Question about Staples ID Armor IDX50B Shredder
Motor is burned up, would like to purchase a repacement motor. modle # ID armor ID 1506x
  • 43,501 Answers
Have seen many people looking for parts for these small shredders here on fixya....have not seen that you can buy parts anywhere yet...
They really don't want you to fix them I think, they want you to chuck it and buy new...
heatman101
Posted on May 27, 2011
Where can i buy parts for my id armor shredder
Your question, while it does state "parts," doesn't specify which parts. The reason why my answer isn't going to tell you, is because the "parts" can vary from the safety flap all the way to the motor that drives the shredder blades.
My suggestion is that you find where you can be eco-friendly with the shredder's disposal and purchase a new one. If you are looking for a part that has anything to do with the workings of the shredder (blades, on/off switch, paper sensor motor), you are going to wind up spending almost as much as a new one would cost and perhaps even more. Plus you have to take into consideration, the time you would spend doing the repairs; surely your time is worth at least $10 an hour. You are most likely going to spend too much time making the repair. Believe me, I tried to fix one once (it was successful, just the "bellows" that expands to change the setting of the "normally off" micro-switch back to off) and it took me a couple of hours.
Purchase a new one and forget about "saving" money by doing the repair yourself.
Jul 13, 2014 | Staples ID Armor IDX50B Shredder
Why is my ID Armor ID-XC200D making a horrible noise when I shred?
kkrenn641:
That "horrible noise" is probably caused by the shredder gears meshing improperly. If you disassemble it again and look carefully at the gears, you will most likely see that some are not mating properly... Usually the motor gear and the first idler gear that meshes with the motor gear. If those two gears seem to be separated a bit, or slightly mis-aligned look carefully at where the motor mounts, and you may see that the plastic "bed" where the motor is mounted has melted from heat from the motor. This is caused by using the shredder too long without letting the motor cool down. You may be able to shim the motor housing to realign the gears, if you have the patience!
Sep 13, 2012 | Staples ID Armor SH2836ID2836 Shredder
Just keeps running but blades do not turnn
The motor is connected to the shredding rollers with gears or a belt. Sounds like they are broken, unplug then take it apart and check.
Mar 08, 2011 | Staples ID Armor SH2836ID2836 Shredder
Need a manual and diagram for under dash computer repacement
need make modle & year, but I have to tell tou that 95% of returned computers to our reman facility have no faults. So you are probably wasting your time and money.
What is the issue?
Feb 02, 2011 | Ford Explorer Sport Cars & Trucks
For the ID Armor ID-XC200D, where should I place the shredder oil?
You don't use liquid oil. At the office supply stores they carry oil sheets that you insert just like shredding something. They come ion various pkgs. Staples and Office Depot stores carry them. They are universal, no model number needed. I hope this helps.
Nov 02, 2010 | Staples ID Armor SH2836ID2836 Shredder
It doesn't even power up- could I have burned out the motor? The strip it's plugged into is working with other machines
Did you remove the top to clean recently? You may not of installed it correctly. Keeping the saftey switch from making contact. It thinks the top is still off and it won't run without the switch making contact. Try resetting the top a couple of times to insure the switch is tripped.
Jun 28, 2010 | Staples ID Armor SH2836ID2836 Shredder
Washer stopped during wash cycle, burning smell
http://www.appliancepartspros.com/Appliance-Parts/Dryer-Parts/index.aspx Take a look at what a new motor costs for your machine and go from there. Is may not be a motor is could be a belt or a bearing. I rebiult a washer for less then 50 dollars that one did not need a motor just bearings and a belt. I would take the washer apart so you can get an idea of what went wrong and then look at parts to repair it and decide what to do good luck
May 23, 2009 | Maytag PAV3240A Top Load Washer
The blades are stuck in reverse
I have the exact same problem. In fact, my SPL-1506X is sitting disassembled on the kitchen table as I write this. There is a PC Board inside the unit with a relay that directs the motor to run in forward or reverse. My relay is fused in the reverse position. I know this because the relay's casing is clear polycarbonate. If that relay can be replaced, the SPL-1506X will be fixed, I'm convinced. Unfortunately, the relay is made in China. So much for quality! I located the part no. on the web: Sanyou SME-2110DP a DPDT relay. If you can find it(which I can't), you're in luck. Myself, I'm going to trash the unit.
Jan 14, 2009 | Office Depot Ativa DQ60M Shredder
Ativa SPL 1506X not working
I had the same problem. I took the machine apart and found out that the main gear running the rollers was defective. All of the cogs were broken or worn out, If you can find parts it can be fixed?
Nov 29, 2007 | Office Depot Ativa DQ60M Shredder
Staples ID Armor IDX50B Shredder Logo
320 people viewed this question
Top Staples Office Equipment & Supplies Experts
 Bob Buchholz
Bob Buchholz
ray gallant
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
