Question about Elmo Projectors TRV-35H Slide Projector
Slide advances OK, but it goes down projects the slide and immediately goes black.....sometimes it will show slide, but top of slide is black or if it shows slide something comes down, and makes the top of the slide black. It actually worked OK once when I tried, but can't get to work......
  • Jim Auburn May 25, 2011
    Is this a Kodak Slide Projector? If so, what model? This would be a big help solving your problem. Thanks!
    Problem Solver:
  • 12 Answers
This is caused by the failure of the slide to drop fully down to the slide stop.
I have posted an answer to this for a different enquirer. Have a look at the other answers.
Posted on May 27, 2011
My ignitor wire came out on my Brinkmann Gas Grill
it should just push back on lok at the end of the wire there is a connection on the end round or flat this goes back on to the back of the knob
Apr 21, 2012 | Gourmet Grilling
I was cleaning the carburator and a small black donut seal fell out and i dont know where it goes?
seal goes between top black cover and top of carb. if its a flat slide carb the slide works off vacumn the large spring keeps preasure down on the slide when it when you throttle up the vacumn increase pulls up the slide to increase fuel...that o-ring seals the vacumn passage from the top cover and the body of the carb.. go luck with it..
Nov 08, 2010 | 2004 Yamaha TT-R 225
Please show me how to quickly and easliy delete the annoying Ask when wanting to go to the internet. Thank you, Bill
mcdevito75 Here, hello Bill, here we go, you should have Windows Explorer as a browser / Operating system, at the top of your home page or any page once your on the internet is TOOLS left cick on that, then Click on Internet options, bottom of drop down menu, then click on ADVANCED TAB all the way to the left and on top of Menu Drop down, NOW click on RESET just above the OK Cancel and APPLY tabs. Now Click OK, then APPLY. sometimes the ok is enough if the drop down menu disappears after you click OK once you"ve done everything else you should be good.
Sep 02, 2010 | Computers & Internet
How to insert video in the PowerPoint 2003?
Insert a movie and play it automatically
In PowerPoint 2003, you can run your movies full screen. This is a very excellent feature.
  • On the Insert menu, point to Movies and Sounds, and then click Movie from File.
  • Click the video you want to use and then click OK.
  • Tips: Always put the movie in the same folder as your PowerPoint presentation. If you later move the PowerPoint presentation to another computer, copy the movie too. Keeping your movie in the same folder as your presentation ensures the link will still work. However, you should always test the movie on a new machine just to be certain. Re-insert the movie, if necessary.
  • After you click OK, you' are promoted with a message asking how you want the movie to start in the slide show.
    I recommend choosing Automatically even if you want the movie to play when clicked- I will talk about how to set this part too. (If you choose when clicked you have to click the black box to start the movie. Because I don't like to show the black box on the slide, I do this a little differently.)
  • You should now have a small rectangle sitting on your slide.
  • Insert a movie using a file on your computer or in another location, such as a server.
  • The movie appears as a still frame on your slide.
  • The trick I use is to move that rectangle off the slide, so it is sitting next to it, but not on it. You can size it down if you like. Click the movie (that is, the rectangle) and then drag it off the slide.
    Play the movie full screen
  • Right-click the movie object (the small rectangle) and on the shortcut menu, click Edit Movie Object.
  • The Movie Options dialog box appears. Under Display Options, select the Zoom to full screen check box, and then click OK.
  • If you want your movie to play automatically when you advance to this slide, you can stop here.
Test this now to see how it workd by starting the slide show. (On the Slide Show menu, click View Show.) Advance to the slide with the movie, (best if you have the title of the movie on it). Within a couple of seconds, the movie starts to play full screen. When the movie finishes, you return to the same slide (but no unsightly box appears). Click to advance to your next slide.
Add an On Click effect to start the movie
If you prefer, you can click to start the movie. This requires one more step, setting an On Click animation effect.
1. On the Slide Show menu, click Custom Animation. The Custom Animation task pane appears on the right side of the PowerPoint window.
2. Click the movie object (the rectangle) to select it.
3. In the Custom Animation task pane, click Add Effect, point to Entrance and then click Appear.
You have added an On Click effect. The animation effect you added is the one with the Green star next to it and a gray rectangle around it. If it doesn't have a gray rectangle, click it to select it. Your Custom Animation task pane should look like the picture below (except with the name of your movie in the list).
4. The last step is to move that animation up to the top of the effects list.
To do this, make sure the animation effect is selected, and then click the Up Re-order arrow at the bottom of the Custom Animation task pane. Or simply click and drag the animation effect to the top of the effects list.
5. Your effects list should now look like this:
6. You are done. Test this to make sure it works by starting the slide show.
(On the Slide Show menu, click View Show.) When you advance to the slide with the movie, you should not see the movie. When you click the slide, the movie zooms to full screen and plays. When it finishes playing, you are returned to the same slide. Click to advance to the next slide.
Souce: How to insert a Movie (or video) into PowerPoint 2003?
Jul 06, 2010 | Microsoft Office Professional 2007 Full...
My nokia n95 screen goes on but freezes all the time and i always get a black screen. the fone is still on but the screen is just black it only comes on when i put the fone into music mode ( when i slide...
your cellphone is fine. Its the strip which needs to be replaced.
actually the strip connects the LCD and the navigation keys.
U might have noticed sometimes your navigation keys also don't work.
get your strip replaced n your cellphone will be fine again.
slide up the phone and you will see 2 screws at the top.
get these screws removed and replace the strip and also do change these screws after the repairing.
Feb 09, 2010 | Nokia N95 Cellular Phone
My hp compaq nx9010 notebook is no longer displaying the color black on the Windows xp start up page or on some of my powerpoints and videos. The color black is replaced by a redish color.
It seems that someone changed the desktop background color. point the mouse somewhere in the middle of the desktop, (away from any icons) and right click the mouse, a menu will appear with several options. The bottom one says properties. Click that. Once done another (more advanced) menu will appear with several tabs at the top. Click on the second to last tab, labled, "Appearance". Once in this tab. Toward the bottom right side of this screen you will see 2 buttons one atop another labled, "Effects", (on top), and, "Advanced", (below). Click the advanced button. A new window will pop up with the first option being desktop in a drop-down menu. To it's immediate right you will see "color 1" with a drop-down menu directly below it. That is where you will select the new background, (desktop) color. Once you have selected the new color, click OK, then apply on the remaining screen, then OK once the color is set.
Apr 16, 2009 | HP Compaq nx9010
HELP ME ON MY WS-65613
The whole bottom tray will slide out. Remove the single black headed screw from the middle edge of the tray. There is a plastic lock on each side of the tray. Pull the plastic lock tab up and slide tray out. Remove all wiring from those little plastic twisty thingy's. Once the tray starts to slide, you will see which plugs have to be unplugged. Just pull the tray out about half way. OK. Now the box. Unplug the two plugs from the top. There are two small screws on one end of the box (closes to you) and a screw on each side. Remove all four of them. The metal box will pull up and off the circuit board. Be very very careful. Take your time. Try to hold down the board while wiggling the box and lifting up. There are 80 or so small pins under this box. You do not want to mess them up. Once you have the box out, remove the two screws on the top and the board with he caps will slide out. When you install the box back on the board, make sure you have the pins lined up before pushing it down on the circuit board. You only screw up once. Soory i'm not good a step by step directions. hope this all helps. I did my own about three month ago. Had new caps soldiered on for 35.00 at a electrical shop. Good luck. Jim.
Nov 12, 2008 | Mitsubishi WS-65613 65" Rear Projection...
I have a 913t monitor and about 3 months ago it started to go to a black screen with an error message "not optimum mode recommend 1280 x 1024 60 hz" any help???
Click START-SETTINGS- CONTROLL PANEL - DISPLAY - select the SETTINGS tab at the top - click onthe ADVANCED button (bottom right)- select the monitor tab- in the screen refresh rate dropdown box select 60htz- click on apply & ok - back at the display properties page , slide the slider for screen resolution to 1280x1024- click apply and ok. restart the computer. this show resize your desktop to the correct resolution and refresh rate recommended by your information.
Oct 15, 2008 | Computers & Internet
Sharp 56DR650 shows power but wont turn on, Sometimes it turns on
That's error code 32. Indicates lamp trouble or failure. The system will shut down automatically.
Aug 29, 2008 | Sharp 56DR650 56" Rear Projection HDTV
Elmo Projectors TRV-35H Slide Projector Logo
132 people viewed this question
Top Elmo Projectors Office Equipment & Supplies Experts
k24674
Are you an Elmo Projectors Office Equipment and Supply Expert? Answer questions, earn points and help others
