Question about HP Photosmart C3180 All-In-One InkJet Printer
Bought used Photosmart C3180 printer. Need to know how to insertcartridges. Thanks
  • 80 Answers
To insert the ink cartridges, follow these steps.
1. Make sure that the printer is plugged in to an electrical outlet. Power on the device using the power button, and wait approximately 30 seconds for the printer to fully initialize.
2. Insert paper into the paper tray, as you will have to print an alignment page once the ink is installed.
3. Open the print cartridge door on the far right side of the printer. It opens downward.
4. Wait for the print carriage to move to the right side, aligning the ink with the cartridge opening.
5. The tri-color print cartridge is on the left and the black is on the right. Lightly press down on the empty ink cartridge to remove it.
6. Remove the packaging from the new ink cartridge, including the plastic pull tab covering the metal connectors.
7. Slide the new cartridge forward into the empty slot, then gently push forwards on the upper part of the cartridge until it clicks into the slot. Repeat for the other cartridge if necessary.
8. Close the print cartridge door. An alignment sheet will print with instructions for scanning it.
For more information, here is the link to the C3180 manual. Information about replacing an ink cartridge begins in section 7.
http://h10032.www1.hp.com/ctg/Manual/c00695211.pdf
Posted on May 24, 2011
  • 38 Answers
For this particular printer, there are two slots, one with a green triangle and another with 2 different shapes. The left one is for colour and the right for black ink.
First you want to pull the desired cartridge out by putting a finger on both top and bottom and it should literally slide out (if it doesn't first time lift it up slightly first). Save the cartridge for future refill and the cartridge you want to put in you hold the same way and again from the bottom just literally slide it in. You should be able to click it in once it is all the way - this indicates it is in correctly, the printer should now run a test print
I want to use my printer HP C3180 with another computer which is not connected with the one the printer is connected before . I lost the CD driver. How I download the right HP driver?
Here is the HP site for your printer:
HP C3180 Support
There are links for several things, including the drivers you will need.
For future reference, put this site in your favorites.
Thanks for using Fixya.
Jun 26, 2011 | HP Photosmart C3180 All-In-One InkJet...
Hpvista will not accept downloading my hpphotosmart3100
Could you give me the exact model of the photosmart printer. In order to better help u out. 3100 series printers had compatibility problems with vista .
Thanks
proton
Jun 25, 2008 | HP Photosmart C3180 All-In-One InkJet...
I BOUGHT A NEW COMPUTER WINDOW 7 AND MY PRINTER HP PHOTOSMART C3180 IS NOT COMPATIBLE WITH THE CD THAT CAME WITH IT
no issue you can download the compatible driver from this side
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=1146331&lang=en&
just select the operating system and start downloading. if you face any problem let me know.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Feb 22, 2010 | HP Photosmart C3180 All-In-One InkJet...
Region codes for France for a photosmart c3180 all in one
Well I had the exact same problem with a C3180 bought in the USA and I moved to France. I called the HP tech support and after I bought 5 brand new cartridges upon their recommendation we haven't been able to print the 10 tap test page
I recommend that you try doing that before you call them otherwise you will be wasting your time
To print the 10 tap test page you need to press simultaneously CANCEL and START COLOR COPY. I couldn't print the 10 tap test page because the printer will not recognize the cartridges bought in France (START COLOR COPY and START BLACK COPY blinking + E in front of COPIES)
If somebody knows an alternate method to print the 10 tap test page, please share it as this is the blocking point with HP support
Thanks
Feb 10, 2010 | HP Photosmart C3180 All-In-One InkJet...
I need an installer for my HP F3180, i hope somebody can help me. i can't find my disc installer, its been years since i bought this unit. Thanks, Dindo
what type of printer are you using? a deskjet or an all-in-one printer.try any of this two.
  1. HP Photosmart C3180 all-in-one printer. http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=oj-40663-2&lc=en&dlc=en&cc=us&lang=en&os=228&product=1146331 or you click on this AiO_071_000_201_000_CDA_Default-Express_NonNetwork_AmericasEuro1.exe, (1/1 , 298.43M)
  2. HP deskjet C3180. http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=25157&prodNameId=12621&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=pl-10683-3
Cheers
Apr 17, 2009 | Office Equipment & Supplies
I'm trying to scan in a document and then fax it using HP Photosm
Unlike most scanners, you must put the page that you want to copy in lower right corner of the glass (notice the small arrow pointing to the corner). This should fix any problem with an image being cut off. As far as faxing, I don't think the C3180 is able to fax pages. Hope this helps
Feb 05, 2009 | HP Photosmart C3180 All-In-One InkJet...
Change regional code from europe to us for hp Photosmart C3180
Currently, it's a very convoluted process involving a phone call to HP tech support. Unless things have changed, you are also restricted to changing the region code 3 times over the lifetime of the printer. Having said that...see this page here at FixYa:
http://www.fixya.com/support/t465196-change_region_codess_printer_hp_c3180
HP Tech Support number is: 1-800-474-6836
Dec 12, 2008 | HP Photosmart C3180 All-In-One InkJet...
HP Photosmart C3180 All-In-One InkJet Printer Logo
74 people viewed this question
Seeker5211
Seeker5211
