Question about Garden
9hp kawasaki ohv engine will not start, has spark, new fuel added, compression check 90psi
  • 7,482 Answers
Hi kevinmarquet
Check /Clean/Replace your fuel filter if you have one.
Also make sure you are using fresh fuel...and oil mix if your using a two cycle mower or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the mower/weedeater is over a year old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
Once you have your carburetor rebuilt that should solve your problem.
This is a FREE answer,Please take time to rate me
Posted on May 25, 2011
Have A Honda ES6500, under 100 compression but leak down test was ok. Will not start. New gas plugs and new carb?
Is there a spark at the plug?
Is there good induction and fuel reaching the combustion chamber?
Is the choke, strangler or cold start working?
An engine needs compression, timing, the right amount of fuel a good spark and a decent cranking speed in order to start.
A side valve easy start engine is likely to have a low compression pressure as would an ohv engine designed to run on poor fuel. Other types of engine with low compression but a good cylinder leakage results probably has a dry or fuel-washed bore and adding a little oil into the cylinder can improve matters.
Feb 11, 2018 | Honda Motorcycles
Flooding kawasaki 250r wont start but has spark. whats wrong?
carb inlet needle and seat leaking or float level is wrong causing it to flood
Jan 16, 2018 | kawasaki Motorcycles
John Deere RX 75. What type of oil does it use? any other suggestions?
The wrong oil won't stop an engine from starting but the right oil will help it to last longer. Buy a respectable brand and there will be an application catalogue making recommendations for which of that brand's products are best in which engine.
It is little use changing parts and hoping. You need to be checking for a good quality spark and for the presence of fuel getting into the cylinder.
An engine needs compression and the right amount of fuel delivered into the cylinder and ignited at the right time by a spark of sufficient quality. An engine that doesn't start has at least one of those requirements missing. The challenge is to discover which...
May 13, 2016 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
Has spark fuel and 125 compression will not start?
Use a small amount of starter fluid in the intake past the filter. If the engine fires than you can be confident it is a carburetor problem.
Check for water in the gas
The carb cleaner may not be volatile enough to support ignition. The over the counter starter fluid is easily ignited even in cold weather.
If the engine has been in storage with old gas it is likely that residue has formed in the carburetor. If it does fire up with stater fluid but will not run with full choke it will most likely require a carburetor cleaning.
Jan 08, 2016 | John Deere Garden
John deer gx75. 9hp kawasaki. Turns over but won't
check and clean air cleaner. Check main jet for blockage.
Jun 23, 2013 | Garden
John Deere Gx75, kawasaki 9hp motor- oil in carb!
A very common problem with the GX series with Kawasaki engines. The carburetor 'inlet needle' sticks open and fills the crankcase with fuel. When checking the oil, it can be difficult to see the gasoline and the level appears to be OK. Remove the dipstick and smell the oil, you may detect a gasoline smell. Also, drain the oil, and you may find much more fluid than you expect.
The solution on newer mowers was to install an 'in-line' shut-off valve to keep the fuel from syphoning into the carburetor. The inlet needle and seat in the carburetor is NOT replaceable, so a new carburetor is the ultimate solution, but VERY expensive. Installing and using an in-line shut-off valve is more affordable.
Also, this situation is common when machine is transported on a trailer, as the bouncing causes the needle/seat to leak. When transporting, always turn off the fuel supply to the carburetor.
Nov 07, 2009 | Garden
Weedeater will not start. was running, shut it off and then will not crank. I have checked all the obvious(spark plug and wire, has good fire, fuel filter and lines,took apart carb and cleaned good) still...
Pull the spark plug after pushing the primer bulb and cranking a few times...if the plug is "wet" (indicating fuel is present in the cylinder) then the next step will be checking the compression...compression should read above 90psi (preferrably 100-125psi)...if compression is below 90psi, the most likely culprit will be a stuck piston ring.
Sep 06, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Compression on 2000 polaris 250 trailblazer
the fuel could be good but still it wont spit check the carbs when you throttle or kick start if thats possible if that is good try some starting fluid it should start up and the fuel pump should get out the obstruction if theres more problems it is one of many things either bad fuel pump, your fuel line is disconnected, blown headgasket idk the psi specs for the 250 but that sounds good i know for the 550s its around 120 and so on
Apr 24, 2009 | Polaris ATV
Garden Logo
188 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
