Question about Refrigerators
AMANA ABB2222FEQ . Found freezer coils iced up and contents of freezer thawed. De-frosted freezer by opening drawer, removing contents, turning off power for hour or so. After ice melted from coils, turned power back on and freezer and refrig operated normally. After noticing frost build up on coils, found instructions for forced defrost using ADC panel. Forced defrost seems to operate properly but cycle seems to end before all frost is gone. I would like to examine the heater and defrost thermostat but am unable to remove back panel of freezer after removing the ice maker and the four screws at the corners of the panel. How does this panel come out? I don't want to force anything.
catriver
  • 878 Answers
SOURCE: Amana bottom freezer/ refrigerator
Geezer, sounds like a defrost issue. I usually find the bi-metal to be the culprit on this model. Check out the pic. You will have to remove the back panel in the freezer and defrost the evaporator. Remove the ice maker if there is one. The back cover has 4 quarter inch screws. remove those. The air vent has 2 plastic clips one each side and one on the bottom, push in and pull the grill off. The thermistor cover has a slot for a flat blade screw driver,push in and pull the cover off. The thermistor will now slide behind the back panel. Check the bi-metal for buldging. As long as the evaporator fan is working, it's probably a defrost problem.
Posted on Jul 16, 2007
lenwest
  • 150 Answers
SOURCE: not cooling properly
Sounds like your coils are getting plugged,(excess ice in and around the coils)if you have a cooler or some other place to keep your food cold,turn off or unplug the fridge,you want to defrost it,for the freezer place pans of hot water in it to speed up the process,leave doors open,should only take around 4 to 12 hrs.A good time to clean it to lol.
Hope this helped.Let me know.Also rate me.
For more help go to live chat.
lenwest
Posted on Jan 31, 2009
SOURCE: Side by side refrig./freezer does not cold.
Are the heat exchange coils behind or under the refrigerator clean?
Are the fans running smoothly? Check for bent blades and bend them back if necessary.
Is the evaporating pan under the refrigerator dry.? Then the drain of the defroster may be blocked. Unblock with a steam generator or a long plastic tube.
Posted on Mar 16, 2009
whytfang
  • 170 Answers
SOURCE: Kenmore Trio bottom freezer frost free. Producing frost
There are several reasons this can be happening...
1. The seal on the door may have a tear or may not be seating properly...this allows excess warm air into the freezer compartment and in its effort to remove the same ...frost appears.
2. There is something call a thermistor (which senses temp and ice build up) that is cycled on and off as needed to remove excess frost accumulation and or ice buildup on the evaporator (freezer) coils...it is a heat strip which actually defrost the frost/ice. If this is not working frost will accumulate and eventually it will become Ice......now the remarkable thing about Ice accumulation is that you would think everything would remain cold or get colder ..however in this case the opposite occurs...it insulates the coils and thereby increasing the temperature...put a thermometer...one that is calibrated properly...(calibration can be set by placing a thermometer into a glass of ice water...the temp of a glass of ice water..after a few minutes setting will be exactly 32 degrees)..if the temperature of your refrigerator is gradually rising over the period of a week...you will need to call a tech or replace the thermistor and or trouble shoot other problems that may have occur such as..
3. The evaporator fan may be going out although they usually make a high pitched whining noise of a whirring noise before they go out...not always and if they are intermittently cycling off then frost would build up...do you always here a fan running when you open the freezer...if so that is good...fan is working...but it may be cycling off at times when no one is aware.
P.S. the odds of it being due to overfilling are slim...I have been in the industry for 35 years and that is what freezers do...which a lot of people don't realize is that freezers don't actually cool anything ..they just remove heat and when you remove all the heat all that is left is cold (like in space) and when heat is removed quickly frost can appear like when you blow your breath on a freezing cold window..then right your name....but I digress...any way..if there was an excess of heat due to a lot of new food in the freezer it would correct itself by one of the processes i mentioned above..and it would never result in Ice..you probably have one or more of the problems I mentioned...evaluate how long its been going on...
4. Thermostat could be out of adjustment..and or not functioning
properly..which would delay or inhibit a defrost cycle..from occurring..unfortunately almost all of these problems require a tech...or a good handyman.
This should lead you in the right direction...if you need help in finding a reputable service company in your area let us know..I hope this has been helpful..if so PLEASE rate me....thank you... .......The Fang
Posted on Mar 26, 2009
  • 531 Answers
SOURCE: Amana SXD 22S2W -Frost on fins but not cooling.
you may have aburn out may be heater
Posted on Mar 31, 2009
Frigidaire refrigerator/freezer side by side--compressor keeps running
Most problems with side by sides frosting up is due to failure of the defrost heater in the bottom of the freezer section behind the panel inside.
Jun 16, 2012 | Refrigerators
Tip
How to stop top freezer from ice ing up on (frost free) fridge HOT POINT
i recently had the problem of my freezer ice ing up on my " HOTPOINT" 18cu" fridge. i kept taking everything out and manualy de-frosting it. i got so frustrated doing this every 3-5 days so i did this : Behind the plastic cover at the back there is a coil. attached to this coil is a round silver part with wires attached to it. it is somekind of temperature sensor. this was the culprit.. here is wat i did to fix my problem.. : FIRST " UNPLUG FRIDGE" !! remove all contents, remove both BOTTOM AND TOP PLASTIC COVERS, if coil is all ice, thaw with hair dryer, if not iced up look for a SILVER , ROUND, sensor approxamately 3\4" high by 1" across. <----{ this sort of looks like a plastic bottle cap.. }CUT WIRES as close to this sensor as possible. REMOVE from coil tube.it will just pull off of coil. take care not to damage this coil or tube in the process.. with this sensor removed , just use yellow or orange wire nut and put these wires TOGETHER and attach wire nut and wrap electrical tape around wire nut and wire. put plastic covers back into place, put all contents back into freezer, plug fridge back in.. " D O N E ". its been 4months now and fridge and FREEZER work better then ever... this fix cost me $0.00 i can't get photo into here. sorry.. this process takes about 10 to 30 minutes to complete..
on Jan 10, 2010 | Refrigerators
My Amana SCD23VW quit producing ice cubes. It was one big melted mess. Also freezer will not get cold enough to freeze now. Please help.
your frig is not defrosting you should see frost on the back panel remove items from frzr and remove the back panel off and thaw the evap coil if you can not get repair person to your house it will oper normal until it frost up again, generally it will be one of 3 thing dfrst heater, dfrst thermostat, dfrst timer
Sep 03, 2009 | Amana SXD524VW Side by Side Refrigerator
Side by side Amana freezer/refrigerator thawing.
The doors not being shut can make it freeze up,Just thaw again and make sure the doors get shut each time and see what happens,just post back details if it doesn't work after thawing
Aug 05, 2009 | Amana ASD2625KE Side by Side Refrigerator
The freezer is warming up
If you found something lodged in the door that may have kept it open for a while, i suspect frost formed on the coils behind the panel. Frost will not let air pass through the coils to the refrigerator side. This is one of the most common problems there is. If you look through the louvers on the rear panel that is for sure your problem. It most likely just needs thawed out. After it is thawed out, your normal defrosting routine will take over again and hopefully you will be trouble free again.
May 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Not cooling properly
lenwest
Jan 30, 2009 | Amana ABB1927DE Bottom Freezer...
Icing up in bottom of the freezer
machine has a defrost issue, defrost mi metal or defrost timer
Apr 12, 2008 | Refrigerators
Amana Distinction side by side
When you say flows out of the bottom do you mean on the floor of the kitchen? Not cooling can be a sealed system problem if it happens in both fridge and freezer. The frost build up could be due to low refrigerant levels in the system. If possible, turn off the frige for a few days with the doors open to thaw any problem areas. Remove the lower panel in the freezer section to view the coil area. Turn the unit back on and watch for a "white frost" pattern on those coils. The pattern should be uniform and even across the whole coil area. If the frost suddenly stops on a coil (the rest are not frosted) you likely have a leaky system and a loss of refrigerant. This would be worst case. Unit must have about 17 degrees (or colder) to make ice (with water of course.... Sort of sounds like a couple different problems at the same time.
Nov 03, 2006 | Amana ASD2326HE Side by Side Refrigerator
Refrigerators Logo
96 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
