Question about Teac Audio Players & Recorders
I have a Teac P-A400 turntable. Power is on, something is turning, but the actual table that holds the record does not turn. What might I be missing?
I have the same problem and have tried to lift the metal platter without success. So you have to come up with harmless tools to be able to rotate the smaller platter underneath the large aluminum platter which has holes that will allow you to slowly but eventually be able to wrap the belt around the circumference of the inner platter. No sharp tools!
Posted on May 31, 2010
  • 3 Answers
Have you removed the metal plate to view inside...it could be the little belt.
Posted on Sep 26, 2009
Why does my crosley turntable not turn when I put the needle down on the record
If you manually put the needle on the record, you still have to push the power on button. If you are using the auto on and the turn table isn't turning, either the band from motor to turn table broke (or came off) or the motor for turn table stopped working. All this is as long as there is power to the unit.
May 15, 2014 | Crosley Audio Players & Recorders
Electro Brand model number 9801: I played one record, now when I tried to play another the turntable will not rotate. Could the motor have burned out that easily?
Listen carefully with your ear to the turntable when you move the tone arm towards the record. If you can hear the motor running and the turntable is still stationary then the drive belt from motor to turntable has probably fallen off of broken. Lift the turntable, there's normally a metal clip holding the turntable in place, and locate the drive belt.
Jan 19, 2014 | Teac GF-350 CD Shelf System
My turn table is going to fast when i play an record , what can i do to fix this? thanks
Hello the turn table has two speeds. 45rpm and 33rpm (rotations per minute) If you are playing a record that takes up the entire turntable you need to set it on 33rpm. For the records that only take up half of the turntable you want to set it on 45rpm. Setting the turntable on the wrong setting for a certain size record can make the record play to fast of to slow.
Mar 24, 2011 | Panasonic Technics SL-BD22D Turntable
I HAVE A TEAC CD RECORDER WITH TURNTABLE/CASSETTE PLAYER #GF-450F7\r\nWHEN A PUT IN A RECORDABLE BLANK CD I GET ERR4 OR ERR8 MESSAGE ALL THE TIME, UNABLE TO GO TO THE NEXT STEP TO RECORD, THESE CODES ARE...
Is it a recordable blank CD with "audio" or "music" printed on it? It MUST be.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Teac-GF-450K7-manual/id/23167bh436/t/2/
"ER **" (variable) IS in the manual on page 29 and it recommends power off, wait a minute and power on, which isn
Mar 23, 2011 | Teac GF450K7 Turntable
Turntable belt is off.
Under the felt of the turning platter section, there should be two rather large holes. Insert your thumb and forefinger and pull the table off. You should also see where the existing belt is running. Insert new belt around the motor first and replace the table section. Now, through the two holes, manouver the belt onto the table section until it spins freely
May 16, 2010 | Teac GF-600 Turntable
I have a new Yamaha RX-V365 receiver and an older technics turntable, regardless of input setup I cannot get any volume from the turntable, yet all other inputs like CD, Tuner are fine....amp issues in...
Some turn tables do not have a built in amp, especially the older ones, the sound goes from the needle to the output. If the amp your are using does not have a designated phono, turn table, input it may not have the turn table pre-amp built in. Some turn tables have to be grounded to the amp to work properly.
Aug 30, 2009 | Teac DC-D2800 Shelf System
Turn table wont spin.
if its a direct drive turntable then the motor is under the spindle as the spindle is a composite part of the actual motor? Its most likely burnt out i`m afraid? sorry
Jul 14, 2009 | Sony PS-LX250 Turntable
Technics SL-5 Turntable will not turn.
try gently pushing the tone arm (actually the piece of plastic holding the tone arm) over to the right a little. works for me, but it still gets stuck often
Apr 06, 2009 | Audio Players & Recorders
Kenwood Turn table
And play then at the same time.....those stopped being produced for the consumer market since the 90s. You will need to find a manufacterer still making automatic turntables..start from there, those those turntables usually are hard on records and offer poor fidelity.
Oct 03, 2007 | Kenwood KD-291RC Turntable
530 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
