Question about Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL2060UC/01 FD8205 won't spin
Over last few months, have noticed the spin cycle sounding whiny. Stopped spinning completley so I just replaced the brushes on the motor and it has no effect. I put it on the spin cycle and push start. It makes an electrical sound but not at the motor. It makes the same sound even after removing the motor, so I have a problem before the motor. I have the back panel off and do not have any hosed connected but do not see any kill switch. What do you think is happening here? Is that noise the pump. Do I need to hook up the water supply and put the back on to have it work? I am confused and appreciate your assistance. Thanks!
  • 1 more comment
  • Anonymous Sep 06, 2008
    i have no spin
  • lschider05 Sep 18, 2008
    My spin cycle is doing the same thing, when i went to remove the drain in the kick plate, it turns but i cant pull it out. I don't know if there is a step in the process that i might have missed, anything you can do to help would be great!
  • adoggy Oct 28, 2008
    i have he same problem but mine is a few years older. sounds the exact same issue. i cleared out the pump drain but nothing reallly came out.
  • 97 Answers
by elecrical sound i take it you mean a buzzing sound, if so it sounds like your pump is jammed. on the front of your machine their will be a plastic kick plate, if you remove this (carefully) you will find the pump filter, this catches all the debris from the water during the wash (coins,bra wires etc). you can remove this by turning it anti clockwise then pulling it out. remove any obstructions whiich may be lurking in there and also check inside the pump housing as things can get stuck behind the pumps fan then refit the filter.
you may need some old rags whilst you carry out this job as there may be water left i the pipes when you remove the filter.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Posted on Aug 19, 2008
I have the same problem on an axxis 2060 washer. I've been opening the drain nob for months. If i leave it off, sometimes it would do a quick spin... but now nothing, just the frustrating humming electrical sound kdkibs was speaking off. Anymore tips would be appreciated.
Posted on Sep 01, 2008
  • tsbosch Nov 01, 2008
    i think i may have a bit more info on these situations. I finally solved my problem. Bosch has had numerous complaints regarding the boot gasket. Inspect the boot gasket, any moisture or leaking in the gasket drains down and inevitably interferes with the electronics of the unit.
Water entering bleach dispenser, far right, but not detergent dispenser, far left. But I can hear water running and with drawer out, can see it trickling at back
Posted on May 03, 2011
I fixed the problem of the humming sound and the non draining or spinning by replacing the drain pump, which cost 40 bucks and two hours of work. i spent more time trying to diagnose and contact bosch than actually working on the machine. it is easiest to do if you can remove the dryer so that you can tip the washer up to gain access to the front bottom of the washer. the pump is connected by a few screws and two hoses. make sure you have removed all the water before attempting to replace it.
good luck,
Posted on Nov 07, 2008
Bosch wfl 2060 washing machine makes a funny rattling sound when it should be spinning or draining. why
Check the filter behind the flap (Bottom right of kickplate) souns like you have a coin or other foreign object in the pump.
Feb 18, 2013 | Bosch Axxis WFL 2060 Front Load Washer
Washer makes a rattling sound when it starts the spin cycle. Sounds like gears stripping or something loose rattling around. Now it won't spin after the wash cycle. It will spin if I put it on the...
Sounds like you cannot activate youre imagination maybe Ill do this for you one time here goes ~: You or someone left coins in your pockets jeans cardigan whatever they got out of garment while in the wash spin and worked themselves into the machine and now its bug-gerred innit?
Jul 30, 2017 | Bosch Axxis WFL 2060 Front Load Washer
Water is leaking from Bosch washing machine WFL2060UC. Checked the hose connections. Lots of water comes out of drain hose after one cycle and water is pooled in the pump (place where the cap is next to...
Bosch washing machine WFL2060UC This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Apr 13, 2011 | Bosch Axxis WFL 2060 Front Load Washer
Bosch axxis washer does not spin; stopped spinning. It worked well for about 8 years, but always had a weird noise, since the machine was brought from the store; my guess is that some piece that kept being...
If you go to BSH home appliances website and follow link to spares you can put in the model number (Enr should start with a W. example WFL2065gb/01) and get the part diagram. I would imagine that it would be the brushes on the motor, there can be replaced but remeber to clean the armiture (copper below where brushes touch in position) lightly with a very fine piece of glass paper. you have said it is not spinning but do you really mean there is no motor action. ie not doing slow turns on the wash cycle? If only not spinning it could be a drainage problem. Hope this helps.
Jul 06, 2010 | Bosch Washing Machines
Replaced the sump pump, now the machine will not
There will almost certainly be something stuck in the pump again. Possibly the same thing that happened to the last one.
May 28, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Bosch WFO2060 not spinning at spin cycle.
Hi. this is a failed timer device. simply replacing the timer control module will eliminate these issues you are having.
Jul 01, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer--Tub won't move
what a bogus website you are. you offer no free support and you should say so
Jul 12, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch axxis door won't open
michele99, So when you put it on drain, do you here the machine trying to drain the water? After it finishes draining, (you have to wait a few minutes, it should then have a blinking light
on the Finished/Door locked light.
Are you waiting for it to finish?
May 08, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WTA 4400 dryer
if you can hear a whirring then the motor is probably spinning, and the problem may just be a broken belt.
If no sound, then probably power not getting to motor via PCB
Apr 09, 2008 | Bosch Axxis WTA4400 Dryers
Bosch Axxis front loader will not drain
check filter. check no foreign objects fouling pump impellor - bra wires are the favourite
Apr 25, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer Logo
1,351 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
