Question about LG 24 in. LDS 5811 Built-in Dishwasher
E 1 error code what does it mean - LG 24 in. LDS 5811 Built-in Dishwasher
    Guru:
  • 500 Answers
Hi george44480,
The E1 you are seeing means the following: Water Level in Drum lowering, this means there is a leak on one of the pipes. More likely it is the Circulation Pump, which is responsible for pushing the water to the Spray arms.
It will have to be replaced, as it is a common spare that has to be replaced on L.G Dishwashers (lifetime expectancy: 12 - 18 Months) - Not very expensive.
Usually is about 20%-25% the price of a new Dishwasher. The Circulation pump is fitted to the sump. Part Number: 5859DD9001A or 5859ED1001A (Depending which one is in stock)
See below a image of what a Circulation Pump looks like:
Good Luck :-) - J.Q
* If you found this solution helpful, please vote positively. A 4 four thumbs up will do nicely too :-)
Posted on May 26, 2011
What does the E3 code mean on the 540 model and is there a fix?
Troubleshooting the "E3" error code in Maytag MAH6700 ...
fixitnow.com/.../troubleshooting-the-e3-error-code-in-maytag-mah6700-...
Feb 20, 2011 - These codes in your (made-by-Samsung) Maytag washer might pop up during the ... In fact, the E3 error code means that the Machine Control wants to make the motor spin but won't do it because it's getting a weird reading from the tachometer.... MAH6700 and MAH8700 models (they use the same motor).
I have a samsung frontload washing machine. A code E3 is ...
www.shopyourway.com > Denise LaGrasse > Questions
Mar 15, 2014 - My samsung front loader is not working. do not no what E3 means. ...code F26 mean on a Kenmore Elite model 110.4708 washing machine?
How To Fix 3E Error Code On A Samsung Washing Machine
www.appliancerepairlesson.com/.../how-to-fix-3e-error-code-on-a-samsu...
May 15, 2015 - Samsung uses the 3E error code to indicate a drive motor tach fault. ...If you're handy, you can fix your Samsung front load washing machine error code ....My samsung frontload washer shows e3 and the drum does not turn ...
Jan 06, 2016 | Washing Machines
What does the trouble code 70 h95 mean
What does the trouble code 70 h95 mean - Fixya
www.fixya.com/support/t25932829-trouble_code_70_h95_mean
28 mins ago - what does the trouble code 70 h95 mean - Bowflex Treadmills question.
What Does Your Treadmill's Error Code Mean? - LifeSpan
www.lifespanfitness.com/.../what-does-your-treadmills-error-code-mean
Free
May 21, 2015 - Please refer to the following table if your LifeSpan treadmill is displaying an error code. If after trying the suggested solutions your treadmill is .
Oct 30, 2015 | Bowflex Exercise & Fitness
Erorr code 4003 zebra zxb8
Error Code 4001
System error code 4001 means "The local WINS cannot be deleted." This error code may also display as "ERROR_CAN_NOT_DEL_LOCAL_WINS" or as the value 0xFA1.
Error Code 4002
System error code 4002 means "The importation from the file failed." This error code may also display as "ERROR_STATIC_INIT" or as the value 0xFA2.
Error Code 4003
System error code 4003 means "The backup failed. Was a full backup done before?" This error code may also display as "ERROR_INC_BACKUP" or as the value 0xFA3.
Error Code 4004
System error code 4004 means "The backup failed. Check the directory to which you are backing the database." This error code may also display as "ERROR_FULL_BACKUP" or as the value 0xFA4.
Error Code 4005
System error code 4005 means "The name does not exist in the WINS database." This error code may also display as "ERROR_REC_NON_EXISTENT" or as the value 0xFA5.
Error Code 4006
System error code 4006 means "Replication with a nonconfigured partner is not allowed." This error code may also display as "ERROR_RPL_NOT_ALLOWED" or as the value 0xFA6.
System Error Codes
Sep 15, 2013 | Zebra ZXP Series 8 Thermal Card Printer
What does error code E6 mean? On a Mitsubishi Mr. Slim A/C
Code E6
Error detail Indoor/outdoor unit transmission error (signal receiving error).
Inspected unit Indoor.
Air Conditioning Fault Codes
Aug 01, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
Error code 51? F & F intuitive washer
Hi just read your posting.Error code 51 means you have a Recirculation Fault.This means while the machine is filling or washing it loses water.Error code 37 means you have Pump Block error which means the machine is not draining.Please look under the machine to the front right and you should see a pump with a red or black fan attached.Can you confirm this please? I think there is a problem with your diverter valve and the information on your type of pump will help me rectify this problem for you.Please reply with additional information on the type of pump in your machine.Looking forward to your reply.
Jul 01, 2010 | Fisher and Paykel Washing Machines
Error codes
Here are the common error codes for the LG machines.
LG Washing Machine Error or Fault Codes
If you have a LG Washing Machine you may see an error code come up and wonder what it is. Here are the common error or fault codes that will be displayed on the LG machine.
OE
This means that the washer has tried for ten minutes to drain the water out of your machine and the water did not drain out.
UE
This means that the load in the drum is out of balance causing excessive vibration when spinning.
IE
This means that the washer has not filled with water in 8 minutes.
LE
This means that the motor and the control panel are not talking to each other properly
PF
Power Failure – The power has gone out to the machine and then has come back on
FE
This means that there is too much water in the machine
PE
This means that the water level sensor is not working properly
CE
The washer motor has received and over current condition
TE
This means that your heating sensor is not working properly
SE
This means that you had a temporary sensor error
HE
This means that you had a temporary heater problem
DHE
This means that you had a temporary dry heater problem
This will give you a basic idea of what has caused your error code.
Heatman101
Mar 15, 2010 | LG WM2277H Front Load Washer
CD disk error
ok error code 1, look for this error code on your owners manual, toyota cd players give 3 error codes, this mean error code 1, error code 2, and error code 3, they all have different meaning please check owners manuel to see what does error 1 mean i will try looking for you
May 26, 2009 | 2007 Toyota Camry
Error code E000019-0000, trying to find out what this error code means.
Hello sir; It's means waste toner bottle full, dump it after you turn off the power, then turn power back on.
Apr 29, 2009 | Office Equipment & Supplies
Code errors on kodak easyshare esp 3
error code 3501 means the front access door is open on the printer. Error code 3502 means the paper tray is empty. The error code 3602 means the print job did not finish printing.
for more hrlp visit CBR Tech Solutions
Apr 10, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Error Code 4 on Saeco Talea Ring
I need to know what error code 4 means as well.
Has anyone helped you yet?
Apr 05, 2009 | Saeco Talea Ring Plus Espresso Maker with...
LG 24 in. LDS 5811 Built-in Dishwasher Logo
116 people viewed this question
Top LG Dishwashers Experts
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
