Question about Sportline 220 Sport Timer Stopwatch WV2786BK
I have an application whereby I want to glue a magnet to the back of the watch and attach it to a metal shroud. I need to remove it and reattach it to the shroud several times a day. Will the operation of the watch be affected? If the operation of the watch is affected, do you have another model with a mounting bracket that could be removed frequently?
    Sergeant:
  • 302 Answers
Generally an LCD watch is not affected by magnetism. A mechanical or quartz watch will be effected. My advice is to set a magnet on the watch and see what happens. A mechanical and quartz(or any watch with analog hands) will stop. Michael
Posted on May 24, 2011
Broken Armani sign
Yes it can be fixed but may need a jeweller. You cannot take the glass face out on it own, you have to remove the watch back plate and then pull out the watch mechanism. (Once the back plate is off removing the mechanism is not difficult) You then have access to both the inside glass face and the watch face. If you can do this you will need to glue the Armani logo with something like super glue, but not applied directly to watch, too risky. If you have tweezers hold the Armani logo in them. Use a pin and dip it into a small blob of super glue, apply the pin to the back of the logo and then place it on the watch face as quickly as possible and align. Once aligned apply a little pressure with the tweezers on the logo to help adhere, about 5 seconds, leave to dry and then put watch back together. If this all seems to difficult a jeweller can do it in about ten minutes.
Jan 08, 2014 | Watches
My Timex Indeglo watch does not have any means of opening the watch so I can replace the battery. It kept perfect time when it ran, but now it does not run at all. Is it supposed to be a disposable watch...
  • If you don't already know what size battery you need, you can find this information on the back plate of your watch. Once you have your replacement battery, you will need to open the back of the watch to gain access to the battery compartment. Depending on the watch, the back plate will either screw off or be attached by a few small screws. If attached with screws, you will need a set of precision screwdrivers such as a jewelry or eyeglass kit.
    Inside the battery compartment, you will see the battery is held down by a clip. Carefully remove the clip and eject the battery. Insert the new battery and replace the clip. If the battery clamp indicates you should do so, quickly press the reset button twice. Then reattach the back of the watch. If the watch display remains off after replacing the battery, press all buttons at the same time to reset the display.
  • Mar 02, 2011 | Timex Indiglo Analog Watch
    Can you please tell me how to remove links on my le cheatau ceramic watch?
    Hi, sizing the bracelet on your ceramic watch may void its warranty, making it ineligible to receive service from the manufacturer. If you want to keep your watch covered under warranty, contact your watch manufacturer for information on their customer repair service.
    If you want to remove it yourself, you need a watch pin removal tool. You can use a watch pin removal tool to remove the link pins that secure the clasp pieces to your ceramic watch band.
    But if you don't have a watch pin removal, follow the instruction below........
    • Find a clean, flat, well-lit work surface where you can size the bracelet of your ceramic watch. For best results, spread a soft optical cloth over your work surface and perform your repair on top of the cloth. The cloth will help prevent you from losing any small watch components, like link pins, that may be freed during repair.
    • Wrap the ceramic watch band around your wrist and count how many links overlap. Use this as a guideline for how many links should be removed. Note that the actual number of links to be removed may differ slightly from the original estimate. Remove excess links from your watch band one at a time to make sure that you don't end up accidentally making the band too short.
    • Remove the excess watch links from the ends of the band with the attached clasp pieces. Look between the removable ceramic watch links to locate the silicone connector pieces that join the links. Use a pair of small, pointed scissors to make a cut between the link and the silicone connector, this will free the excess links. Cut on the side of the link that faces the watch clasp. Repeat the process on the other side of the ceramic watch band.
    • Remove the clasp pieces from the ends of the removed watch links. Examine the clasp pieces to look for the metal pins that hold them in place. Push out the metal pins with a push pin to free the clasp pieces. You can now reattach them to the ends of your ceramic watch band.
    • Examine the newly-shortened ends of your ceramic watch band. Without the clasp in place the silicone connector pieces will be exposed. Note the two small puncture holes that go straight through the silicone connector. Insert the teeth of one of the clasp pieces through the holes in the silicone connector from the bottom. Fold over the other side of the clasp piece, reinsert the metal link pin and push the clasp to click it into place. Attach the second clasp piece to the other side of the watch band using the same procedure.
    Jan 06, 2011 | Watches
    I AM A JEWELER AND I TOOK THE BACK OF THE WATCH OFF TO CHANGE A BATTERY FOR A CUSTOMER AND THE BACK PEEELED OFF. IT IS 18K HOW DO I GET ANOTHER BACK????
    mcdevito75 Here, I would figure a specific glue to reattach the back cover. Vicence watch is in italy, I have an email address, info @vicence.it Also, from a web search, Lawson Watch.com tel. # 866-805-0007 They may be able to help.
    Sep 24, 2010 | Vicence Rectangular Case Strap Watch
    I have an omega speedmaster and the bezel fell off I want to r
    Any good quality SUPER GLUE will do the job. Apply to the case only and push the ring straight away onto it. Make it precise first time, as there will be no aligning possible afterwards. Rate me, please.
    Apr 08, 2010 | Rolex Daytona 116528 Wrist Watch
    Casio PRO TREK error 'OP EN' Display frozen with the above msg. None of the buttons - except the light - works. Whats wrong .. battery charge shows FULL
    The problems is very simple: On the back cover (inside) is a little Cu metal Part. This part is glued to back cover using a poor glue (rubbered glue) and, in time, is moving from original position. You must put back this parts to original positin ( a little hole inside of back cover) and glue using a good glue. When the back cover is mounted , this part must have a ferm contact with two springs from mechanism (sensor for back cover open). If beatwin this springs isn't a electric short (using Cu metal parts) the internal mechanism of watch "see" the back cover is open and show "OPEN" on screen!
    Mar 22, 2010 | Casio Watches
    A metal jewel fell off of the watch face and is loose on the dial
    I suggest you take it to a watch shop and ask them to repair it for you.
    It can be more difficult than it appears to remove and replace backs particularly.
    Feb 25, 2010 | Watches
    New watch..Jules Jurgenson day-date..the stem cap is loose.
    remove the cap and put a tiny drop of locktite glue on it. spill some glue onto a piece of glass or an old plate and use a sewing needle to put a tiny drop of glue in the hole then screw it back on and wait till the remaing glue on the glass is gone hard before pushing the stem back in .. this last bit is important so as not to glue the stem to the watch. if this helps please rate me joe
    Nov 12, 2008 | Jules Jurgensen 5004PB ( ) : Swiss Quartz...
    Watch Repair
    I would not recommend you attempting to try this at home, because you can severly damage your watch, but if you must, you will find that on the back of your watch relatively near the crown is a dimpled, small metal piece. Take a tweezer and push it in LIGHTLY while pulling out the crown.
    Apr 22, 2008 | Watches
    Sportline 220 Sport Timer Stopwatch  WV2786BK Logo
    41 people viewed this question
    Top Sportline Watches Experts
    ray gallant
    Tom Chichester
    Bill Boyd
    Are you a Sportline Watch Expert? Answer questions, earn points and help others
