Question about IBM Office Equipment & Supplies
I could only get 1/2 of every letter. It is a IBM select wheelwriter. How to fix? It uses a IBM ribbon #1380999
  • IBM Master
  • 3,594 Answers
You probably have an IBM Wheelwriter. Press down firmly on both ends of the platen (black roll) it should snap into place.
DickyO
Posted on May 25, 2011
IBM Wheelwriter 3 - Cannot get the complete word - Middle part of word is white
Type on a two part form if the carbons are goog then you have a ribbon problem. Look at the ribbon. Do the letters overlap (ribbon feed) If they don't fall in a line near the center of the ribbon (ribbon lift) Check for folds in the ribbon.
DickyO
Oct 04, 2012 | IBM Wheelwriter 30 Typewriter
Hi, I have an IBM Wheelwriter 30 Series II. When I type text it does not type the bottom 20 % of letters. I changed the ribbon and made sure that the roller was securely locked down. Any suggestions? ...
yes in the carrier ribbon there is a adjustment of ribbon to fix it up and down.
take out the ribbon.
see the cam from where the ribbon carrige lift up.
in side that cam a adjustable screw from that screw you can adjust the ribbon hight.
Nov 25, 2010 | IBM Wheelwriter 30 Typewriter
Ibm wheelwriter won't strike. Ribbon is good. Wheel is working. Carriage is moving. Just not striking. I dusted & cleaned as well as I can but to no good.
I HAVE AN IBM WHEELWRITER 6 TYPEWRITER THAT WONT STRIKE THE LETTER. EVERYTHING ELSE WORKS? CAN YOU HELP ME FIX IT?
May 10, 2010 | Office Equipment & Supplies
Wheelwriter 35 cutting off bottom of letters
First thin to do is to be sure the platen (rubber roll) is fully seated in the T/W side frames. press firmly on both ends of the platen.
DickyO
Mar 02, 2010 | Lexmark Wheelwriter 35 Series II...
Faint printing on checks
To my knowledge the 999 ribbon is the best avaivable. Try these things. put a little light (WD40 works well) oil on the back side of the print solenoid, then perss code and "Q" the display will show 1,2 or 3 set it at 3 and then try code "B" for bold print. These should help.
DickyO
Feb 02, 2009 | Lexmark Wheelwriter 3500 Typewriter
IBM Personal Wheelwriter 2
Look at the ribbon and see if the letters are on the very top of th ribbon. If so on the front of the carrier there is an eccentric screw for adj. ribbon height. Loosen the lock nut W/ a small 9/32 wrench and adj screw to raise ribbon. Be sure to check L/O with the underscore as you can get it to high.
DickyO
Jul 02, 2008 | IBM Wheelwriter 30 Typewriter
Replaced Part No. 1337765 and 1380999, but there is still no ink coming out
It sounds like th4e plastic cap on the print solenoid plunger is broken. The part is avail. but a little tricky to replace.
DickyO
May 16, 2008 | Office Equipment & Supplies
Ibm wheelwriter 5
Most likely the plastic cap on the print solenoid is broken they are available but are a bit tricky to install.
DickyO
Mar 27, 2008 | IBM Wheelwriter 30 Typewriter
IBM Easystrike Cartridges
The ribbon cartridges can be pried apart they are pressed together, getting it apart is easier than putting back together.
Next time you have to install a ribbon advance it by hand for a foot or so as old ribbons tend to stick to themselves.
Hope this helps
DickyO
Feb 08, 2008 | Lexmark Wheelwriter 3 Typewriter
55 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
