version of Driver Detective ... it should find drivers specifically for YOUR laptop ... that might work ...
Posted on Jun 23, 2008
JulesPCaut
  • 702 Answers
SOURCE: hard drive detection
You should not need a driver for it. Assuming you are using XP or Vista, the disk should be supported directly by the OS.
Have a look at external HDD troubleshooting.
Jules
Posted on Apr 23, 2009
lserni
  • 466 Answers
SOURCE: I have a Toshiba HDD2190 C DC +5V 0.7A 40 GB
In general, you need to install the correct drivers for the enclosure, not for the hard disk. Seeing as you have XP Pro, this is probably unnecessary though.
Also, 0.7A is 700 mA, and this exceeds the USB port maximum current which is 500 mA.
Most (not all!) laptop drives will run even if under a slight undercurrent, but this depends on USB port electronics and enclosure electronics.
Chances are that you won't be able to run the disk unless you plug it into an externally powered USB hub supplying at least 750 mA per port. The 100-500 mA supplied by your PC's USB port is enough to power the enclosure electronics and the host controller, but not enough to get the HD to spin properly. As a result, the HD can not be initialised and the enclosure will report an error.
Some hard disk enclosures come with a "USB Y Cable" or "double power cable" which joins two USB ports to get double the current, and can support HD up to 1.0A. If your enclosure comes with one of them, try that first.
Posted on Nov 02, 2009
yooperbud
  • 8637 Answers
SOURCE: in my laptop toshiba webcam iz nt working frm my
Web Camera's have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ )
set it up as follows:
Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
Then click on the Video Settings.
The camera, if Installed Properly, it will come up and show a video picture.
Then, on the bottom of the page click save.
The camera and audio should function properly. Your friends and Family will now be able to see and hear you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.HTML )
Go to Messenger at the top left and click on it.
Next go down to Preferences and click on it.
Next "Calling and Devices" on the right, set the Microphone and Speakers to the computer Audio Card or headphones/mike.
Next go to the Test Audio section below where you just setup the microphone & speaker and (written in blue) click on "Open the call setup assistant"
and the "Yahoo Call Setup Assistant" window will open to the left and follow the the instructions. Click on FINISH and the audio will be setup.
Next go to "Webcam" and click in the circle "Allways allow the following people to view my webcam.
Next Click on "Super Webcam" snd in the circle click "Start Super Webcam mode automatically".
Then click OK and it should work.
C. Windows Live Messenger:
http://www.microsoft.com/downloads/details.aspx?familyid=d78f2ff1-79ea-4066-8ba0-ddbed94864fc&displaylang=en
After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
Then on the Windows Live messenger window on the right side, click on " "Show Menus." And then click on "Show the Menu Bar".
Next go to the Menu Bar on right side, click on " "Action."
Go to "TOOLS" and click "Audio and Video Setting" and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
D. AIM (AOL) Messenger:
http://dashboard.aim.com/aim
On the VIM sign-in window, click on Edit.
Then click on Settings Enhanced IM.
Next click on Enhanced IM.
Then click on Audio Video.
The Audio and Video portion has drop downs so you can select the proper audio card and video camera installed in you computer.
The Audi Video drop downs are
Microphone
Speaker
Camera
The audio and camera should function now.
Additional information to use with VIM settings.
Adjust Your Audio and Video Settings:
In order to adjust your audio and video settings, please follow the steps given below:
1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window. If you are currently
Participating in an AOL Live Video IM session, a message will display: You must disconnect the current AOL Live Video IM
conversation before running setup. Would you like to disconnect now? Click the Yes button.
2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working
Properly. Follow the on-screen prompts.
Notes:
The first time you use AOL Live Video IM, a message will display: Would you like to first check your audio and video settings? Click the Yes button.
The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly.
images in AOL Live Video IM may appear reversed, or as a mirror image (text may appear backwards) when you look at your own camera feed or at the
Picture-in-picture (PIP) display.
After making the settings your ready for a chat and video talk with your Family and Friends. Hope this helps. Bud
Posted on Feb 16, 2010
Sony Vaio VPCCB45FN exmor Hd web camera not working.....the green light besides the camera does not glow...neither does any webcam software detect the camera. The device manager shows a yellow exclamation...
Open device manager and uninstall that camera driver. After uninstalling click on CHECK FOR HARDWARE CHANGES, it will automatically detect and install the driver, if still doesn't work, take it to the service center.
Sep 08, 2013 | Microsoft MTP Device
Toshiba built in web cam not working
Remove both Webcam driver and skype with a software called Vista Manager from yamicsoft.
Why a third party tools to uninstalled a software?The answer is it will remove even the files or registry key that is concern with that software.
Download the file using the link below
http://www.yamicsoft.com/vistamanager/software/vistamanager.exe
If you are with windows 7 then downalod Windows 7 Manager
Here is the link :
http://yamicsoft.com/windows7manager/software/windows7manager.exe
after unstalling reboot your system.
First installed your webcam driver and check webcam work or not. Then installed skype software.
It will work.
Note: Lastest skype version have problem with webcam synchronisation.so used a little older version.
Dec 28, 2009 | Computers & Internet
Hi, i have a toshiba L355 S7812 and just upgraded to 7 -- everything seems to work except for the built-in camera, and i cant find a driver/program for it....the toshiba program from vista doesnt work....
If the Vista Driver Doesnt Work, You Will need to search out a Driver from Different Make/Model... OR install software such as Driver Genius or similar to Install the correct driver for you...Or... try uninstalling and rebooting..
1) Bring up the device manager. You do that by clicking on Start button and then type 'Device Manager' in the search box. Select the "Device Manager" in the list.
2) In the list of devices, you will see "Chicony USB 2.0 Camera" with yellow bang on it. You will see either code 19 or code 1 as error codes.
3) Right click on the device and then select "Uninstall".
4) In the uninstall dialog, make sure you select the option to delete the driver package from the system. This causes the driver package installed earlier to be deleted.
5) Then in the Action menu of Device manager, select Scan for Hardware changes option. This will cause the device driver to be reinstalled.
Nov 23, 2009 | Computers & Internet
I RECEIVE AN ERROR MESSAGE: "WEBCAM OPEN DRIVER FAIL"
Remove the webcam driver and then clean the registry using something like Ashampoo (free use for 30 days from www.ashampoo.com) then reboot the laptop. Download the updated driver from Toshiba at
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=2184601&rpn=PSLD9U&modelFilter=L350-S1701&selCategory=3&selFamily=1073768667
Install it and then reboot.
All should now be OK.
Sep 11, 2009 | Toshiba Satellite Pro L350-S1701 Notebook
Stopped working
Hey,
Goto device manager by right-clicking My Computer-> properties-> hardware-> device manager.
There in mice and other pointing devices category, select your mouse, uninstall it and refresh the page.
It should automatically detect your mouse.
Thanks
Apr 15, 2009 | Toshiba Black/Red USB Laser Mini...
Dvd rw is not detected in windows xp in my toshiba a75 laptop
Kindly follow the following steps..
1. Go to Device manager. Click on the + sign beside IDE drives. Right click on the dvd drive and select uninstall. Restart the computer. It should get installed automatically as it is a generic driver.
2. Go to run > type regedit > go to the following key
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\
Select the folder that says ( 4D36E965.....
on the right hand side delete the file that says "Upper filters" and "Lower filters"
3. Go to device manager > click on the + sign beside IDE ATA ATAPI Controllers > right click on Secondary IDE channel and select uninstall. Do the same with Primary IDE channel. Restart the computer.
4. Reseat the dvd drive.
Hops this helps..
Regards,
Anup
Apr 07, 2009 | Toshiba A75-S125 Satellite Notebook
I got problem in networking
It is a general problem for all TOSHIBA laptops. Its pretty hard to detect toshiba's in network. Trying using another driver software after uninstalling the current one.
Mar 06, 2009 | Toshiba Satellite A60 Notebook
TOshiba Laptop. Sound doesnt work
go to device manager and uninstall the sound drivers and restart the system and if the drivers are automatically detected good enough if not install the drivers again
Nov 01, 2008 | Toshiba Satellite A135-S2276 Notebook
Toshiba S2450 PS245E Laptop Heating Problem
toshiba 2450
1 clean the cpu radiator 2 make sure the fan works, 3 install toshiba common modules and toshiba chipset drivers. 4 go into bios and set devices managed by the os.
Dec 24, 2007 | GPS
Toshiba PA3554U-1CAM Webcam Logo
77 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
