Question about Durabrand HT-3915 System
I need a fuses for my durabrand home theater system and model is ht-3916. i went to radio shack and purchase a fuse 1.6 amp volt fuses and it still don't work can you please help me thank you
  • Durabrand Master
  • 5,349 Answers
Do you mean it blew them again or that it didn't work and the fuse is still intact?
If it blew it again the problem is not the fuses. Instead what you have is a semi-conductor device that has developed a short and that is blowing the fuse. Check any devices in the power supply section, look for signs of damage or heat and also any devices on the heat-sink.
If the fuse did not go and it still doesn't work check the power supply only or the on-off switch.
Posted on May 27, 2011
I need a fuse for my Durabrand Home Theater System HT-3917. The fuse is T 1.25AL/250V. Where can I get that fuse?
TRY MAPLINS OR A ELECTRICAL STORE OR EVEN A DISCO SHOP WILL STORE THESE FUSES.
TAKE THE OLD ONE WITH YOU AS THEY WILL NEED TO KNOW IF IT IS FAST BLOW CAP ON EACH END WITH A SINGLE WIRE INSIDE OR NOT (IS THERE A SPRING AT ONE END INSIDE THE GLASS TUBE THIS IS CALLED A SLOW BLOW FUSE).OR IS IT IN A CERAMIC WITH A METAL CAP ON EACH END.
HOPE THIS HELPS
NORMAN
Aug 23, 2011 | Durabrand HT-3915 System
Need codes for ht3916 to chage remotes
Description=Durabrand Home Theater System (HT-3916)
Remote.name=URC-6131nwB00 PVR Remote 2K
Remote.signature=PVR0PVR0
DeviceType=Amp
DeviceIndex=3
SetupCode=1568
Protocol=00 5a
Protocol.name=NEC2
ProtocolParms=24 null null
FixedData=01 e7 e7
Function.0.name=Power
Function.0.hex=c7
Function.1.name=Mute
Function.1.hex=e7
Function.2.name=Source
Function.2.hex=d7
Function.3.name=Channels
Function.3.hex=67
Function.4.name=Reset
Function.4.hex=cf
Function.5.name=Front (-)
Function.5.hex=6f
Function.6.name=Front (+)
Function.6.hex=5f
Function.7.name=Center (-)
Function.7.hex=57
Function.8.name=Center (+)
Function.8.hex=df
Function.9.name=Rear (-)
Function.9.hex=47
Function.10.name=Rear (+)
Function.10.hex=ef
Function.11.name=Subwoofer (-)
Function.11.hex=77
Function.12.name=Subwoofer (+)
Function.12.hex=ff
Function.13.name=Master Volume Down
Function.13.hex=4f
Function.14.name=Master Volume Up
Function.14.hex=f7
Button.8=Mute'null'null
Button.3=Power'null'null
Jul 23, 2011 | Durabrand HT-3915 System
My durabrand cd home music system wont come on
If you have no lights or power to the unit, check on the back of the unit to see if there is a twist and pull type knob for a fuse. If so, unplug the unit/player and take the fuse out. If it is damaged/broken/wire element burned/cracked, it will need to be replaced. Take the old fuse with you to make certain of a correct match(volt/amp/slow or fast acting)Most Radio Shack/Walmarts/Ace Hardware stores stock these type of fuses. They are very inexpensive, usually less than a $1 or $2. They are on most home entertainment equipment/t.v.s etc. to prevent some degree of lightning or power spike damage the unit.
Oct 13, 2009 | GPX HM3817DT Shelf System
Looking for replacement remote control for durabrand ht-3916 ..unit was given to me without remote and new this unit only cost $40. I don't want to buy remote that is as much as a new unit
logitech has a really good lineup of universal remotes..it could also make ur life easier with the other equipment in ut house.
http://www.logitech.com/index.cfm/remotes/universal_remotes/&cl=us,en
Aug 05, 2009 | Audio Players & Recorders
Need a manual and codes for durabrand HT 3916
Hi
I need a manual in English for dURABRAND ht 690 MODEL
May 10, 2009 | Durabrand HT-3915 System
Durabrand HT-3915 System Logo
396 people viewed this question
Top Durabrand Audio Players & Recorders Experts
Lyle Siemens
Lyle Siemens
Carlos L. Burgos
Carlos L. Burgos
SHARCNET-USA
SHARCNET-USA
Are you a Durabrand Audio Player and Recorder Expert? Answer questions, earn points and help others
