Question about Kenwood VR-407 Receiver
I have a VR-407 reciever and I am unable to get my CD/DVD rear outputs to work. I am hooking up a DP-3020 and I can get it to work in the Audio L/R jacks in the front. Is there something that I need to do to get the rear CD/DVD jacks to work.
    Brigadier General:
  • 8,546 Answers
A Kenwood VR-407 is a receiver and has an INPUT pair for CD/DVD, not outputs. Plug ANY functioning audio source (except a turntable) into it and select it on the front panel.
If your DP doesn't work on either I'd suspect something is wrong with IT.
Posted on May 24, 2011
I am connecting an amplifier to my VR-407 to accomodate more speakers I have installed throughout my home. Where do I connect the amplifier?
Connect the amplifier input to the VR-407 using the receiver's REC OUT jacks for the MD/TAPE input on the back panel. This is a fixed line-level output for recording, and will work fine for driving the additional amp.
Jan 17, 2011 | Kenwood VR-407 Receiver
Sub woofer output port does not seem to work on my kenwood VR 407, checked sub woofer on another system - works fine, any easy solutions?
Is the 407 set up to drive the unknown sub. It's not just plug n play.
The manual will guide you, around page 15. Also refer to your subwoofer manual. Try retrevo.com for that one.
http://www.retrevo.com/support/Kenwood-VR-407-Receivers-manual/id/480ag200/t/2/
Dec 29, 2010 | Kenwood VR-407 Receiver
I have direct satalite tv VR 6050 kenwood surround sound tuner vizio tv, dvd player, and a vcr, Im confused on how its hook up and what order should it go something like sat in to sat box to kewood...
that reciever is not going to carry a hi definition video signal, it doesnt have either hdmi or component video inputs.
you can still use it, but if you run the picture through the reciever, it will have poor quality.
heres how you are supposed to hook it up:
find the single,m yellow video jack on your sattelite box, and hook that up to the "tv" video input, then hook the laft and right audio outputs from the cable box into the "tv" audio left and right inputs on the receiver. hook up the dvd player and vcr in the same manner, using "dvd" and "VCR" (if labeled as such) inputs on the reciever.
finally, send the tv video and audio outputs to the composite video in and left/right audio inputs on the tv. the video will be running through the reciever, and when you use the reciever to switch the sound source, the video will also be changed. you could get better picture quality if you ran the video directly to the tv using component (seperate green, red and blue) outputs/inputs, and bypassing the reciever on the video end, but then you would have to change inputs on the tv AND reciever to change from your cable box to your dvd player.
Nov 25, 2010 | Kenwood VR-6050 Receiver
Have a VR-407 receiver, all of a sudden there's no audio coming out of the speakers from the TV. Also, DVD, tuner and CD player have no sounds. Speakers are only a couple years old.
Check for basic things like speakers being turned off or switched to speaker b from a and the tape monitor switch being on. Larry's Electronics.
Apr 27, 2010 | Kenwood VR-407 Receiver
I have a Kenwood VR-407. TV and Blue-ray are
Check the manual for "Volume offset" at the input mode. I'll pull the pdf on the unit, If I find it, I will send the instructions. Hope this helps
Dec 23, 2009 | Kenwood VR-407 Receiver
I have a vr-405 5.1 channels reciever, I have it hooked to nanlog out on tv per tv manual,tv speaker r off,there is a dvd/vcr hooked into video 1 and it works on tv speaker, where do i hook into the...
try to be a little more clear on what you are trying to do.do you have it connected to hdtv and cable box if so run hdmi cable from cable box to tv and then run optical cable from reciever to cable box you then must turn reciever to cd/dvd to listen to it leave reciever in auto mode go into cable box menu under audio and select dolby digital
Feb 21, 2009 | Kenwood VR-405 Receiver
Linking DVD/CD to Receiver
You use rca cables to hook them up to each other. On the back of your Reciever make sure it is hooked to the cd. There should be speaker outlets in the back of the reciever. You should have suroundsound, Center, left and right speaker ports. I've never seen just 2. Crazy
Oct 16, 2007 | Kenwood VR-707 Receiver
Kenwood VR-407 Receiver Logo
126 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Eddie Dalton
Eddie Dalton
Henry  Thomas
Henry Thomas
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
