Want to know how to hook up to my TV, Sharp Aquas. Have 2 SB-926, I assume L and R, Then the middle speaker SB-C936
  • 643 Answers
You will need an external amplifier to power the speakers. You can not just hook up speakers, you might short out tv. If wanting surround sound you need to find a receiver thats 5.1 Usually around 199.99. Hope this helps.
Posted on May 24, 2011
Sharp aquas code 3 flashs 1 quik flash what is the code
It sounds that your TV has Philips main board fitted. This kind of flash pattern is of Philips.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Nov 29, 2016 | Sharp Televison & Video
My logitech speakers mo.ls11 sound is blurred when volume is increased
Adjust the volume level of the TV to low while the Logitech Speaker volume is at the middle... try changing volume of both TV and speaker to achieve satisfying results.
Apr 26, 2012 | Logitech Audio Players & Recorders
I am trying to connect my bose cinemate speaker system to my new sharp Aquos Quattron tv but I am not having success. I called Sharp and she told me to put the TV on the variable select mode but this is...
I assume you have everything hooked up? You should have the Audio Out from your interface module connected to the Audio IN of the TV. The sound should be set to fixed, not variable. Variable means you control the sound output from the TV which controls the sound from the Bose. Not Good. Sound quality is not as good and confusing to customers. Make sure your selecting the right tv input on the Bose system. You should be good to go.
Dec 27, 2010 | Sharp Televison & Video
I have a sharp cant get the comcast remote to turn on tv it just turns the box on can u suggest help
Try these codes for sharp LCD tvs: 10093 or 11602. I found them in the concast instructions on line. they worked on my Sharp aquas tv.
Mar 14, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
A ball hit my liquid plasma sharp tv
The cost of purchasing a replacement screen will exceed the value of your television.
Aug 31, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Dark line down the middle of the screen
There are two sets of wires internal to the LCD. one of the wires has come loose. Complete dissassembly and reassembly should solve the problem. (use electrical contact cleaner on the gold tabs that insert to the LCD)
(take it back if under warranty, and haggle to get it replaced even if it isn't first. Following the above procedure is an easy way to break the light tubes if you're not super careful.)...
Apr 19, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
SB speakers error
I had the same problem but fixed it (no thanks to what I believe is an oversight by Pioneer!). The amp is a 7.1 system. What we are assuming is the rear surround (SB) is the default using a 5.1 setup. The amp uses the SR & SL as the default. So the solution is plug your rear speakers into the SR & SL & you should have your surround! (only took me 6 hours to figure this out, hope it saves you time!)
May 01, 2008 | Audio Players & Recorders
Sound won't play thru stereo from t.v.
take the main tv digital opti outto sterio ok on ch or from dish box to sterio on a ch
Feb 02, 2008 | Onkyo TX-SR605 Receiver
Sharp aquos LC 37D43U
If you have satellite, I am assuming you at least have a converter box hooked up. If so, make sure the converter box volume is set at its max. There may even be a volume setting in the converter menu that forces the volume output of the box to always be at full so that you don't get variations in audio when changing channels. Warning...before attempting this, please turn down the volume on your tv to at least the middle setting so you don't blow your tv speakers if this works.
Jan 20, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
Electro Med Services...
