Question about Dell Latitude D600 Notebook
Dell latitude d600 doesn't turn on
I was using my dell latitude d600 and it suddenly turned off i tried removing the battery and powering it with the power cord only and it still wouldn't turn on . not even a single light turns on and every time i plug in the ac power cord the little light on the power cord shuts off can someone please help me. also i have two power cord and they both turn off as soon as their plugged in to the laptop
  • Dell Hell Sep 21, 2008
    I have the same problem with my D600 Dell since today. Were you able to solve your problem and, if so, any insights you can share would be very helpful. I am hoping it is a easy fix. Problem sumary: Laptop does not turn on either with the power cord-adpater or battery. The power adapter's light comes on (means there is power), but the moment I plug-in the cord into the laptop, the power cord light goes off (means no power). Starting it form a battery also does not work.
    Thanks!
  • 4 Answers
The test Dell advises to narrow down this issue is to remove the battery, hard drive, ram, and optical drive.  Next plug in the a/c power cord and you should get some LED's coming on. If not it points to the motherboard.
Posted on Aug 16, 2008
D600 wont power up
Try removing the battery and boot on the power cord sometimes the battery shorts the system so it will not boot if it does boot then you need to replace the battery it could be the battery is dead and your power cord is bad check and make sure that is not the case if the power cord is good then I would look into replacing the mother board you can find a replacement on Ebay or at dell .if you have to replace it do a google search on hot to replace the mother board on a Dell latitude D600
and you will ba able to get step by step on how to disassemble it
Aug 28, 2011 | Dell Latitude D600 Notebook
My Laptop (Dell Latitude D600) when I'm trying to turn it on, can not swicthing on and no effect can show me that power is entring. I thounght that is charger problem and I trayed to use the same charger...
Try this, Unplug the power and remove the battery, while the battery and power are unhooked hold the power button down for 30 seconds, Put the battery back in and make sure you slide the locking tap to lock the battery in, try to start the computer, If it doesn't start, plug the power cord in and wait 3 minutes and try to start it, If it still will not start it has an internal issue and needs to be repaired.
Dec 01, 2010 | Dell Latitude D600 Notebook
D600 monitor is blank after I unplugged power cord
Your battery got fried Try replace with a new battery.
Jul 28, 2010 | Dell Latitude D600 Notebook
My Dell laptop d600 suddenly shut off and will not power back up....led light on adapter blinks when plugged in...I have tried re-inserting RAM modules but this or nothing else seems to work.. thank you...
Unplug your battery and then plug in AC adaptor and see if laptop powers on. I assume you power button doesnt turn on at all? If so, your motherboard seems to have a power issue. Unfortunately, you have to replace motherboard. If laptop. powers on withour battery then you then battery needs replacement.
Nov 25, 2009 | Dell Latitude D600 Notebook
Dell Latitude d600 starts up, loads Dell screen, but stops there
try removing the battery . wait 30 minutes. plug the battery back in and try again.
Sep 12, 2009 | Dell Latitude D600 Notebook
Power button
try one step if that doesnt work contact the dell tech on 18006249896 it could be a major hardware failure
remove the battery and also the power cable and hold down the power button for 10 sec and than connect the battery and the power cable and start the pc that should work
Jan 12, 2009 | Dell Latitude D600 Notebook
D800 will not even boot
remove the battery from the system and try to power on the System with the AC adapter connected. its only to check whether the system is receiving the power .
Also press the Fn key holding it down press the power button and release both the buttons , look for the LED codes and do let me know abt it
Apr 21, 2008 | Dell Latitude D600 Notebook
Dell Latitude D600
remove the battery and adapter..keep the power button pressed for 10-15 seconds....again plug in the battery\adapter and turn it on...
Feb 08, 2008 | Dell Latitude D600 Notebook
Dell Latitude D600 Notebook Logo
951 people viewed this question
Alun Cox
