I have a Qwest Modem - M1000. I bought a DIR601 router so my some could use his Kindle. When I try to access the internet, I get "modem cannot connect to DSL line."
  • 984 Answers
Let's see if I can help you.
Begin by turning on your computer and your router
  • Open Internet Explorer;
  • Click on 'Tools';
  • Click on 'Internet Options';
  • Click on 'Connections';
  • Click on 'Setup'
  • Click on 'I want to set up my Internet connections manually . . .';
  • Click on 'Next';
  • Click on 'I connect through a local area network (LAN);
  • Clock on 'Next'
  • Click on 'Next' [This is not an error];
  • Click on 'No';
  • Clcik on 'Next';
  • Click on 'To connect to the Internet immediately . . .; and,
  • Click on 'Finish'.
That should have you online
All the best
Ben
Posted on May 24, 2011
Where can I get a quest m1000 mnual for a quest m1000 modem
Here's a link to the quick setup guide:
http://setuprouter.com/router/qwest/m1000/manual-596.pdf
and Centurylink help site:
M1000 Actiontec Modems
Note: Google searching for actual .pdf manual results in links to hacker sites, be careful.
Nov 11, 2014 | Actiontec M1000 Dsl Wifi Modem In Box W/...
D Link Router "Does not appear to be working"
I think you should try to reset and reconfigure the router.
Connect your computer directly to the modem and make sure that Internet is working through the modem.
Connect the modem and computer to the router and try to reconfigure it.
See how to setup router
Mar 18, 2012 | D-Link Wireless N 150 Home Router 4Port...
How do I connect to a qwest dsl m1000 modem
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Aug 20, 2010 | Linksys Wireless-G WRT54G Router
My router won't work with my Qwest modem.
Are you trying to set up the router.
You can do it manually without the CD.
When you connect the computer to the quest modem, does it work?
Then you need to connect the computer to the router ad the modem to the router.
Click Here for step by step by instructions
Feb 07, 2010 | D-Link Computers & Internet
My DIR-655 won't work!
It would be helpful if you could be a bit more specific regarding the way you hooked up the dir 655 to your network and your specifc DSL modem. If the modem you are using is the Actiontec M1000 DSL modem you will not be able to obtain internet access because the DIR 655 is trying to route an already routed IP, the M1000 has a built in router / DHCP that by default is enabled. You can use option 1, access the configuration settings of your M1000 and change the WAN configuration to act as a transparent bridge. After doing so and rebooting the modem you will have to enter your DSL login information like a PPPoE username and password for example into your DIR 655 network settings. With this configuration the modem simply acts as a bridge to relay data directly to the DIR 655 and the 655 itself provides login credentials to obtain internet from your DSL provider as well as hand out IP addresses to the local network. Option 2 is to continue to use the M1000 as a router by default and disable DHCP on your DIR 655 so that it essentially acts as nothing more than a switch or wireless access point while the M1000 hands out local IP addresses. I personally would recommend using the DIR 655 to route IP's as it's got far more configuration utilities than the M1000 does as a router, and really what's the point of getting the 655 if you're only going to use it as a switch or access point when there are other simpler and cheaper devices that could do that for you.
Jul 20, 2009 | D-Link Xtreme N DIR-655 Wireless Router
I need instructions for a Linksys Wireless G router to work
Call your internet provider they will walk you thru the process.
Jun 18, 2009 | Linksys Wireless-G WRT54GS Router...
Problem between my Qwest actiontec modem and D-link router
You need to sign into the dlink router and check the status tab, to make sure that the router has picked up the modems IP address. it sound like it hasn't, and is just assigning lan IPs to the client machines, butd oes not have a valid WAN IP to the internet.
If it hasnt got a wan ip, you want to do a hard boot on the router .unplug the router ONLY for 30 sec, and power back up the router only ...not the modem this should allow the router to find the modem IP
Dec 30, 2008 | D-Link DIR-625 (790069292637) Wireless...
D-link 614+ will not connect with Qwest M1000 modem
Well what everybody really doesnt know is that if Qwest provided you with a modem named Actiontech that modem has the same ip address of router so just change routers ip address to 172.16.0.1 and subnet mask to 255.255.0.0 and the problem should be solved.Im a product specialist for dlink.
Aug 27, 2008 | D-Link AirPlus DI-614+ Wireless Router
We recently got high speed internet from Qwest. It will not work. It keeps saying that the can't "ping" it. All light are green; power DSL, and the Ethernet. The internet is not. I have...
The DSL router/modem will receive an address from your ISP (Qwest) and will assign an address to the connected PC.
There should be a cable that goes from your DSL modem to your PC. It'll either be a USB cable (flat rectangular plug on the PC end), or a RJ45 (looks like a wider telephone plug).
If there is neither connection between the DSL modem and your PC, then the PC can't "talk" to the DSL modem, so it's not getting an address from the DSL modem.
Apr 06, 2008 | Computers & Internet
Computers & Internet Logo
88 people viewed this question
David Payne
David Payne
