Question about Canon NP 6050 Copier
Error code e013 displayed and a sound of cut cut is happened
  • Canon Expert
  • 1,326 Answers
I believe a E013 error code means that the waste toner feed screw is packed with toner and can not turn the feed screw. From what I remember, there is a switch on the drive gears for the waste toner on the back ofthe copier. It is not a Happy, happy,joy,joy job...... You will need to clear out the feed screw & empty out the waste toner bottle and possibly cln out the drum unit... Toner is packed there as well...... Good Luck
Posted on May 25, 2011
Error E015
http://printermanua.blogspot.co.uk/2014/03/canon-error-code-e013-e014-e015-e016.html
Jun 03, 2015 | Office Equipment & Supplies
My Canon Laser LBP 5970 display tell: E013-0001. What kind of error is it?
My Canon Laser Image runner c2058 display tell:
E013-0001.
Apr 29, 2011 | Office Equipment & Supplies
Error code E000013-0001
getfile.asp?rid=1258 February 2, 2005 getfile.asp?rid=3215 Product : imageRUNNER C5800 / C6800 Title : E013 code and Waste Toner Full message Question :
The copier shows an E013-0001 and "Waste Toner Full" message. The Waste Toner Bottle has been emptied and SW1 is operating properly but the code and the message are still appearing on the display.
Answer :
The counter for the Waste Toner Bottle needs to be reset back to zero in Service Mode.
Enter Service Mode level 1 by pressing * 2 8 *, select Copier > Counters > MISC, then highlight WST-TNR, press Clear - the counter will zero out.
Power off the copier, turn the copier back on, the Waste Toner Full message on the display should clear out.
Canon USA, Inc. Systems & Technical Support Division 1-800-528-2830
Dec 22, 2010 | Canon imageRUNNER C6800 Copier
Error problem e013 view machine
If I rember correctly a E013 error code means that there is something causing a drag in the copier. Do you hear a clicking sound before it codes out? I would look in the fuser unit and see if the cleaning web is wraped around the upper fuser roller or if the Lower fuser roller is cut and causing the fuser not to turn. If that turns OK, I'm almost sure you may have a packet waste toner aurger or waste toner tube is cluged. If that is the case you will have a packet AP kit... Good Luck
Jul 10, 2010 | Canon NP 6545 Copier
Canon CLC 4000 Error code E013-0002
DESCRIPTION:
THE WASTE TONER LOCK DETECTION
SWITCH (SW4) HAS BEEN PRESSED FOR O.1 SECONDS OR MORE.
Solution: the waste toner is FULL.you have to get rid of that TONER.
Nov 04, 2009 | Canon CLC 4000 Copier
Canon 6050 E013 error
E013 usually means used toner transport jammed
Aug 14, 2009 | Canon NP 6050 Copier
Error code E013-002
A E013 is a code that is refering to the waste toner screw is not turning. The feed screw is packed withe toner. you have to unclug the waste toner tube. It's a very unpleasant job, Good Luck
Jan 04, 2008 | Canon CLC 1000 Color Copier
Canon NP6050 Error code E013
E013 refers to the waste toner receptical being full, but in this case the toner melts at the end of the worm screw assembly causing the cleaning unit to block up, activating the microswitch which tells the machine the waste toner bottle is full. The solution is to try to free up the worm screw assembly, failing that, replacement of the drum cleaning assembly.
Dec 07, 2007 | Canon NP 6050 Copier
Canon NP 6050 Copier Logo
109 people viewed this question
old marine
old marine
