Question about Jacuzzi Bath Perfecta EZ33 959 White round high-performance toilet
After I flush my Jacuzzi Perfecta toilet, the tank takes two to three minutes to fill. It sounds like it is running forever to reach the water level line. I have never heard any toilet take this long to fill. Why does it do that and what can I do to correct this so it fills faster? I had this installed around November of 2010. It has done this since I had it installed by Lowes service man. It is the toilet, not the installer.
  • 3,315 Answers
The inlet feed that fills the toilet is blocked slow to fill needs cleaning out .
Posted on Jul 12, 2017
picatudo
  • 239 Answers
SOURCE: toilet not flushing properly
there are allot holes around rime inside they get clogged over time because water quality very hard to get there to clean best bet replace toilet
Posted on Jan 04, 2009
tbirdfan1
  • 3051 Answers
SOURCE: tank won't fill unless I push down on flush valve inside toilet
Hello there
ok first when the valve inside of the tank is wearing out or is dirty this will happen you can take a washrag and clean the underside of themechanism really good and also the part that it rests on providing that you can get to it
if there are no screws to adjust the water reg valve see if it will turn clockwise to shorten the arm making it turn off or if needed turn it counter clock wise i have had to also slightly bend the arm down in some units to make the water stop after the tank is full so you may want to try that too ok
hope that this helps
best regards michael
Posted on Sep 13, 2009
  • 138 Answers
SOURCE: Tank not holding fill level...
Most likely, you do not have a good seal on the flapper valve at the bottom of the tank. To confirm, try this:
Turn off water and flush toilet. Then lift up the flapper valve and put a light coating of vaseline on the mating surface where it contacts the toilet tank when closed.
Turn water back on and see if it continues misbehaving. If that fixes it, it was a bad seal. Usually that is all it takes.
Posted on Dec 15, 2009
jeff_drakesr
  • 155 Answers
SOURCE: how to assemble tank to bowl
  1. Place the Rubber Donut on th bottom side of the tank (this will form a seal from the tank to the bowl)
  2. There are two small holes to either side this is for your two tank bolts. Place a washer on both bolts and place them in the two holes with the head of bolt and washer inside the tank. Place tank on bowl, matching up the holes.
  3. there are two plastic nuts that are beveled on one end, with bevel up toward bolt head thread onto bolt finger tight. Repeat for remaining bolt.
  4. Apply a little pressure to one side of tank and tighten nut finger tight again then repeat for other side. May need to do this a couple of times back and forth. IMPORTANT tight the nuts equally and carefull not to overtighten or you will crack the tank ONLY FINGER TIGHT.
Good Luck and have a Great Day. Please give a 4 THUMBS UP if this free answer was helpful. THNX
Posted on Apr 01, 2010
  • 81 Answers
SOURCE: We bought the Jacuzzi Perfecta toilet 1 year ago
The complication here is that Jacuzzi does not make toilets anymore than Sears makes refrigerators. In Sear's case their Kenmore refrigerators are from Whirlpool with the Kenmore name.
It is my understanding that Eljer was the manufacturer of the toilets with the Jacuzzi name typically sold at box stores. With that as a starting point, surf the web for any Eljer toilet tank replacement parts and see if you can find a similiar flusher
Posted on Jun 02, 2010
Why would the jacuzzi perfecta toilet handle comes off and now won't fill, just keeps running
Handle retaining nut either came loose or broke off. Check the flapper valve, if its not completely closed water will keep running out, and fill valve will stay open trying to fill the tank.
Aug 30, 2014 | Jacuzzi Perfecta White Round 2-Piece...
Why is it taking so much long to tank to fill?
Disassemble the valve assembly. It probably has mineral deposits in it. If this doesn't do it, replace the whole assembly. Costs 8-10 dollars
Jan 11, 2013 | Jacuzzi Bath Perfecta EZ33 959 White round...
I have a Jacuzzi Perfecta commode. It has worked fine until all of a sudden, the tank began filling very slowly. It now takes from 5 to 7 minutes for the tank to fill. I've replaced the flush valve,...
keep going...i mean disconnect the supply line from the fill valve, hold the line into a bowl/bucket and slowly turn the water on. is there pressure? sorry for delayed response if you text me back i will try to answer expeditiously:)
Jul 26, 2011 | Jacuzzi Bath Perfecta EZ33 959 White round...
I just installed a new perfects. The pool of water in the bottom of the bowl is small, how do i increase the pool of water in the bottom of the bowl.
The toilet you just installed is a 1.6 gallon flush water saver and will not have the same amount of water in it that your old 3.5 gallon toilet had. The water level may not be able to be raised as this is the nature of the beast.
If you can raise the level it will only be a little and will be done in the tank area by increasing the water level in the tank. If the water level in the tank is at the mark provided it a done deal.
The amount of water refilled into the bowl is done by the tube that runs from the fill valve into the overflow tube of the flush valve so if you put more water into the tank more water will be put into the bowl but the bowl will only hold as much water as the trap weir will let it hold (what the factory has sit it at and is not changeable
Mar 07, 2011 | Jacuzzi Bath Perfecta EZ33 959 White round...
I have a Jacuzzi Perfecta toilet (bought Aug. 21, 2008) at Lowe's. I have the sales ticket. The toilet works fine. The tank fills very slowly (2 minutes) before it shuts off. It also makes a whistling...
Have you tried shutting water off and take top of valve appart and flush it out. It may have something in valve causing water to be restricted. It will have an arrow on it to direction to get it to come off.
Take appart and clean rubber disc and you can put something over top of valve , a small cup or something to enable you to flush the tank. Have someone help you and hold the cup above the valve so that when you turn water on for a few bursts to flush out the valve it goes into tank.
The actual stream that flows through valve is restricted down to almost 1/8 " opening so it wouldn't take mush to block the flow of water.
The disc you take out you can replace it, if it seems to be damaged and not working correctly. That will affect the flow also.
Jun 10, 2010 | Jacuzzi Bath Perfecta EZ33 959 White round...
Dec 15, 2009 | Jacuzzi Bath Perfecta EZ33 959 White round...
Super low water level in bowl decreases after flush refills
First, fyi, adjusting the knob? in the tank, or the fill level will not increase the amount of water in the bowl. The bowl fills to a certain point, and then as more water is added it starts to go over the built in trap, and down the drain. When you flush the toilet, all the water in the tank dumps into the bowl, and the existing water is pushed over the trap and down the drain. All of this being said it sounds like you may either have an internal crack, between the bowl and trap; you may have a crack that is draining under your toilet, (water spots?), or you have a more serious plumbing issue, improper venting, which is causing a vacuum, and pulling the water out. Hope this helps.
Jun 16, 2009 | Jacuzzi Bath Perfecta EZ33 959 White round...
Water level drops in bowl after it fills
If very little water is used on initial flush, The bowl is functioning as a tank for second thorough flush. The high water level cannot stay high in the bowl while in motion or you would have a mess ion start and stops.
May 28, 2009 | Jacuzzi Bath Perfecta EZ33 959 White round...
Replace your stopper at the bottom of the tank. While you do hat you should also just go ahead and replace the float. 25 dollars for everything and 10 minute worth of your time
Feb 14, 2009 | Jacuzzi Bath Perfecta EZ33 959 White round...
Jacuzzi Bath Perfecta EZ33 959 White round high-performance toilet Logo
2,660 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
armylifer
Level 1 Expert
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
