Question about Garden
Parking brake doesn,t hold my countax 18/50dsl on gradient. how do i adjust it
  • 98 Answers
SOURCE: parking brake wont hold
if you have rear drums then you adjust them from behind. the backing plate. just tight enough that you can fell the drag.if they are rear disk brakes.there is a cable with a nut on it.tighten the nut to tighten up the parking brake.
Posted on Mar 11, 2009
  • 232 Answers
SOURCE: parking brake adjustment
Go back and recheck your work. The cable on one or both sides might be installed improperly.
Posted on May 06, 2009
  • 8 Answers
SOURCE: how to adjust parking brake 05 impala.
u will nead to get under the car. how u go about that is up to u but do it safe an have mate around. go to your front door this is the best place easy to reach your hand brack hear. look where the gear stick is up front u nead to be under the car where the gear stick is find it then look a bit downback from gear stick an u will see it. when u do the hand brake up do not hav it on u wont to have max 8 click,s an u,ll be fine. hope this helps u
Posted on May 28, 2009
isaid
  • 302 Answers
SOURCE: Parking brake not holding
it sounds like its time to replace ur rear brakes, but dont forget to readjust handbrake when done
Posted on Oct 03, 2009
SOURCE: The emergency brake adjustments on a 1993 Ford
I would inspect the rear linings,my guess they are low or out of adjustment
Posted on Oct 07, 2009
Bmw x1 handbrake - has to be fully at top to work
Adjust the park brake and also have the rear brake pads checked, they may be worn out.
Apr 02, 2014 | BMW X1 Series Cars & Trucks
How to remove and clean and replace the rear brakes on a 2008Toyota yaris
REMOVING REAR BRAKE DRUM SUB-ASSEMBLY
1. Release the parking brake and remove the rear
brake drum.
If the rear brake drum cannot be removed easily,
do the following:-
2.Remove the hole rubber and insert a screwdriver
through the hole into the backing plate, and hold the
automatic adjust lever away from the adjuster.
3.Using another screwdriver, contract the brake shoe
by turning the adjuster.
4. Take out the brake drum from the flange.
5. remove the shoe hold down spring cup, shoe hold down spring, pin and front side brake shoe.
6. Remove the tension spring. Remove the shoe return spring from the rear brake shoe and remove the parking brake shoe strut set.
7. Remove the shoe holding spring cup, shoe hold spring, pin and rear brake shoe.
8. separate the parking brake cable.
9. Remove the automatic adjust lever tension spring and remove the automatic adjust lever.
10. remove the C-washer and remove the parking brake shoe lever.
NOTE: Do not use any solvent like gasoline to wash the brake parts.
Always wear safety goggles and mask before using compressed air.
Dec 28, 2013 | Cars & Trucks
Why doesn't parking brake hold
check the adjustment on the brake band
Mar 31, 2012 | Garden
The handbrake doesn't hold the car on steep slopes, only gentler slopes - and even then I hold my breath! It's had new pads and the cable has been tightened too, but the problem's still there...
I think you should look into the possibility that your rear brake pads, and your parking brake pads are different items. Replacing one is not necessarily replacing the other. Many vehicles have different brake surfaces, and adjustments thereto, for parking brakes. Find the person who did the back brakes and ask him if there is another set of pads for the parking, and if so, did he replace those too? If they do not know, call a dealer parts department or a plain jane car parts store. I notice advance parts seems to indicate a parking brake shoe set for your car, in addition to the back brakes, but they do not sell them.
Aug 25, 2011 | 1994 Isuzu Trooper
My locking dual brake lever does not hold in he PARK mode. The cables are as tight as possible without causing the brakes to drag.
If the lever stays in the park position but doesn't hold the wheel, then you'll need to have the brakes adjusted. They're likely not properly aligned with the rim, which is why the cables are tight, but not effective.
May 05, 2011 | Pyramid Alloy Mountain Bike Dual Cable...
Parking brake cable stretched beyond adjustment how do you replace
Rear Brake Shoes- You'll need to know how to remove the rear brake shoes to remove the parking brake cable. REMOVAL AND INSTALLATION Amigo and Rodeo
  1. Raise and safely support the vehicle.
  2. Remove the rear wheels.
  3. Remove the brake drums.
  4. Remove the brake return springs.
  5. Remove the leading shoe holding pin and spring, and then the leading shoe.
  6. Remove the self-adjuster and the adjuster lever.
  7. Remove the trailing shoe holding pin and spring.
  8. Disconnect the parking brake cable from the trailing shoe and remove the trailing shoe. Remove the parking brake lever from the trailing shoe. To install:
  9. Attach the parking brake lever to the trailing shoe.
  10. Connect the parking brake cable to the parking brake lever.
  11. Apply a thin coat of high temperature grease to the shoe contact points on the brake backing plate (locations A and C in the accompanying illustration), piston contact surface (B), and self-adjuster (D). Fig. 1: Exploded view of the rear drum brakes — Amigo and Rodeo 93026g56.gif
  12. Position the trailing shoe on the backing plate and install the hold-down pin, spring, and retainer. Don't stretch the return spring when fitting the shoes onto the backing plate.
  13. Connect the upper return spring and the leading shoe to the trailing shoe and position the leading brake shoe on the backing plate.
  14. Install the adjuster assembly and the hold-down pin, spring, and retainer.
  15. Use a brake spring tool to install the lower return spring.
  16. Install the self-adjuster lever and adjuster spring.
  17. Adjust the shoe-to-drum clearance to 0.0098–0.0157 in. (0.25–0.40mm) and install the brake drum.
  18. Check the brake drum for scoring or other wear. Machine or replace as necessary. Check the maximum brake drum diameter specification when machining.
  19. Install the rear wheels. Lower the vehicle.
  20. Road-test the vehicle.
Aug 17, 2010 | 1997 Isuzu Rodeo
Parking brake on my 01 kia rio(standard) no longer holds
parking brakes are adjusted at and with the rear brakes,..(drum brakes that is),.....as you adjust the rear brakes to have a slight drag as you spin tire, the parking brake is adjusted at the same time,...they work together with that one adjuster,....as you pull on the parking brake, it makes the brake shoes spread apart just as they do when you push the brake peddle,..by adjusting the rears you'll also find that the brake peddle feels better too.
Jan 06, 2010 | 2001 Kia Rio
2001 jaguar stype won't shift from park, what do I do?
The brake switch may be bad on the pedal. Brake lights may still work but signal to trans is lost somewhere. First make sure all fuses are ok. Then test the switch. Voltage should be present on one wire then with the pedal depressed the other wires should have voltage.
Nov 11, 2009 | 2001 Jaguar S-Type
I need a schematic for the rear brakes on an F150 super cab with 4.6L automatic trans 4wheel drive
Drum, Rear Brake System Standard Rear Brake
Item Part Number Description 1 2069 Brake Shoe Hold-Down Spring Pin 2 — Rear Wheel Cylinder Retaining Bolt (2 Req'd) 3 — Washer (2 Req'd) 4 — Anchor Pin (Part of 2211) 5 — Wheel Cylinder 6 2028 Brake Shoe Anchor Pin Guide Plate 7 2A637 Parking Brake Lever 8 2296 Brake Shoe Retracting Spring (Short) 9 2296 Brake Shoe Retracting Spring (Long) 10 2200 Rear Brake Shoe and Lining (Secondary) 11 — Washer 12 2106 Parking Brake Lever Pin Retainer 13 — Brake Shoe Adjusting Lever Cable Guide 14 2A642 Primary Brake Shoe Parking Brake Lever Link 15 2A601 Parking Brake Link Spring 16 2068 Brake Shoe Hold-Down Spring 17 2A176 Brake Shoe Adjusting Lever 18 2048 Brake Shoe Adjusting Screw Socket 19 2047 Brake Shoe Adjusting Screw Nut 20 2041 Brake Adjusting Screw 21 2049 Brake Shoe Adjusting Screw Spring 22 2200 Rear Brake Shoe and Lining (Primary) 23 2A178 Brake Shoe Adjusting Lever Cable 24 2211 Brake Backing Plate
Heavy Duty Rear Brake
Item Part Number Description 1 — Rear Wheel Cylinder Retaining Bolt 2 00538 Lock Nut 3 2212 Rear Brake Backing Plate 4 2262 Rear Wheel Cylinder 5 2A642 Primary Brake Shoe Parking Brake Lever Link 6 2A601 Parking Brake Link Spring 7 2A637 Parking Brake Lever 8 2106 Parking Brake Lever Pin Retainer 9 — Parking Brake Lever Bolt 10 — Secondary Shoe Assembly 11 2A179 Brake Shoe Adjusting Lever Cable Guide 12 2068 Brake Shoe Hold-Down Spring 13 — Adjusting Lever Pin 14 — Adjusting Lever Return Spring 15 2A176 Brake Shoe Adjusting Lever 16 2047 Brake Shoe Adjusting Screw Nut 17 2049 Brake Shoe Adjusting Screw Spring 18 2041 Brake Adjuster Screw 19 — Primary Shoe Assembly 20 2068 Brake Shoe Hold-Down Spring 21 2200 Rear Brake Shoe and Lining 22 2035 Brake Shoe Retracting Spring 23 2A178 Brake Shoe Adjusting Lever Cable 24 2092 Brake Adjusting Hole Cover 25 2069 Brake Shoe Hold-Down Spring Pin
The rear drum brakes:
  • Have internal shoes that expand against the brake drum (1126).
  • Are a single-anchor type.
  • Are actuated by one rear wheel cylinder (2262).
  • Have two pistons in the rear wheel cylinder (2261). One exerts force against the upper end of the primary shoe; the other exerts force against the upper end of the secondary shoe.
  • Adjust rear brake shoes and linings (2200) automatically.
  • Need manual brake adjustment if the adjusters are not operating properly or after the rear brake shoes and linings have been replaced.
When the brake pedal is applied, hydraulic fluid pressure forces the pistons in the rear wheel cylinder outward, moving the rear brake shoes and linings against the brake drum.
The rear drum brake system includes the parking brake mechanism. Refer to Section 206-05 .
Apr 04, 2009 | 1997 Ford F150 Regular Cab
Garden Logo
115 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
