Question about Kenmore Vacuums
It turns on and shuts off just like it is supposed to but the thing is bone dry. The humidity is at 56% so it should be able to dehumidify. It is just a little over 1 year old, help me please?!!
    President:
  • 2,080 Answers
If the machine's compressor runs when you switch it on, then turn the machine on maximum and let it run for an hour or so. Then check the coils in the back with your hand. If they are not getting cold at all, then there is a significant problem with the refrigeration process in the unit. It may have developed a leak and allowed your refrigerant gas to escape, or there may be another internal problem with the compressor. Either way you would need to have it serviced by a fridge technician, or more likely just replaced with a whole new unit since both options can potentially cost about the same.
If the unit runs normally and the coils are getting cold, then make sure they are not totally icing up which will impede the unit's performance. If your dehumidifier is freezing up then that probably means it is actually working well. The humidity level in the room is probably just relatively low and you probably have the unit turned up too high for the conditions.
Try turning down the setting on the unit so that it cycles on and off every few hours and does not run continuously.
Also try using some warm soapy water to clean off any dust or oily residue from the cooling coils in the rear of the unit. Remember to also clean the air intake filter while you are at it.
The ambient temperature in the room may also be a bit too low, so you can try adding some heat to the room if necessary. A dehumidifier will not work properly if the ambient air temperature is too low. Basically, the warmer and more humid the room is, the better they work.Since warm air rises, you can even try lifting the unit higher up off the cold floor onto a bench or table where the air is warmer.
You can click on the following link for a general operating and troubleshooting guide with additional tips on effective dehumidifier operation:
http://www.allergyconsumerreview.com/dehumidifier-advice-troubleshooting.html
I hope that was helpful to you, good luck.
If you choose to rate this solution using the Thumbs Up scale provided, I thank you very much for your time and consideration.
Joe.
Posted on May 24, 2011
Carpet cleaning
If you wet cleaned and vacuum extracted yet find carpet still quite damp,
The most common methods to dry are:
With windows open on a warm day...
Air movers
(High speed squirrel cage fans with low exhaust openings)
Designed to shoot air across the surface of the carpet...Evaporation occurs that way.
Alternatives are:
Depending on climate..running your central air or room Air conditioner with fans set around the room ,...This option is what I normally use when humidity is high in Kansas
Another option..And actually the best would be to use a Dehumidifier...They are a bit pricey new...but rentals are available
Sep 12, 2012 | Rug Doctor Mighty Pro X3 Carpet Cleaner -...
Our dehumidier is running but there is not water in the tray???
If the unit runs normally and the coils are getting cold, then make sure they are not totally icing up which will impede the unit's performance. If your dehumidifier is freezing up then that probably means it is actually working well. The humidity level in the room may be relatively low and you probably have the unit turned up too high for the conditions.
Joe.
May 29, 2011 | Vacuums
I just purchased a used portable air conditioner, a danby dpac120068. It is not producing any water when in dehumidify mode. Also, it seems as though the air conditioner is on even when in dehumidify...
The A/C will be on when dehumidifying... that's how it does that...
If it is not collecting water, it is probably because the humidity is too low in the house already...
I would give it more time....
heatman101
May 25, 2011 | Vacuums
My eureka enviro vac shut off and wont turn back on it was clogged but does not smell burnt . is there a reset or some kind of shut off when it gets clogged?
Same thing happened to me. I checked the owner's manual and it turns out the Eureka Envirovac has a built-in thermal cut-off switch. So anytime the motor gets too hot, it just shuts down. Most of the time this is because it gets plugged or the filter is too dirty. In my case, the dust basket thingy and filter were clogged beyond belief. Probably would help to clean that more regularly in hindsight. Supposedly it will turn back on after the recommended 30 minute wait.
Apr 15, 2011 | Eureka 5893AVZ Bagless Upright Cyclonic...
I have a GE dehumidifier that i hooked a garden hose to for direct drain. it will work okay for awhile then will only drain into the drain bucket. is there something i can do to ensure that it will drain...
This seems to be a fairly frequent complaint on these GE dehumidifiers, and none of the solutions I've read here or anywhere else have fixed mine. My hose is clear, straight downhill, tight to the nipple with a good gasket, no plugs visible in the nipple, but has always filled the bucket rather than drained through the hose (and it's always bone dry). After two years of this and emptying the bucket, I'm about ready to disassemble it to see if I can fix it but with all of the other unresolved complaints I've seen GE should step up to the plate and post a solution.
Aug 19, 2010 | Vacuums
It does not spray the cleaning solution
CHECK TO MAKE SURE THE HOLE WHERE THE SOLUTION IS SUPPOSE TO SPRAY OUT IS NOT CLOGGED SHUT, TRY STICKING A NEEDLE THROUGH THE HOLE TO OPEN IT UP.
Apr 01, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Mach 5 hoover turns off
Just got a solution off another website. There is a pre motor filter about the dust collection container. I opened mine and it was very dirty. I washed the filter and you are supposed to let it dry out for 24 hours. Hopefully this will work. Another guy said it worked for him.
Dec 29, 2007 | Vacuums
Power
I had a similar problem with a Shop Vac. The solution was to disassemble the power switch and polish the metal electrical contacts to remove any oxidation caused from humidity. Tedious and time consuming but effective.
Dec 13, 2007 | Craftsman 17026 Wet/Dry Vacuum
Vacuums Logo
63 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
