Question about Hitachi 50UX26B/27K 50" Rear Projection Television
Want come on
Makes a sound when pressing the on key but want come on
  • 927 Answers
Good Day, arods107;
Wont come on? the most common problem for this TV Model is to suspect: Q912, Q913 and I901.
Good Luck, big IRISH.
Posted on Aug 16, 2008
The keyboard was working fine and all of a sudden stopped making sounds. I must have pressed a button.
I've never heard of a keyboard making sounds. I have heard of key presses making sounds. In the control panel under keyboard there may be a setting. The setting may also be under sound or audio (depends on the operating system).
Mar 21, 2015 | Computers & Internet
Yamaha DGX 640 - keys make odd sound
I don't think that is correctable; if it is under warranty, have it repaired or replaced. The yamaha keyboards are great when they work partly because they use sampled sounds; getting extra sounds indicates a bad chip.
May 07, 2017 | Yamaha DGX-640 Walnut 88-Key Keyboard...
My samsung monte slide makes a beep when i send a text, how do i stop this from happening
Choose settings for profiles info.png 1 Find "Profiles"
  • Press Menu.
  • Scroll to Settings and press the Navigation key.
  • Scroll to Profiles and press the Navigation key.
2 Select profile
  • Highlight the required profile and press Options.
  • Scroll to Edit and press the Navigation key.
3 info.png Select settings for incoming calls
  • Highlight one of the following options:
  • Call alert type, go to 3a.
  • Call ringtone, go to 3b.
  • Message alert type, go to 3c.
  • Message alert tone, go to 3d.
  • Keypad tone, go to 3e.
  • Volume, go to 3f.
  • Press the Navigation key.
3a "Call alert type"
  • Highlight the required incoming call alert and press the Navigation key.
3b "Call ringtone"
  • Highlight one of the following folders:
  • Default melodies
  • Sounds
  • Music
  • If you select Default melodies:
  • Highlight the required ring tone and press the Navigation key.
  • If you select Sounds or Music:
  • If required, highlight a folder and press the Navigation key.
  • Highlight the required ring tone and press Select.
3c "Message alert type"
  • Highlight the required message alert and press the Navigation key.
3d "Message alert tone"
  • Highlight the required message tone and press the Navigation key.
3e "Keypad tone"
  • Highlight Mute or the required key sound and press the Navigation key.
3f "Volume"
  • Highlight the required category and press Navigation key right or Navigation key left to select the required volume.
  • Press the Navigation key to save.
4 Exit
  • Press Disconnect to return to stand-by mode.
Jun 25, 2011 | Cell Phones
How do I adjust the color
Hello
To adjust colour and other picture adjustments
[1] Press "Menu" key to display the main menu.
[2] Use cursor UP/DOWN keys to hilight [green]; Picture or sound ; whatever you wants to adjust, and press ENTER.
[3] Use cursor UP/DOWN keys to hilight [green] AUTO [for factory settings] or MANUAL to set picture settings according to your taste. Here you have to hilight MANUAL as you wants to set it mannualy. Press ENTER after selecting MANUAL.
[4] User cursor UP/DOWN keys to select the option you wanted to change.
then cursor keys to make adjustments of the selected option parameter according to your taste.
[5] When you have finished all the adjustments according to your taste, press EXIT key to return to normal tv viiewing. This way you can adjust the sound parameters also. Proceedings are all the same, but the option choose to hilight [green] must be sound. That is all. Ok.
Jan 12, 2011 | Sanyo DP26746 26 in. LCD Television
Won't makes a sound when pressing on keys. I
you may need a new keyboard,, the beeping sound when pushing keys means there is a sticky key [bad keyboard]
I dont know what option you changed for the keyboard speed? try changing it back..
May 16, 2010 | HP Pavilion dv6000z Notebook
I own LG VX8360 and can't figure out hoe to turn ringer on. Can you help me?
To restore the ringer it will depend on what mode your phone is in:
Vibrate Mode:
Sets the phone to vibrate instead of ring.
To set Vibrate Mode, with the flip open, press and hold the # key .
To return to Normal Mode, press and hold the # key again.
Sounds Off Mode:
Quickly deactivate your phone's sounds when you're in a place where phone sounds would be disruptive.
From standby mode with the flip open, press and hold the lower side volume key for 3 seconds. To return
to normal sounds mode, press and hold the upper side key.
Airplane Mode:
Turning on Airplane Mode will disable all wireless communications.
1) With the flip open, press the Menu key.
2) Use the Directional Key (top center of phone) to scroll to 'Settings and Tools'.
3) Press the 6 key for Phone Settings.
4) Press the 1 key for Airplane Mode.
5) Use the Directional Key to highlight a setting, then press OK.
On/Off
Mar 30, 2010 | LG VX8360 Cell Phone
I have a Samsung U900 and cannot turn off the key sounds without
to solve this at the main screen press volume down and u will get a pop up saying key tone volume keep pressing unil it reaches 0 and there will be no key pad sound but music etc will still work fine
Dec 07, 2008 | Samsung U900 Soul Cellular Phone
Keyboard buttons clicks before typing
Sounds like he may have turned on the "Sticky Keys", to turn this off , tap the shift key 5 times....should take care of it!
Oct 01, 2008 | Dell Dimension 3000 PC Desktop
Open Questions:
Televison & Video Logo
37 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
