Question about Moffat Ovens
Seems like the blower motor is making a lot of grinding noise and the fan is not spinning quickly. also the fan continues to spin when the door is open.
    Problem Solver:
  • 7 Answers
The blower wheel has come loose from it's base, this happens a lot with ovens where aluminium foil is used, as the Moffat oven was designed to be the ultimate pastry oven, free flow air system was designed into it, I would start with the blower wheel as it is usually the cheaper of the 2 to buy.
Posted on May 24, 2011
Algor fan making noises
switch off main wall switch check how free the blade spins if tight needs a drop of oil on bearings if able to access them or may be worn out check blades are not rubbing on part of cover or side.
if a small drop of oil is put on a screwdriver may access if spins free then test.
Oct 16, 2014 | Ovens
Viking washer grinding noise on spin cycle
LOUD NOISES IN washing MACHINE;
LOT OF THINGS TO CHECK, THE BELT LOOSE OR WORN, THE CLUTCH, THE TRANNY, THE BEARINGS BOTH TUB SEAL AND BEARING, THE REAR DRUM BEARING, the balance or counter weights.
THE DRIVE PULLEY- If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
THE TRANSMISSION, THE MOTOR COUPLER, THE MOTOR DRIVE BEARINGS,
THE DRIVE MOTOR- If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
The drive coupling connects the motor to the transmission and consists of two plastic drive forks with a rubber coupling between them. One of the drive forks is attached to the drive motor shaft and the other is attached to the transmission input shaft. As the motor shaft rotates, the rubber coupling between the drive forks absorbs the torque to prevent the forks from breaking. Normal use will create wear on the coupling and eventually the drive forks may slip and cause a vibrating noise. If the transmission seizes or if the spin basket cannot turn freely, then the coupling may fail and again you may experience a vibrating noise. Most models will require you to remove the cabinet to access the drive coupler. Disconnect power from the appliance before attempting any repairs.
A worn drive block will usually have a pounding sound, like hammering metal, during spin when it first starts. If there is enough interlocking tab left on the drive block, you'll see it finally engage at top speed with an empty basket.
In a transmission lock up the holes get enlarged in the rubber isolator and the studs break off the motor and transmission couplers. This is usually caused by the abrupt motor reversal between the agitate and pump out functions. If you hear a loud bang every time the motor reverses, the coupler is getting loose. An obvious sign of a failed coupler is a pile of black rubber shavings under the washer. If the motor runs and the agitate and spin functions don't work, the studs may have broken off the coupler (old coupler design) or the coupler may have broken at the shaft (new design) and you need a new coupler kit. The coupler can also just crack around its center hole allowing it to slip on the motor or transmission shaft hampering those functions.
If the washer is making a loud noise the drain pump might be going bad or might have something caught in it. Remove the drain pump from the washer and inspect it carefully. Look for anything that might be caught in it, a piece of wire, plastic, etc. If nothing is wrong with the pump, but it's still noisy it will have to be replaced.
Front load washers often use a self contained electric drain pump and the motor may be worn or damaged and require the complete pump to be replaced. Remove any foreign objects or replace the worn or damaged pump, thencarefully tighten the hose clamps and check for leaks before installing the cabinet or front panel.
All front-load washing machines have shock absorbers that are used to dampen the tub movement in the spin cycle. The shock absorbers or struts are attached to the base frame and to the outer tub and you will need to remove the front panel or the rear panel to access them. When shock absorbers weaken or become damaged, the machine will often make a loud banging sound during the spin cycle and if the symptom is not corrected, can lead to damage of other components. Inspect the shocks for signs of broken attachments, leaked fluids or a weakened dampening action and replace both shocks if worn. Remove power from the appliance before attempting this repair.
Some models of top-load washers use tub dampening straps to cushion the movement of the tub during the spin cycle. There are four straps attached to the top of the tub and to each corner of the cabinet
Also There are four suspension rods that suspend the tub and allow the tub to free float. If the suspension rods are noisy, there will be a squeaking noise during wash. You can fix this by putting bearing (lithium base) grease in the cup that each rod rests in. If it continues to squeal replace all four rods the cups come with the rods, replace them as well.
If your washer has a loud banging noise during spin the balance weight may be loose. This weight is to counter act the weight of the motor so you will find the weight directly behind the motor. Sometimes simply tightening the bolts will fix your issue but if the bolts are stripped out get some bolts slightly longer than the original bolt to allow you to put a locking nut on the bottom side of the mounting plate. If the weight is broken replace it.
Lastly Washer vibration can be caused by a broken counter balance spring. Ur washer may be equipped with one or more counter balance springs which help to absorb the natural movement of the spinning tub. If a counter balance spring fails the tub might lean in one direction more than another and it will shake and cause vibration.
By the way my advice is free cuz God is good!
Apr 16, 2014 | Viking Ovens
Beko built in oven fan makes a noise like it's catching on something, now the fan has stopped
you will need to change the motor
This video will show you how to replace fan oven element in your
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 14, 2014 | DeLonghi DEBIGE 2440 Electric Double Oven
Main oven motor cover
Why not secure the fan cover?
Jun 22, 2013 | Ovens
Turbochef problem with door and magnetron blower
First aligning the doors on these ovens are a pain. In the service manual there is a whole chapter on doing this process. Contact turbochef and buy a manual for 30 bucks.
Second the mag fan should operate for 4 mins after the cook cycle has completed to continue cooling the mags down. If it goes longer than this then the control board chip needs updating or you have a bad mag fan relay.
Mar 03, 2012 | TurboChef TORNADO Electric Oven
My oven fan is making noise what should i do?
check to see why it is making noise. look at the fan while it is spinning DO NOT INSERT YOUR HANDS and see if you can see what the fan is hitting and why it would be hitting whatever it is hitting could be the shaft onthe motor is maybe bent or a blade is bent on the fan blade itself or maybe something fell into the fan and that might be makin the noise hope this helps
Jul 17, 2010 | Ovens
My turbochef tornado gives an error messag of
this is simple to fix but usually costly sorry to say.
F1 blower means the motor is not running when commanded.
first check the motor and verify if it spins freely - if the motor does not spin freeely remove the obstruction or replace the blower part# NGC-1025
just to clarify its the big blower behind the cook chamber not the little fan in the electrical compartment.
Dec 30, 2009 | TurboChef TORNADO Electric Oven
Nef B1432 (2000) not heating up properly
You possibly need to fit a new fan motor, as this will certainly cause temp variations, if it is not working properly.
If you remove the inner rear cover of bottom oven, you will see the element and the fan.Try spinning the fan by hand, it should revolve freely, and rotate on its own after spinning it by hand.
If it does not, then it needs replacing.
It is a fairly straight forward job to replace, just bear in mind that the fan is held on by a left handed nut, so to undo it , hold the fan blade, and unscrew the nut clockwise, as though you were tightening it up, and vice versa to tighten it.
You will have to remove the main rear cover of oven to access the the terminals and the fan motor.
Please rate my fixya soution.
Thanks.
Jan 31, 2009 | Neff B1432 Single circotherm plus Electric...
Neff 1861 oven fan stopped working
Fitting new bulb would not cause fan to stop working.
If it is getting hot, then there is something wrong with fan, try spinning fan by hand, it should be free, and continue to spin under it's own momentum.
Hope this helps.
Plz rate my solution.
Thanks.
Dec 29, 2008 | Neff B1861 Single circotherm super...
Ovens Logo
273 people viewed this question
Top Moffat Ovens Experts
Lawrence Oravetz
john h
Are you a Moffat Oven Expert? Answer questions, earn points and help others
